Question about Microsoft Wireless Laser Mouse 6000 v2.0
Number key pad giving symbols rather than the numeric number
  • 484 Answers
If you haven't installed the software which goes with this wireless mouse, then it's time you did.
1 - First, remove the mouse and replace it wih a normal, wired mouse.
2 - Restart your PC
3 - Insert the CD or DVD which contains the Wireless mouse software, from Micosoft.
4 - If you don't have it, download it from www.microsoft.com/hardware - at this location, look for the software and download it.
5 - Install the wireless mouse software only and, when it tells you to do so, remove the wired mouse and replace it with the wireless mouse from Microsoft, along with the transceiver.
6 - Now, run the Microsoft software and choose the keys you want when you press certain buttons.
7 - As you get use to the software, you will also get used to the way the buttons work with the mouse's buttons and what they will do for you.
8 - When you have gotten used to what the buttons do, then you can start working alone, without the software.
9 - It will all become like second nature to you as you use it more and more.
Enjoy!
Posted on Jun 26, 2009
The numeric key pad on my keyboard does not work
There's usually a Numlock key that turns off the cursor movement and turns on the numeric keys. If it doesn't say "Num Lock" or something similar, you might need to press the Fn key with the F1-F12 key that looks like a numeric keypad. Pressing the Shift key while pressing a number on the numeric keypad should give a number output if the Num Lock is turned off, the cursor movement if Num Lock is on.
Jan 25, 2018 | The Computers & Internet
How can type (Alt+0225 = a with accent in spanish) or any keystrokes, (no numbers in the rigth keyboard)
See this page on how to enter the symbols you want in Spanish, directly from the keyboard, using the numeric pad.
Windows Alt Key Numeric Codes
Mar 19, 2015 | Computers & Internet
On a HP pavilion dm4, How do I use the number lock, or basically I just want to add symbols in a word doc using alt 153 ( for example). It doesnt work... Help please
If you have a desktop or a keyboard with the numeric pad, you can enter characters (accented) with an ALT key combination. If on the other hand you have a laptop and no numeric key pad, there should be an Fn key sequence (maybe Fn+F10) that locks the keyboard on the overlaid numeric pad. Better still, display the characters table and pop it open whenever you need a special character.
May 23, 2012 | HP Computers & Internet
Numeric key pad on right wont work on aspire 7741 notebook
Maybe you need to press the Num lk (number lock) key at the top of the keyboard, then Press and Hold the FN function key at the lower left portion of the keyboard then hit the number key you want..
May 06, 2012 | Acer Aspire 7741z
Number pad does not work
  1. Find Alt code.
    Numeric Alt codes for symbols are listed in Alt codes list. Check for Alt code of symbol you want to input.
  2. Enable Num Lk.
    You may need to simultaneously press ["FN" and "Scr Lk"] keys. That's the combination for "Num Lock" on some laptops. Look at the picture - the "Num Lk"/"Scr Lk" button is highlighted there.
  3. Hold down "Alt" key.
    Some laptops require you to hold both "Alt" and "FN" keys.
  4. Input Alt code of symbol on Keypad.
    Do this while holding "Alt" button pressed. Type Alt code on your laptop's numeric keypad. It's highlighted on the picture.
  5. Release all the keys.
    After you release all the keys alt symbol should be entered. If all this stuff didn't work - check if you have really enabled the "Num Lock" first. Remember that green indicator should shine near the lock symbol on your laptop's keyboard. If that wasn't the case - try simultaneously holding "FN" and "Alt" keys instead of just "Alt". That just might work.
Feb 15, 2012 | Toshiba Satellite P105-S9722 Notebook
Secret keypad letters in computer
hi
Click on a text box or open a text document.
  • 2 Press the "Num Lock" key to activate your keyboard's numeric keypad.
  • 3 Press and hold the "Alt" key.
  • 4 Enter the numeric code on the number pad. Press "1" to create a "smiley face." Display a musical note by pressing "14". To make a heart symbol, press "3".
  • 5 Release the "Alt" key after entering each numeric code. The symbol will appear.
  • Jan 15, 2011 | Computers & Internet
    Some keys register different characters. For example the O registers the number 6 when it is typed.
    This should be a simple fix, look at your keyboard, you should have a function key and if you look at the number pads above the top row of letters there should be either a numerical symbol or a key pad, your keyb board is simply using several keys as an extended numerical keypad. If you look closely at the letters there are small numbers on them. To fix hold down function key and pressing the keypad button. You can also try pressing the number lock.
    Al
    Aug 04, 2010 | Sony VAIO Notebook
    Where is the equal sign.
    Usually the = sign is substituted with the * sign on the number pad.This symbol is above number 9 on the right side number pad.
    Sep 15, 2009 | Targus USB Ultra Mini Keypad Keyboard...
    When entering degrees minutes and seconds (as per lat and long) into Turbocad .. what is the symbol you use for degrees?
    Hey there, this is easy. HOLD the ALT key down and with the ALT key held down type 0176 on the number pad. DO NOT use the numbers on the top row of your keyboard, it must be on the numeric pad.
    seth
    Jun 25, 2009 | IMSI TurboCAD Pro 15 Full Version for PC
    I need help in understanding the keyboard functions
    dear,
    what does it mean. do you want to know the hotkeys of just want to speed up your typing speed.
    if you mean is to speed up you typing speed. then use softwares like typing tutor etc. i used typing tutor 6. it is an old version but is simple too. now i can type very fastly.
    or if you want hotkeys then visit this links:
    http://users.sa.chariot.net.au/~kday/keyboardtips.html
    http://www.helpwithpcs.com/tipsandtricks/keyboard_shortcuts_microsoft_word.htm
    http://wiki.blender.org/index.php/Manual/Hotkeys/Hotkey_Keyboard_Map,
    the last one is impressive.
    regards,
    salman
    Jul 22, 2008 | Computers & Internet
    Microsoft Wireless Laser Mouse 6000 v2.0  Logo
    107 people viewed this question
    Top Microsoft Computers & Internet Experts
    micky dee
    Alun Cox
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
