Question about FrancisFrancis! X1 - Stainless Steel Espresso Machine
Francis Francis X6
Hi. My X6 is leaking water from the group head. It can drain half of the tank within 30 minutes. I suspect the spring is broken. Is there any way to repair this OR is there an alternative diagnosis?
  • owlscliff Jul 03, 2009
    Thank you!! We aren't sure how to get the screen off. How is this done?
  • Anonymous Mar 19, 2014
    descaling francis francis x6
    President:
  • 1,618 Answers
It is possible that the gasket under the spring is damaged, remove the screen and diffuser and check the spring and gaskek in the middle hole. You can try backwashing which might force the spring and gasket in position.
Posted on Jun 27, 2009
Leaking water when not in use
possible of leaking internal pipe may need to change /or drip tray to full also cheak water tank and see if it leaks
Mar 28, 2016 | DeLonghi DE LONGHI EN95S M.CAFFE CAPSULE...
Intermittent rough idle
Hi Anonymous, and the usual suspects are:
1. Spark plugs in bad condition or partially fouled.
2. Spark plug cables in bad condition or leaking.
3. Spark plug gap to close or to wide.
4. Faulty ignition coil, module and or sensor.
5. Battery nearly discharged.
6. Damaged wire or loose connections at battery terminals,
ignition coil, or plug between ignition sensor and module.
7. Intermittent short circuit due to damaged wire insulation.
8. Water or dirt in fuel system, carburetor or filter.
9. Fuel tank vent system plugged or carburetor vent line closed off.
10. Carburetor controls misadjusted.
11. Damaged carburetor.
12. Loose or dirty ignition module connector at crankcase.
13. Faulty MAP, CKP, and or CMP sensors.
14. Incorrect valve timing.
15. Weak or broken valve springs.
16. Damage intake or exhaust vale.
For a prime suspect please visit website below:
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley... Good luck
Feb 10, 2014 | Harley Davidson Motorcycles
Hi have a commercial expobar two group head, the site glass was leaking so sent it in to be replaced. Have installed new one in machine but no water to group heads? Should the relief valve on the water...
First, I'm not a Expobar technician. But I've worked on similar Professional espresso machines. Since this is a Professional unit I assume you have a close relationship with the service tech. So the following is for the tech:
* Yes it is possible to install the site level glass upside down. It will still work but the fittings to the tank also has to be switched. (Hey, I did that too!) But usually the tech will realize the mistake and re-do it as it will take longer the switch out all the fittings. Easier to flip it back.
* In most cases the indicator is usually mounted on a back plate that is fixed to the front panel or the site fittings themselves. It's a lot of trouble to put it back right, so if you did your own work (the owner) then suggest getting a black marker and remark the correct levels. (correct it later when you have time)
* Water in the site glass should come up at least half way in the glass tube. But not completely to the top and out of site! (filled) then the water level probe or float is not working and you will have water leaking from anti-vacuum valve and/or safety valve. Check float/probe system.
* No water to groups are another problem. The only common connection to tank and groups are at the water inlet fitting. it splits into several directions from that point. Tank fill, Hot water, Temperate steam port, and each individual group (I.E. 4 groups splits 4 ways)
* Many units have additional water treatment options that may be clogged or restricted (or turned off) check your "Manual fill leaver" if the lever works or has been cut off. Some have manual valve shut off for testing etc. It's usually under the drain tray or somewhere accessible.
* Changing the site glass requires work on the fittings that connect directly to the tank. I usually drain and clean out the tank at this point as the machine is completely disassemble to get at these parts. Good idea to check inside the tank for crud build up. Removing fittings will break off calcium deposits which will clog up other parts and valves up the line.
* Identify and locate the clog in each system. You will find that once a machine starts to calcify then it will spread all throughout the unit. Complete disassembly and cleaning will be required (lots of work and time) strongly suggest looking for a new replacement machine.
*** Do Not use ACID to clear clogs. This includes Vinegar as it's and acid! ***
Aloha, ukeboy57 (youtube)
Jan 17, 2018 | Coffee Makers & Espresso Machines
There is a leak that is bad enough the coolant tank drains within minutes im wondering if it could be a hose because it drains in the middle though closer to the opposite side of the car
If it's a hose, it will leak fast, but don't count out other things like the radiator, water pump, head gasket, etc.
fill the system up with antifreeze and water or just water for diagnosis purposes, and use a pressure tester to force fluid out faster.
