Question about Weber Genesis Silver B Grill
How do i start my genisis special editon weber grill
5 Suggested Answers
onyxvu
  • 74 Answers
SOURCE: weber gas grill will not ignite
you will probably have to get a new igniter or try to adjust the one you have. there is a little electrode on the igniter that needs to be clean and a certain distance away to work properly.
Posted on May 26, 2009
heatman101
  • 43501 Answers
SOURCE: i have a weber genisis gas grill. the front
Your problem could be or probably is with the regulator...not enough gaspressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Posted on Apr 02, 2011
hunter19_46m
  • 7482 Answers
Hi nasanelg...
If all the venturis and holes of the burner is clear then the problem has to be either a defective hose or gas pressure regulator.
If it is defective hose then the whole gas regulator and hose assembly will have to be replaced as they come normally as a unit.
Try this: Take the hose off of the gas tank and take a small hammer and tap a little more than "lightly" on the gas regulator, sometimes the valve inside will get stuck and not function properly and not allow enough gas to enter the grill burners. Reinstall the gas regulator back on the grill and try to see if it allows more gas now...if not, try tapping a little harder and try again.
If it again fails to deliver any more gas to the grill, then it is defective and you will need to replace it with a new one, if you can find one that has an gas adjustment knob/plug on it I would recommend that you purchase that one as you will be able to adjust the flow of gas to the burners.
I hope this solves your problem.
Hunter
Posted on Jun 06, 2011
  • 4736 Answers
SOURCE: weber grill has been performing
To solve this problem, first be sure you have adequate gas in the tank. If that checks out OK, do the following:
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling.
Posted on Jul 05, 2011
I can't get my new Weber Q120 started?
you might need to clean the orficies on the grill
Apr 06, 2012 | Weber Q120(LP) Grill
I have Weber Genisi Silver model 8133 which has been hook up to a natural gas line. We have moved to a new location and can only use a propane tank hook up. Do I need a adaption for conversion to...
Unfortunately, you cannot use your Natural Gas Grill on Propane Gas. In addition, there is no conversion kit for Weber Grills. That's why they make two different gas models. Conversion of a grill becomes a safety issue. As each model Weber grill is tested and approved only for the specific gas type. Attempts to convert it voids that approval.
I'm sorry I didn't have better news. Thanks for choosing FixYa.
Jul 27, 2011 | Weber Genesis Silver B Grill
Weber grill has been performing inconsistently. It does not heat up above 250 degrees and frequently the flames go out. It's a Genisis B two burner grill
Jul 05, 2011 | Weber Grilling
Should there be fake coals in my gas weber bbq
Get rid of the fake coals they will only collect grease and cause a fire.
Jun 29, 2009 | Weber Genesis Silver B Grill
Paint inside lid peeling off when I cook
From Weber.com Don’t worry, it’s not paint. The inside surfaces of our grill lids are not painted, they are coated with baked-on porcelain enamel which cannot peel. What you are noticing is a deposit of grease and smoke that collects during normal use. During use, the grease and smoke vapors slowly oxidize into carbon and collect on the inside of your lid. This deposit will eventually peel, and looks very similar to paint. The peeling normally starts in the center of the lid and spreads outward. It may come off in sheets or flakes, and is shiny on one side and dull on the other. These carbon deposits are non-toxic. But you might want to regularly remove the build-up. Fortunately, the peeling is easy to remove. Simply brush off all loose particles with a brass brush before you start grilling. To prevent future build-up, after every grilling session, while the grill lid is warm—not hot—wipe it with paper towels or a mild soap-and-water solution.
Apr 25, 2009 | Weber Genesis Silver C Grill
Need manual or instructions for starting
The manual can be found in the support section of the weber website (www.weber.com)
Jun 22, 2008 | Weber Gas Go-Anywhere Grill
Weber Genesis Silver B Grill Logo
81 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
