Question about Linksys Wireless-G WRT54G Router
I forgot my network key for my WRT54GL - Linksys Wireless-G WRT54G Router
  • 854 Answers
Log on to Internet Explorer:
go to http://192.168.1.1
by default
username: admin
password: admin
go to wireless
click wireless security
here you will see the network key
Posted on Jun 26, 2009
How do i set my password on my linksys WRT54GL router
Turn over router and check in the bottom default access IP address and then type that IP address in to your browser. Then it shall ask you for ID and password. Enter `Admin` or `admin` as ID and `Password` or `password` as password. You will see a web based setup opened in front of you. Go to the Wireless Lan settings and then you will SSID so change the SSID and this would be your network`s name. Then go to subsection security and select WPA2-PSK or simple WPA-PSK then enter your desired network key. Once done with all these things the click apply and reboot if prompted.
May 12, 2012 | Linksys WRT54GL 802.11b/g Wireless...
I cannot find the SSID for my Linksys router WRT54GL-EU.
the SSID is the name of your network, usually it will be the model number i.e. WRT54GL
Apr 04, 2011 | Linksys Wireless-G WRT54G Router
I connected WRT54GL router to Motorola modem per linksys instructions. the router is not able to connect to the internet. please advise
This is most likely due to the Motorola modem still having the Media Access Control (MAC) address of the device that was previously connected the modem in NVRAM.
In order to clear this old MAC address, the easiest thing to do is to unplug the power cable from the modem for 15 to 20 minutes. This allows the NVRAM in the modem to clear and makes it able to accept the new MAC address of the router.
After the modem has been unplugged from the power for 15 to 20 minutes, plug the Ethernet cable of the router into the modem and plug the power cord back in to the modem. After the modem syncs back up to the network, it should add the MAC address of the WRT54GL router to its NVRAM and assign it an IP address. This should allow the router to connect your systems to the Internet.
Dec 27, 2010 | Linksys Wireless-G WRT54GL Router
Would like to secure my network
Follow this link to download the manual that will give you set by set instructions on your router. And security setup.
http://downloads.linksysbycisco.com/downloads/WRT54GL-EU_11_UG_A-WEB.pdf
Oct 04, 2010 | Linksys WRT54GL Wireless-G 54Mbps...
Linksys wrt54GL v.1.1 is saying nework cable unplugged-won't ping
Make sure that the computer is connected to the router properly and there is not loose conection. If it good then check the IP address on that computer. Make ssure that there is static IP address on the computer.
The default gateway number will be the IP address to access the router set up.
If you do not get IP address and if it says media disconected then try to disable the Local area connection and enable it.
If that doesn't work then try on another computer.
Click here for more information about the rotuer and networking
Apr 24, 2010 | Linksys Wireless-G WRT54GL Router
I have a Linksys WRT54GL wireless-G router connected to a cable modem and a PC using Ethernet cables. The wifi function is working fine with my two notebooks but I cannot get the computers to connect to...
Please
  1. Verify File and Print Sharing is installed for the wireless network card on each computer.
  2. Try pinging each computer.
  3. Try doing Start, Run, and in the browse line type \\and the ip address other computer. For example, if computer B has the ip address of 192.168.1.3 from computer A, do Start, Run and type in \\192.168.1.3 to see what that brings up.
Please post back if you have any questions.
Sep 15, 2009 | Linksys WRT54GL Wireless-G 54Mbps...
Router doesn't broadcast?
Make sure the brodcast light is on. and that brodcast is on in the congfig screen of the router.
Jan 29, 2009 | Linksys WRT54GL Wireless-G 54Mbps...
Can't access adminpage of the router from the 1st lan
you can use ethernet cable, or you can use the wireless.
search for the wireless network and connect your pc to that wireless network. or simply connect an ethernet cable to your pc and connect other end to the Linksys WRT54GL .
open an internet explorer (or whatever you use) type ip address.
Dec 17, 2008 | Computers & Internet
Connection
You have to set the wireless connection
Check if you have the wireless card ON or check if your wireless card is installed
My computer >> right click >>Properties>>Hardware>>Device Manager>>Network
If yes,
Click your Start Button
Select and click Control Panel
Select Network Connections
Select Wireless Network Connections
Right click
Select View Available Wireless Networks
5. Highlight the network you want to connect to
Click Advanced
6. Select the wireless network tab
7. Highlight the network in the available networks window
9. Click configure
9. IN the Properties Window
Double check the SSID (network name)
Enter the WEP KEY provided to you by the office
Click OK
Nov 09, 2008 | Linksys WRT54GL Wireless-G 54Mbps...
SECURITY PROBLEM
first go to router setting page, for access router page the default ip add is 192.168.1.1 try this first, if the router page is not open then check the default Gateway in u r pc and keep the ip add of ur pc ob tend automatically
1. when the page is open then go to wireless potion>wireless security>
2. then select encryption type WEP > 64 bits
3. then type pass phrase>click on "generate network key"
4. routher will generate 4 network key , select first key as wireless security key.
5. save this settings.
now the wireless connectivity automatically disconnected
6. now search the wireless network on u r pc .
7. when u get u r wireless network , then connect to this network
now the wireless network key is ask bye system ,
8. type the network key which generated by router .
and connect 2 u r wireless network
Aug 20, 2008 | Linksys Wireless-G WRT54GL Router
Linksys Wireless-G WRT54G Router Logo
255 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
