Question about Garden
My stihl weedeater will not stop when i turn the switch off... why? thanks, victor
  • 59 Answers
Make sure the black wire is ground and the other wire is plugged in
Posted on Jun 27, 2009
Does a stihl weedeaters have primary & secondary windings in their coils ?
which model.?? I have all the parts manuals so will gladly help with a little more info
Apr 22, 2016 | Stihl Garden
Need a new Stop Switch
You might be able to obtain a replacement switch directly from Stihl
May 06, 2013 | Stihl Hs 60, 61 Hedge Trimmer Stop Slide...
Stihl fs44 weedeater wont fire
Do you have compression, a good spark and is fuel going into the cylinder.? Working on a solution.
Jul 27, 2012 | Stihl Garden
Stihl sf44 weedeater wont fire
more info please? does it now have a spark and good compression?
Can't start new stihl weedeater fs 45
The Stihl FS45 has a particular way of getting started as do all the stihl products. We sell Stihl equipment in our store and service and repair them also. The normal starting procedure is to:
Be sure the switch is turned to the ON position which is the negitive sign (-). The (O) is the off position.
Press the primer bulb 3 times.
Move the choke lever to on.
Pull the starter cord three times only. If the engine fires, turn the choke to the off position and pull till it starts.
If the engine did not try to start during the first three pulls with the choke on, you must turn the choke off and pull till it starts.
Remember:Pulling more than three times with the choke switch on will flood the carburator on every stihl product thats on the market.
However, if the units still refuses to start, being its new and still under warrenty, return it to the repair shop that services Stihl products and they will repair it according to warrenty. All parts and labor should be honored at no cost to you. Please provide your receipt and serial number located on a silver tag located on the unit or the mechanic will get it off the unit when he works on it. Either way, it will most likely have to have a new carburator put on it. I hope this helps. Please comment back if this was helpful. Thanks; George
Mar 17, 2012 | Weedeater Garden
I need to know the preset adjustment on the low and high idle on a stihl weedeater (ex. 1 1/4 turns)
all 2 cycle weedeater type carb diaphram presets / initial settings are 1.5 turns after a gentle close. You will of course have to dial them in after the initial start.. (1 and 2 screw types)
Jan 22, 2010 | Garden
Stihl weedeater starts but won't run at high speed
This sounds like a timing problem.
It is too far retarded, and needs advancing a couple of thou.
There you go:)
Jul 25, 2009 | Garden
Stihl weed eater runs 2min. then stop
Stihl weedeater was running and stopped suddenly. Put in a new fuel filter and cleaner air filter with soap and water. Checked spark plug and it appeared fine. Started the weedeater, ran for a second or so and stopped. Spark plug wasn't gas fouled. Could it be the carburetor needing new diaphram gasket and spring.
Apr 23, 2009 | Ryobi Garden
Garden Logo
326 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
