Question about Kenmore 53642 / 53644 Side by Side Refrigerator
No ice, but water in door OK.
Hi, I have a Kenmore side by side model 10656532400. Manufactured 11/04, Water in door works, but unit will not make ice. I tried to mess with the diagnostics but didn't have much luck. Any ideas?
  • 46 Answers
Check to see if where the water comes into the ice maker is not froze does this one have a biult in filter if so this may need to be repced or fill valvebad
Posted on Jun 26, 2009
No ice or water
Check to see if the plastic water line was bent, kinked, or under the wheels. Check for water flow from the water-out line when UNATTACHED from the refrigerator to see if the pressure is enough to pass through the Filter. (you said it was OK). Last inlet valve must open to the filter and ice maker.
Apr 02, 2014 | Kenmore Refrigerators
I have a Kenmore side by side model # 106.53609202 and its about 8 years old. About a month ago it stopped making ice. I've already replaced the water valve behind the fridge and waited 24 hours and...
OK, remove the cover on the face of the ice maker and let me know if the model look like this picture:
12_17_2011_1_36_01_am.jpgIf it looks like this model, I have the service manual for it with all the testing procedures.If it doesn't, see if you can get a model number off the unit. They make about 4 different model for this unit.
Happy Holidays!Richard
Dec 17, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Model:106.56612500 side by side refrigerator ice maker not working .Possible water valve ,possible ice maker ,possible frozen water line .Ice maker is in the the freezer box not the door What is...
cheapest and up,, check for a frozen water line, defrost the entire unit, any of the components can be iced up, once defrosted,, if you still have a problem, then check the inlet valve ,
Jul 22, 2011 | Kenmore Side by Side Refrigerator
The ice maker is not working. The freezer
check the water valve located at the back/lower portion of the unit,get check for continuity, if your tester deflected to the right coil is ok, next, check for possible clogging, sometimes trapped dirts accumulates in the valve filter, it restricts the water going to the icemaker module.check your tap sir or flojet pump, if you are using bottled water.,
Mar 18, 2010 | Kenmore 52632 / 52634 / 52639 Side by Side...
Water and ice won't work on kenmore side by side fridge
I just resolved an issue with my kenmore elite side by side refrigerator icemaker (model 106).
It was expensive because I took the long road to fixing the unit myself.
My problem: No water going up to the freezer water dispenser into the icemaker but the water in front of the door working just fine.
-first thing i tried was the simplest. The Internet is clogged with this miracle fix of using a hair dryer to melt the frozen water line going to the dispenser output. This is highly unlikely for our model since the water line is protected within the refrigerator frame.
-2nd thing I replaced my water filter (thinking that there wasn't enough water pressure to trigger the solenoid valve. $40, and still no luck.
-3rd thing was I tested for voltage going to the solenoid. No voltage going to solenoid, so I wasted $30 for a new solenoid.....still no water.
-4th thing was I ordered a new IR sensor and receiver (since the reciever end is where the relay that sends the voltage to the solenoid to turn on and allow water to go up to the dispenser).
My IR sender and receiver appeared to be working flakey.
Installed, still no water. $58 BUCKS ON EBAY (EVERYWHERE ELSE $100+)
-I finally removed the freezer front little white door, I TURNED OFF THE FREEZER SWITCH SO NO VOLTAGE WAS PRESENT, removed the release latch underneath the freezer unit and disconnected, and removed the freezer unit to inspect it further.
When I removed the protective white cover that covers the mechanical wheel, I had a few parts come flying out of it. Turns out that the wheel accessories were damaged. THERE ARE NO REPAIRABLE PARTS ON THE FREEZER UNIT. I FOUND ONE ON EBAY FOR $39 BUCKS + $9 SHIPPING! $48 BUCKS, SWAPPED THE HARNESS AND BOTTOM COVER, AND IN 20 MINUTES, I WAS BACK IN BUSINESS. STARTED MAKING ICE IN ABOUT A HALF HOUR!!!!!
when in doubt, replace the freezer unit for $48 bucks! 7 out of 10 times it will fix your problems. All techs replace the IR set at the same time too which will set you back another $58 bucks.
Good luck! ;)
Mar 13, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker problems
hi thanks for the question when you switched the wires around you checked the valves . tey are ok is the arm in the ice maker down check that if that's ok then the problem is with ice maker thanks for the question the appliance doc
Sep 23, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice maker not working, water not going in tray.
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
iuoiout
Mar 28, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
I recently had trouble with both my water dispenser and my ice maker. I determined that my filter was clogged, so I replaced it. That fixed the water dispenser but the ice maker still wasn't working. I investigated further and found that the water inlet tube was frozen solid. Aparently, when the filter was clogged the water came in so slowly that it froze before it got to the icetray. I tried pouring hot water over the inlet tube to melt it and it mostly worked, but there was still some ice in the tube further back where I couldn't reach. Finally I defrosted the freezer so all the ice could melt and turned it back on and now it works great! Hope this might help.
Dec 17, 2007 | Kenmore 21.7 cu. ft. Side-by-Side...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
324 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
