Question about Kenmore 22942 Top Load Washer
Is there another name for the lid plunger?
My Kenmore washer will not drain or spin. I don't know what the technical term is for this part, but the 'lid plunger' (as was described in one person's question/answers) has the tip broken off.
The Sears site does not have any part listed as 'lid plunger', but they do
have one they call 'strike,lid'. It is listed at $10.72.
In the diagram, it appears to be in the same place as my part that is broken, but this seems to be a very high price to pay for such a small part, so believe that I am calling this part by the wrong name.
  • 15,935 Answers
It appears your lid switch/door latch has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
My washer does not spin or drain.
If the unit will agitate but not spin or drain I recommend checking the lid switch first. You should be able to hear the lid switch click as you slowly open & close the lid. If you don't hear a distinct click, replace the switch.
Here is the part you need.
Oct 13, 2012 | Kenmore 24032\24036 Top Load Washer
My kenmore stackable washer model 417.92702200 washes the cothes and drain but not spin. The clothes are very wet and smell burned when it try to spin.
This involves the spin lid switch.
You can tape the two wires to the switch together and it'll work just fine
Also check the plunger on the lid to see if it is not broken off
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Sep 05, 2010 | Washing Machines
Have to trip washer lid safety switch with something more substantial than little 'plunger' attached to the washer lid to get washer to drain and spin during rinse cycle. do i need to replace the safety...
removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet to replace it.
It comes as a complete unit and you can't replace just the plunger.
May 03, 2010 | Kenmore 23812 Top Load Washer
Washer fills up agitates then when it should drain ,nothing.motor dosent come on to pump water out.
In most cases all brands will fill and agitate with the lid open, but will not drain or spin with the lid up.
It sounds to me like your lid switch is either bad or misaligned.
The first thing to check is the actuator plunger on the lid. Make sure it hasn't fallen or been broken off. Look for a piece hanging down from the lid that looks like a little finger that when the lid is closed, would hit and depress the lid switch ,which is under the top of the washer.
If it looks like the actuator is good shape then the lid switch is either bad or misaligned. Take a pencil or a bic pen and depress the lid switch. Making sure your washer is plugged in and in the spin mode. If it begins to rotate to spin and drain then see if a screw has fallen out that holds it in place or became loose not letting the actuator hit it correctly.
If the switch does not seem loose and it will not start the machine when depressed with a pencil it is probably time to change it out.
Apr 09, 2010 | Kenmore 24032\24036 Top Load Washer
I have a Kenmore Washer that stops in the middle of the washing cycle. The water doesn't drain or anything. I have to take all of the clothes out and scoop out 90% of the water and than turn the washer to...
Hi
Thanks for using FixYa. Please check the belt and lid switch or a broken lid switch plunger. Also check the lid switch actuator and the timer. Please replace whichever is required to be replaced.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Sep 11, 2009 | Kenmore Washing Machines
My kenmore 90 series is agitating but not draining the water or spining
Check the lid switch. The lid switch will be located on the machine top where the lid closes. It may be a plunger on the lid that activates the switch or a white plastic flat piece where the lids sets. Either scenario can be checked by jumping out the lid switch. Disconnect the power. Lift the lid. Use alligator clips to connect the two terminals. Plug in the machine. Select spin. If, the machine operates you have a bad lid switch.
Jun 15, 2009 | Kenmore 23822 Top Load Washer
Won't spin
check your lid switch ...on the lid you see a little plunger this should go into a slot areound the rim of the washer and close a switch. you can try a small screwdriver to press it in while in the spin cycle..see if it works then if not the sw will have to be replaced as this needs to be closed (lid) before the unit will pump out and spin
Feb 23, 2008 | Kenmore 22422 Top Load Washer
Will not drain
Check that the drain house is clear from kinked or clogged. Good luck!
Aug 17, 2007 | Kenmore 22422 Top Load Washer
Kenmore 22942 Top Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
