Question about Whirlpool Duet GHW9150P Front Load Washer
Rubber door seal rip...
I found a rip in the door seal on my washer. Has anyone else had this problem?? I am just wondering how deep of a hole this will burn in my pocket...thanks!
  • 3 more comments
  • apoepping Nov 06, 2007
    I also wanted to add that I CAN do little loads of laundry without it leaking...its just when I do a larger load that it leaks from the rip..
  • apoepping Nov 07, 2007
    I think we are going to order the part and try to fix this ourselves..so step by step instructions would be fabulous!! Thanks!
  • apoepping Nov 09, 2007
    We fixed it!! It really wasnt too hard, just labor intensive like you said. Thanks again for the instructions, it sure helped!!! Im calling the place where I bought the washer to let them know they shouldnt tell people to stuff the washer full of clothes..the washer obviously cant handle too much weight...Thanks again
    Angie and Tim
  • apoepping Mar 07, 2008
    Sorry I didnt even realize a rating was left, but if i left that i didnt mean to!! Your instructions were great, washer is still working!! Thanks again;0
  • Lizzih Mar 09, 2008
    I have the exact same problem...it leaks horrible when it's filled with a medium or large load.
    Somehow we are going to have to replace this ourself since I'm sure labor is going to be expensive.
  • 5,911 Answers
The rubber door boot (bellow) commonly wears out on these front loaders. A replacement will run you about $80 just for the bellow. Labor could run as high as $180 if you decide to hire someone to replace it for you. If you wish to perform the repairs yourself, post back with your intentions and I can provide you with step-by-step instructions on how to replace it. It is labor intensive as you will have to remove the entire washer front in order to do the job right. It IS possible, however, if you wish to pursue a repair option on your own. Just let me know.
PS I can also provide you with the part number if you reply with your washer model number (found along the door opening).
Posted on Nov 06, 2007
  • 2 more comments
  • Jeff Rockwell
    Jeff Rockwell Nov 07, 2007
    Okay...here ya go:
    1. Unplug the washer.
    2. Remove the washer top panel by removing the three torx-type screws (or 7mm) where it attaches in the rear of the washer. The panel should slide back, then lift off.
    3. Remove the operator console by removing the dispenser and the scew(s) behind it. Take a putty knife and insert it under the console seam right above the door. If you push in slightly while pulling outwards the panel pops off. Use care not to pull or damage any of the wiring. You can leave the wires attached and simply lay the console across the top of the washer out of the way.
    4. Locate the wire hoop retainer around the rubber door boot. It is located behind the rubber seam where it attaches to the door frame. Follow this hoop around to the bottom of the door opening and locate the wire tension spring. Gently pry this spring apart and pull the wire hoop from the groove. Pull the rubber boot from the frame and push it inside towards the wash tub. You will also have to remove the door boot from the fill tube on the left hand side of the door opening. There is a small wire clamp holding it in place.
    5. Remove the three screws that hold the door latch assembly in place. This is on the right hand side of the door opening. You can leave the latch in place as long as you remove the screws and push it inside slightly to remove it from the front casing of the washer.
    6. Remove the door by removing the screws holding the hinges in place. Use care to support the door hinges when loosening. They can bend. Set the door aside in a location where it will not get stepped on or broken.
    7. Remove the lower kick panel under the door. There are 3 screws under the bottom edge holding it in place. Sometimes the panel can stick. A slight tap on either side will knock it free.
    8. Remove the front washer casing by removing the four remaining screws that are holding it in place. There should be two at the top and two at the bottom. Set the front casing aside.
    9. Remove the old door boot by locating the large clamp that attaches it to the wash tub. Loosen the 7mm nut and the boot will dettach from the tub.
    10. Install new door boot on the wash tub and install clamp. There should be instructions that come with the door boot with guide marks to ensure you align it correctly. Once you have the boot in place, tighten the clamp enough to where it is snug. DO NOT over-tighten or you may damage the tub and or clamp. In most cases the clamp will break.
    11. Once you have the boot in place, re-install everything in the reverse order of how I explained to disassemble. Make sure you connect the door latch assembly BEFORE you re-install the outer portion of the door boot. Also, make sure you install the boot completely over the fill tube. Sometimes the tube is not inserted all way into the boot and water will leak behind it. If you cannot get the clamp to go back over the tube, you can live without it. Some newer models do not have them installed. Just make sure it is a snug fit where the rubber boot fits ALL the way back to the plastic ridge on the tube.
    12. When you get the point where you are ready to install the door boot back over the frame of the door opening ensure you fit it snugly all the way around the door. Then, beginning at the top start inserting the wire hoop back into the groove. Make sure to wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place. It would be adviseable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
    13. Once the door boot is back in place, re-install the operator console and washer top.
    14. At the operator console, select DRAIN SPIN, NO SPIN and press any button under OPTIONS 4 times (has to be the same button, though). This will place the washer in diagnostics mode. You should hear the door latch lock and "C00" will be displayed on the console. The washer will run through a series of tests filling the tub, tumbling, draining, then a final spin. If you do not wish to wait for the test to complete you can press CANCEL at any time. The test checks out everything and takes about 15 minutes. Look for any leaks.
    I hope you find these instructions helpful. Let me know if you have any further/questions and concerns. Good Luck to you.
