Question about KitchenAid Refrigerators
Kitchenaid refrig KSRS25ILBL03 will not maintain temperature. Sometimes freezer goes from 0 "temperature setting" then will rise to 40+ degrees for no cause.
  • 46 Answers
If this only last for a shot time its just in defrost
Posted on Jun 27, 2009
Refrigerator
The self defrost mechanism is not working. The evaporator is getting blocked with ice, an insulator, and that affects freezer as well as refrig temps. When you unplug unit the ice melts and it will work till the ice block returns.
Sep 07, 2016 | Refrigerators
What is the normal fluctuation range of a top freezer in a freeze-refrig combo? That is if I set the temperature of the freezer a 0 F, at what temperature should the freezer come on to keep the air i
Hello Richard;
My name is Peter. I am a retired field service refrigeration technician.
The normal range for a freezer is -2 to +2 Deg. F.
The normal range for the fresh food section is 35 to 40 Deg. F.
If you set your freezer at 0 Deg. F. it will stay at 0 Deg. F.
When the freezer temperature drops below 0, your compressor will kick in to bring the freezer back to 0 Deg. F.
Dec 15, 2014 | Frigidaire Refrigerators
The alarm light is flashing what do I do to stop it.
Hello Mrs. Mavis;
My name is Peter. I am a retired field service refrigeration.
The alarm light is a good thing. It is telling you that something is wrong. Generally, the alarm goes off when there is a temperature problem in either the freezer section or your fresh food section.
You only have one cooling source and that is in your freezer. Your freezer will satisfy its own temperature before it feeds your fresh food section.
Ok, Your freezer temperature should be between -2 & + 2 degrees F. Your fresh food section should be between 35 & 40 degrees. F. Adjust you temperature settings accordingly. Wait for a few hours to see if the alarm goes off.
Another problem with maintaining temperature control; people tend to over pack their freezer or fresh food section. Check to make sure your food product does not over extend the shelves. Also check the racks on the doors. Check to see if food product does not over hang the racks.
You also need to maintain your refrigerator. You have a cooling coil like the radiator in your car, it gets rid of heat. You must keep this clean. A dirty condenser coil can effect your temperature by as much as 40 degrees F. This coil is located either under in the front of your refrigerator or a canister looking item in the back of your refrigerator behind the lower cover.
Look at the back of your freezer wall. Is there a lot of frost or ice?
This could be either a defrost heater or freezer fan motor.
Call me. Lets talk about this more. 443-306-1362.
Nov 04, 2014 | Refrigerators
The freezer doesnt go below 0 degrees anymore it goes 27-28 degrees . What could be the problem?
A defective temperature control can cause that problem.
Check by dialing it, it should be smooth when dialed.
It should be on desired degrees where you set it and not on other.
Thanks for asking.
Jun 27, 2011 | Coldtech 40 cu. ft. / 1133 liter...
What is the proper temperature for a refrigerator be and what is the proper temperature for the freezer?
A refrigerator should maintain temperatures at or below 40 degrees F. The freezer temperature should be 0 degrees F or lower
May 13, 2011 | Amana Refrigerators
New whirlpool refrig. freezer ok at 0 but refrig
The freezer get the first crack at cooling and combination units have a fan and adjustable vents to steal some of the cooling capacity for the refrigerator. The vent are normally located in the back of the refrigerator compartment and with these, you can balance the cooling capacity between freezer and fridge. I recommend you swap your thermometer back and forth until you get the balance you want; typically the freezer should be at 5 degrees F or below and the fridge at 35-40 degrees F. Adjusting the control for temperature and having the vents set to supply the cold air you want in each compartment should give you the range you want in each.
Sep 09, 2009 | Whirlpool Freezers
Freezer temperature is not consistent
No recall that I have on my listing for that model. Keep in mind that the refrigerator goes into a defrost mode that lasts up to 30 minutes. It happens anywhere from 10 hours to 60 hours of operational time. When this happens, it's not uncommon to see 20 ° temperature. If you check it again an hour later, it should be back under 10 °. Also, double check to be sure the condenser coils are really clean. That alone can also cause this sort of symptom.
Oct 24, 2017 | GE Refrigerators
Temperatures fluctuating
Wonder why the "repair men" can't find a defective temperature control or circuit board.
Nov 06, 2017 | Frigidaire Refrigerators
Freezer not cold enough; fridge OK
Hello cokoliso,
Welcome to Fixya
You said, your Trio won't make ice. Freezer stays at about 25 degrees regardless of control setting. Fridge maintains 40 degrees at mid setting. Shouldn't the freezer be close to zero? Is there a way to check the temperature sensor in the freezer?
To check the temperature you can buy a refrigerator thermometer at the hardware store.
Ask if it can be used in the freezer too!
The fridge sounds slightly to cold and the freezer not enough.
Fist look in your freezer and check if the articles there are full to the max and covering the air vents usually found in the rear of the freezer.If so clear an opening for the freezer to breath.
Refrigerators and freezers usually share the cold air and I've seen this be the problem on many occasions.
If freezer was not I blocking the vents or even full to the max.
Then pull the plug out or if you can not reach the plug, trip the breaker off for 5 minutes and see if this resets the system.BUT do not plug the fridge back in before at least 3 minutes.
Let me know how it goes and send me any questions.
Thank You, Huuum
Please remember to leave a rating .
Oct 03, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Defrost Mode
YOU MIGHT HAVE A GAS LEAK ON THE UNIT.OR THE COMPONENTS IN THE FREEZER COMPARTMENT ARE NOT WORKING WELL.BEST YOU GET AT TECHNICIAN TO HAVE A LOOK.GOODLUCK.MOHAMED
Sep 08, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
296 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