Maybe, if the leak is fast, you can look under the car to see exactly where it is coming from.
You say middle and opposite side of car (is this as you're sitting in the driver's seat?).
Where is the leak, now?
Jul 04, 2010 | Cars & Trucks
My pump comes on and presurizes about every 20 to 30 minutes, when there is not water being used in the house. If I shut the valve off from the pump to the storage tank the tank will stay presurized and...
When you hear water running, it is usually in a drain. You probably would have noticed a leaking faucet, so it's probably a toilet. Try shutting off the supply pipe to any toilet you suspect and see if that stops the pump. Then you have to fix the toilet.
I hope this helps. Thanks for using FixYa, and good luck.
Al K
Mar 24, 2010 | Tetra Plumbing
I was given a new light blue Gaggia 'Francis Francis' machine ten years ago. I used it pretty regularly, then put it away during several house moves . I'm trying to get it working again now, after 5...
valve in group head seized. remove 'shower' under group head with central screw remove internal spring loaded jet clean and re-install. Then run a de-scale.
Sep 19, 2009 | Coffee Makers & Espresso Machines
Water wont flow past brew head
Hi there, it sounds like your boiler may be full of scale. There is a copper tube which runs from the group up inside the boiler which can get clogged up quite easily. When you take the group apart you will see that when you remove the shower plate and unscrew the bolt in the middle the safety valve and spring will pop out and then if you get a pipe cleaner or something similar and ram it up through the copper pipe. If this does not work then you may have to dimantle the boiler and give it a good clean out. Also although you say the pump is primed it could still be broken. All these problems usually come from scale though. If you get some descaler and try to feed into the boiler by pumping or running water out the steam wand this may free it up. Any further assistance please get in touch with David at coffeeservice@live.com
I am a domestic coffee machine engineer and have machines of all makes sent to me from all over the UK daily. I specialise in La Pavoni, Gaggia, Elektra, Francis Francis etc. You can get in touch with confidence.
All the best
David
The Domestic Coffee Service.
Jul 06, 2009 | Gaggia Classic Espresso Machine
I have a leaky Francis Francis X5 Espresso machine which loses water as it heats up. Brews OK as long as grind is not too fine, but if grind is fine I get a leak and loss of pressure from inside the group...
The pump bypass(expansion valve) is opening if the pressure is too high(as with the fine grind), I haven't seen one of those machines, so I will assume that it is setup as the rest of the manual espresso machines, first thing to do is backwash the machine(note not back flush), I will attach an easy wash description.
Check the pump line to the group, on one side there is a discharge that goes to the drain tray make sure that it is not damaged(on some models the expansion valve spring gets tangled).8ab7618.jpg
Jun 11, 2009 | FrancisFrancis! X5 Espresso Machine
When I pull the lever to make an espresso it takes about 10 seconds for water to come out. It's as though all the water in the boiler (or heat exchanger?) drains out when I dont use the machine for about...
Tank fills automatically with level electrode on top of boiler. Same punp that brews your coffee will top up the tank. Electrode full of scale - no water in tank. The boppom of group has drain exit. Fully normal to have a bit water to drain out. tale apart and clean manually! Nothing to be afraid of. take photos as it can get tricky to get all pcs back after mayor overhaul. Larger commercial machines have the drain outlet covered behind a vertical wall. You don't see the water but the E61 group is identical!! ///Olev
Nov 01, 2008 | ECM Giotto Espresso Machine
Francis Francis X1
Some leaking from the group head of the machine is totally normal while the machine is heating. The reason for this is that the valve that sits above the shower screen is simply a spring and rubber ball. The spring expands, creating a seal with the rubber ball and the boiler, once the boiler reaches a specific temperature. Until the boiler temp is reached, leaking from the group head will occur.
Feb 26, 2008 | FrancisFrancis! X1 - Stainless Steel...
FrancisFrancis! X1 - Stainless Steel Espresso Machine Logo
421 people viewed this question
Top FrancisFrancis! Coffee Makers & Espresso Machines Experts
dharmanos
Level 1 Expert
Joe Lalumia aka...
Joe Lalumia aka...
Are you a FrancisFrancis! Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