  • Jeff Rockwell
    Do you still need a part number? If so, give me your washer model number (located inside the door opening) and I can find it for you.
  • Jeff Rockwell
    Jeff Rockwell Mar 06, 2008
    If it fixed the problem why the "Thanks for Trying" rating?
  • dhentschel
    dhentschel Dec 27, 2012
    Our Kenmore Washer #41744102301 has a tear in the lip on the very front of the boot. It does not go all the way through but allows water to leak between the door & the front of the washer. Can this small tear be retaired some way?
The inside rubber ring has 2 rips in it! how could that happen and can it be replaced? Also can i still do a load of wash with the rip in it?
If you're referring to the gray rubber door seal (bellow), it can be purchased and replaced. They do wear out from normal wear and tear and may require replacement from time to time. Overloading the washer is a major contributer in causing the seal to prematurely wear and cause it to fail. The following link gives you step-by-step instructions on how to replace a door bellow:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
Replacement parts can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites listed also inlcude helpful exploded view parts illustrations to assist you with locating and properly identifying any parts you may need. Prices will vary, so shop and compare.
NOTE: As a TEMPORARY fix (if you need to use the washer while awaiting parts and the holes are not too severe) you can use a good water proof tape, or inner tube repair patches to place over any existing holes.
If you require additional assistance, please post back and let me know. I hope this helps you
May 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Door seal leaks
Most commonly, the source of the leak comes from the door bellow (gray rubber seal). They do wear out with age and can develop small rips and tears. A routine inspection of the perimeter of the door seal can determine if you have any holes. If the seal is damaged, it must be replaced. The following link explains how:
Replacement parts (if required) can be purchased at any of the following web sites:
repairclinic.com
If no obvious rips or tears are found, it is also common for the bellow to stretch over time and no longer provide a good seal around the door glass. Make sure you check to see if the bellow is sealing properly all the way around the perimeter of the door.
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, or require additional assistance, please post back and let me know. I hope you find this information helpful.
Apr 18, 2011 | Whirlpool Duet GHW9150P Front Load Washer
We have water leaking out of the front of our washer not from the door but from just below the door. Is all over the floor??
most likely you have a hole in the boot seal,the rubber piece in between the door and the tub,also open the door and wipe the bottom part of the door on the plastic window,i've found pieces of hair there and the water travels down the hair and leaks through the door.if that's clean you have a hole in the boot seal,open the door,spread the rubber boot open and with you fingers feel all around the rubber boot
Jan 29, 2011 | Kenmore Elite 45986 Front Load Washer
Leaking water under drum area seems to leak more with larger load
Check the gray rubber seal by the door. Look all around, inside the folds, for a hole. (usually found on the right or left side) Replace door seal if hole found.
Jan 26, 2011 | LG WM-2277HW Front Load Washer
Leaking at each wash cycle
this sounds like the door seal has split,,,there not very pricy but a pain to fit,,,so here go's,,,
open the door,,look at the door seal pull it off the back of the door and you should fine a spring wire holding it there,,,undo this wire,,,now fold the seal into the washer over the inner drum,,,,there you will find the inner wire,,undo that wire and pull the seal out the washer door,,,,
to fit the new seal,,,turn the seal inside out and push it through the hole in the door then fit the inner wire on the inner drum first,,,unfold the seal and pull it through the door,,,now fit the outer wire,,,,not put the kettel on,,have a cup of tea take the pain killers for the head ache you just got,,, and think about how much money you just saved ????
now was it realy worth the trouble,,,i wonder? am i good or what?
Jul 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Maytag epic z-ripped piece of door seal
I would say that the rubber may have gone into the system, and is probably clogging up the water outlet hose, and or the Pump. This is a bit of a "Fix' it will require the taking off of the motor and Hoses, connected to see where that bit of rubber is.http://www.letsfixit.co.uk/html/washing_machine_faq.html
http://www.appliancerepair.net/apnet/frameset?http://www.appliancerepair.net/apnet/washer/toc.htm
If you do not choose to repair this yourself, using those links above. Then please get a "Quote" for repair.
Mar 24, 2010 | Maytag EPICz 3.7 cu. ft. Washer
Stackable Neptune Front Loader Washer Leak.
check that the door seals correctly on the rubber boot, check the boot for holes or rips, check the drain hose, tub to pump hose and pump.
Jul 08, 2009 | Maytag Neptune FAV6800AW Top Load Washer
BOSCH: How to replace rubber seal (boot) of front loading washer
remove soap draw take screw out lower right.
remove boottom panel screw in filter flap push to the right panel comes off undo 2 x screw,take front lip off door seal off 2 screw from door interlock then front panel will come off you will beable to whole seal and spring cilp
slightly longer but easy you can see what you are doing.
Jun 30, 2009 | Washing Machines
Washer is ripping my clothes
yep, I have that problem too. My son's winter coat got wripped to shreds.
Apr 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
KHWS01PWH0 Front Loading Automatic Washer Leaking
out the bottom of door?? no through the bottom panel???. check the rubber door seal for rips or tears pull it back and look around entire circumference. smalll rip in very front of seal where door should close against will cause leak for sure
Mar 07, 2008 | KitchenAid KHWS02RMT 3.7 Cu. Ft. Ensemble...
Whirlpool Duet GHW9150P Front Load Washer Logo
849 people viewed this question
Dan Webster
Dan Webster
Sal De
