Question about Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television
DLP TV: Left half normal, vertical 6" band center is gray, right half almost black. What's wrong?
Left half of screen projects normally. About a 6" gray band is in center vertically, and right half of screen is nearly black although picture is still visible. Problem began with 6" gray band restricted to right margin of screen, then darker band began as an equal width, and progressed toward mid screen.
  • Anonymous Nov 16, 2007
    I have a Gray band that goes from the top of the screen to the bottom of the screen on the right hand side. It is about 2-3 inches wide. I have heard this could be the light engine that costs around $1400.
  • Anonymous Mar 21, 2014
    Mitsubishi WD6628 Black on right side of the screen normal on Left side
  • 71 Answers
No. The optical engine is OK. You need an adjustment in the light tunel. Call a tech to do it.
Posted on Dec 10, 2007
I replaced a dlp chip in a mitsubishi tv. i now have a band 4" high with vertical bars in it, running across the screen. what is wrong?
Hello. I have replaced many DLP chips, as I work for a repair shop. I have seen similar symptoms when the chip isn't seated properly in the mount. There is a gray screw that should be loosened to remove the chip, and tightened when the new one is installed. Most importantly, you must make sure that the chip is seated flat in the socket before tightening the gray screw. Since you have done it once, you should have no problem correcting the issue! ??
Aug 06, 2016 | Mitsubishi WD Televison & Video
How do I fix my Samsung LN52A580 TV as the right half of the screen is totally black (even thought I get sound and picture on the left hand of the screen)?
Samsung HL-R6178W DLP TV half of screen goes black [Solved] - HDTV ...
www.tomsguide.com/forum/54431-4-samsung-r6178w-half-screen-black
Aug 28, 2013 - 36 posts - ‎24 authors
Samsung HL-R6178W DLP HDTV I just bought this tv used as is. Every once in a while, the right side of the screen goes black on all inputs. I have read ... As for the 1000 dollar price tag, that's totally bonkers. I found a web site ...Missing: ln52a580
HLR6768W - Right half of screen goes black - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI have a 4 year old 67" Samsung DLP which has worked pretty well other than having... Over the past 6 months it's developed a new behavior where the right half of the screen goes completely black and stays that way until I power cycle the tv.Missing: ln52a580
Samsung LN52A580 Vertical Line Problems - YouTube
? 0:32
https://www.youtube.com/watch?v=eejE6O340EY
Aug 22, 2011 - Uploaded by Jonathan Polis
Samsung LN52A580 Vertical Line Problems ... This feature is not available right now. ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical Lines, ... Sanyo LCD with DistortedHalf Picture Lines Waves Distortion Distorted ... Samsung DLP Green screen / lines Repair HLR XX67 Series ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
https://www.youtube.com/watch?v=dYHPKxijz1A
Jan 21, 2016 | Samsung LN52A580 52 in. HD-Ready LCD TV
Samsung LCD TV diagnosis. Possible tcon board?
T-con board is causing all your problems. You are correct. You can get parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 21, 2015 | Samsung Televison & Video
I have a 56" DLP Samsung (HLR5668W) Right side goes solid black
The color wheels will never fix an issue like that. The only things that will cause that issue is a bad DMD board which is part of the light engine or the digital board which is not. Freak Squad need to replace the digital board.
Sep 10, 2009 | Samsung HL-R5668W 56" HDTV
Samsung plasma HPR4272 that had a 4" black vertical line on
There are at least two issues here. First you have bad buffer boards. Second Very possibly a bad X-Main bd and P-Logic bds. Have a trained Samsung tech troubleshoot the set.
Jul 03, 2009 | Samsung SP-R4232 42 in. Plasma HDTV
Samsung HL-R4667 DLP There are about 6 vertical bands (usually all the same color) running top-to-bottom and within these vertical bands is a picture trying to come in. The screen behind the bands is...
needs a DM Board, prity easy to change yourself, if you order one, make sure you give them the version number off the Right side of the TV, will be somthing like SP01, To change - when you take the back off the tv, it will be on the left hand side, have to unplug 3 or 4 connectors, then take the plastic covering off, and it will slide out.
Jan 08, 2009 | Samsung HL-R4667W Rear Projection...
Half of screen blacks out
sounds like power supply caps or caps in the dm board
http://www.auctioncreations.com/wd62525a.JPG
The DM board is the one with the digital connectors on the back panel. If you already have it appart, you may as well check the caps on all of the boards. The caps that go bad are typically Jamicon brand caps in 1000 uF and 330 uF values. There are also a couple of 3300 uF caps in the PS that cause problems.
Mar 22, 2007 | Mitsubishi WD62628 62" Projection HDTV
Vertical Green/Purple Lines on lower half of screen
I would contact RCA if the repair center dosent know how to troubleshoot this set. But I bet its an eeprom or ground issue. Contact RCA here at 580-634-0151 or At https://www.rca.com/secure/service/contactrca/1,,,00.html Good Luck
Jun 15, 2006 | RCA Scenium HD65W20 65" Rear Projection...
Screen split with black bar through center, top of picture shows in bottom
It sounds as you desribe, the vertical output IC and or the b+ feed capacitor off the Hi voltage transformer feeding the vert. IC its required voltage. Not a really hard job to replace, but not for a handi person to do. This should be left to the professional, as there are no user serviceable parts inside this set and with the HI voltage and the safety issues its best to call somesone to assist you with this repair. Good Luck
Jun 14, 2006 | Sanyo DS31520 31" TV
Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television Logo
509 people viewed this question
Jerry Greenberg
Jerry Greenberg
