Question about Black & Decker Black and Decker & Grass Hog Electric Trimmer
My black & decker no bump trimmer no longer feeds automatically
Don't know if I don't have enough string on the spool or if there's a problem with the automatic feeding mechanism. Was working fine when the spool was fully loaded but now that I'm down to only a few yards of string it won't feed. Can not enough string cause this problem?
4 Suggested Answers
  • 133 Answers
SOURCE: B & D auto feed string trimmer won't advance string
Is the string spool seated on the rachet correctly? If so and all is well, it is worth noting that these trimmers auto feed fuunction is problematic at best, requiring manually unwinding some line every few minutes as the unit gets older.
Posted on Apr 21, 2010
  • 3 Answers
SOURCE: Black & Decker Grass Hog Electric Trimmer
How do you replace the white lever, and how do you know if it is broken?
Posted on Jul 14, 2008
SOURCE: auto feed spool doesn't work
10 to 1 yours is doing what mine is, line comes out all over... I think there is a little spocket on the center shaft under the spool... When I replaced line I lost this part and know one shows this as a part on there web sites... I don't know what to do??????
Posted on Oct 13, 2008
The nylon thread has worn down. How do I get more of it to come off the spool which is still full?
Hi cmlontg152...
You will have the grass hog running and then bump the turning head on the ground and it will automatically feed out the line, the more you bump it on the ground the longer the line will be...don't make it too long at a time...only what you need.
Please take time to rate me
Jul 08, 2011 | Black & Decker 14" Grass Hog Xp...
How do you advance the string
These little electric machines have an automatic line feeding system. Do not bump the trimmer head on the ground attempting to make line advance. If the line advance is not functioning like it should, then the string head should be removed and the spool inspected for snags and tangles.
Sep 25, 2010 | Black & Decker String Trimmer Cordless 12"...
I properly replaced the line spool but it won't feed automatically.
After you replaced your string in the trimmer and fed it through the hole in the plastic casing in which the spool fits into, did you pull the string until you hear a click? The click locks the string in, then you can bump and feed as usual. Otherwise it won't feed normally.
Aug 13, 2010 | Black & Decker Grasshog 12 Inch 18 Volt...
String on weed wacker does not automatically advance.
the notice on the trimmer says it has an AFS Automatic Feed Spool, "NO BUMPING REQUIRED". I see that underneath the spool, there's a small plastic centrifugal weightwith a peg on it. . It kinda looks like it might advance the line each time the electric motor starts and stops. If there are loose clippings in there, or if the weight is stuck, it probably would cause the problem.
Apr 21, 2010 | Black & Decker String Trimmer Cordless 12"...
Apr 21, 2010 | Black & Decker 14" Grass Hog Xp...
String won't advance automatically. Thank you so much for any assistance! It's a Black & Decker ST 7000 edger/trimmer.
There is a rachet mechanism at the bottom of the spool. make sure the spool is seated fully. Also make sure the string isn't wound too tight or it will stick and not advance.
Apr 06, 2010 | Black & Decker St7000 13'' Automatic Feed...
Spool is stuck
Have you tried using vise grips to get it off. Next time put neverseize on it.
Jul 18, 2009 | Craftsman 25cc Gas Line Trimmer
Auto feed spool doesn't work
You may need to purchase a new spool housing, which may not be too hard to do, if you have one of the name brand trimmers. This replaces the whole mechanism that holds the line, the retaining ring, etc.
Sep 21, 2008 | Black & Decker Black and Decker & Grass...
I am trying to spool trimming line into my black and decker GH1000. It is supposed to feed automatically. It is not. I'm afraid I fed the line onto the spool incorrectly. Need help
Yes, it does feed automatically.
Please make sure the trimming line spooled in your spool regularly.
If above does not work, please go to service center to change a lever inside spool housing.
Aug 29, 2008 | Black & Decker String Trimmer Cordless 12"...
Black & Decker Black and Decker & Grass Hog Electric Trimmer  Logo
239 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
