Question about Refrigerators
Fridge is not as cold
FreezerI have cranked to 9 and fridge is 55 degrees. Is the freon going out? The freezer seemed to leave a snow covering.
  • 3 Answers
YES TO THE FREON. HAVE IT RECHARGED. OR PULL THE FRIDGE OUT AND CHECK THE COPPER TUBING BEHIND THE FRIDGE FOR CRACKS
Posted on Jun 26, 2009
My may tag fridge GS2126PADB seems to run fine but the freezer is not blowing cold air and fridge & freezer are warm.
There are more than reason: first check the fan in the upper part of the freezer (you have to unscrew 3 bolts of the cover),second check the freezer door sealing,third is to check that the cooling tubes inside the freezer are cold enough without heavy snow (you have to unscrew about 6 bolts of the cover),Heavy snow reduces cooling and it means that the timer is not working or the heater is not working.I hope to help you in reform
Jun 27, 2014 | Amana ARS266ZBS Side by Side Refrigerator
Fridge flashing temputure at 1 degree fridge doesnt seem cold
you need to upload your freon you just call the technician..your freezer lack of freon that's the reason why....
Mar 28, 2010 | Samsung RS2630SH Side by Side Refrigerator
Freezer cold fridge 52 degrees
We have a Kenmore Coldspot Model # 106.8770687 and the freezer is cold and keeping things frozen, but seems to be frosting over and the refrigerator is warm at 40 to 50 degrees ... any help regarding what to check is helpful! Or a schematic / manual
Jun 14, 2009 | Kenmore Refrigerators
Fridge portion of my 611 is warm but freezer is still cold. Help.
The only other thing that seems could be wrong is that your freon lines are icing up and is cause you to not cool properly. Pull out your fridge and check the compressor on the bottom
Feb 07, 2009 | Sub-Zero 611 / O Bottom Freezer...
Freezer is cold cold....fridge is at approx 50 degrees
Hello lmk400,
Welcome to fixya,
Haier HRF10 Top Freezer Refrigerator
You siad, your freezer is cold cold....fridge is at approx 50 degrees What could it be ????????
1. The first thing it could be is that you have a freezer that is packet to the ceiling.
And so full that it's articles are covering the air vents found in the rear of the freezer.
They are need to be clear for the cold air to circulate form and to the fridge compartment.
Yes that is correct!
The freezer and the fridge both share the same air and to restrict the air causes the other
to get warm.
And will eventually burn out your fan motor or possibly your compressor!
OR
2. Your fan motor is already burned out.
Try checking this and clearing the vents.
It will take some hours to get cold and all night to reach peak temperature, if this is your reason!
If not you should then try turning off the fridge AND, then unplugging it for five minutes.
This should reset the system if there is an electronic glitch!
If all this fails you may be low on freon and need service to add some.
If the fridge was left open a crack all night or all day by accident it will cause this!
or if you go shopping and while unloading or loading the fridge with the door wide open running back and forth to the kitchen table for some extended time to!
Gather all the cold stuff near the fridge and put them in quickly!
I gave you a lot to work with and I hope the first two suggestions are the fix and solve your problem.
Let me know!!!!
Huuum
Please rememebr to leave me a rating at our fixya site!
Oct 21, 2008 | Haier HRF10 Top Freezer Refrigerator
Whirlpool side by side refrigerator not cooling
Hello danielscynt,
Welcome to Fixya,
You said, freezer is fine the refrigerator is 50-65 does not get colder than 50.the evaporator fan is working but it seems to be blowing very little air
Have a 1998 Hotpoint Model # CTX16CAZDRAD Serial # ZS738209. The refrigerator is not cooling. Temp is at 66 degrees with setting at 5. The Freezer is working, but it seems to be running all the time. Please help!
There are a few things that come to mind!
The Freezer is working, but it seems to be running all the time, you said!.
This could be a bad thermostat!
But lets try some simple maintenance first!
Is your freezer packed too the hilt with packages???????
Where the articles cover the air vents in the freezer?
The freezer and the fridge share the cold air and the passages must not be blocking the cold air from moving out of the freezer!.Search your freezer !
Also your fridge is 10 years old!
Did you ever remove the plastic grille at the bottom of the fridge along the front, and GENTLY run a refrigerator brush along the black metal tubes running back and forth under the fridge?
( You can buy this brush at any hardware store $10.)
They must not be covered in ten years of lint and dust. These narrow tubes carry the freon and run in this parallel fashion back and forth, so they are cooled by the air being **** through them.
if not and they overheat your fridge will get warm.
If the tubes are found to be covered or submerged in dust sometimes I have found them one to two inches thick in dust, and sometimes they are even not visible until you clean the dust out.
Then it will take 10 to 24 hours for the system to get back to full working temperature again. As long as the heat did not cause permanent damage!
if these are not the answer, then you may need a hands on diagnoses!
BUT, most of the time these two things are what I find!
Let me know how it goes!!!!!!!!
Thank You for asking my advice!
Huuum
Please remember to leave a rating for me!
Oct 08, 2008 | GE Hotpoint Top-Freezer Refrigerator
Fridge not getting cold
Hello swill688
Welcome to fixyz
You said, Your Kenmore refrigerator not getting cold
What is the model number?
And how old is it?
First check that the freezer is not filled packed full, and covering the air passage vents in the rear of the freezer! The fridge and the freezer share cold air from the compressor.
and his can cause the fridge to get warmer.
The other 2 things may be, either the coolant is low and needs to have the pressure checked then perhaps a sot of freon.
Or the thermostat may be malfunctioning!
I hope the freezer is packed to full, this is the easy way out of this situation!
Let me know!
Please remember to leave a rating before you leave us!
Thank You, Huuum
Sep 30, 2008 | Refrigerators
Kenmore side-by-side with thermo switch problem?
Acting like a bad thermostat, One thing to check is make sure compressor isnt overheating. If really hot you could have a relay problem on compressor.
Jan 05, 2008 | Refrigerators
Refrigerators Logo
101 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
