My dvd is playing only in black and white - Audio Players & Recorders
    President:
  • 1,114 Answers
Check your settings on the player in setup without a dvd in it and make sure the Video path is correct (component/composite/HDMI etc.) then check your cables if it's a stand alone player on both sides. If your connected to an AV receiver, check it's settings for video as well. More than likely it is a setting problem. If you still have an issue, post a comment listing all your equipment model #'s and cables used and I can help you troubleshoot some more.
Posted on Jun 26, 2009
3 Suggested Answers
SOURCE: DVD problem - now only plays in black and white
just checked by cables and that was it! Now have color back.
I have 321
Thanks a lot!
Dave
Posted on Nov 19, 2007
  • 3 Answers
SOURCE: when playing a dvd it black and white no color
I have had exactly this problem when changing TVs. Initially I had the sVideo out cable from the Bose with a scart plug on TV end - that worked fine on old TV. On new TV, first Samsung, second SOny, got Black and white video picture. To get it to work I used a component video cable - this is a short svideo cable with a an audio cable at the Bose end. It splits into a 3way R G B cable within 2- 3 inches at Bose end. I then plugged rgb extension cables into this and TV and worked perfectly.
I found the answer to this by errr...... reading the BOse doucumentation I reveived when I bought the lifestyle system 5 years ago :-)
Hope that this helps everyone else!
Peter
Posted on May 28, 2010
Dvd playing hooked up to an old t.v. plays in color when i hook it up to my lg tv it plays in black and white?
My DVD player only plays in black and white - TOSHIBA FORUMS
forums.toshiba.com/.../My-DVD-player...plays-in-black-and-white/.../47...
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
No Color When My DVD Player Is Hooked Up - Community ...
community.insigniaproducts.com/...DVD-Players/...Color...My-DVD-Pla...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
The picture from a disc player displays on the TV in black ...
Jan 17, 2016 | LG Televison & Video
Will only play DVDs in Black and White
Onkyo DV-CP706B 6-Disc DVD Player (Black) - Amazon.com
www.amazon.com/Onkyo...Player-Black/.../B001AMS...
Amazon.com, Inc.Color: BlackChange .... It's quieter than it was before, and it plays ALL DVDs, even if you can see some visible damage ..... THere was no color-just black & white.
Onkyo dvd player no color only black white Questions ...
www.fixya.com > Forum > Tags > dvd player no color only black white
Onkyo dvd player no color only black white related problems. Ask your Onkyo dvd player no color only black white questions. Get free help, advice & support ...
Onkyo dvd player plays black white Questions & Answer
Dec 29, 2015 | Onkyo Dr-s2.2 5.1 Dvd Home Theater...
Alba dvd/tv combo playing dvd's in black and white
There are a couple of things you could try with this. One, is to make sure that the video input is connected properly. The second would be to make sure that the DVD that played in black and white automatically changed your settings to PAL rather than NTSC
May 13, 2012 | Televison & Video
My dvd player only plays movies in black and white
my dvd player only plays movies back in black and white...not color. why?
Jan 21, 2010 | Cyberhome CH-DVD 300 DVD Player
My dvd player is playing in only black and white. I cannot figure out how to get it to play in color
I have the same problem.My dvd plays in Black And White.I found out A bulb in the tv burned out.The tv will still play color,but any dvd player will play in Black and White.The bulb is $130.00 to 230.00.Hope you have a warrenty like i doo.Thanks Hope ive helped.John from Riverside RI.
Nov 16, 2009 | Panasonic DVD-S35 DVD Player
VHS plays in colour and DVD plays in black and white.
there is a circuit in the color section to put the tv to black and white if the color subcarrier is missing from the broadcast signal.
it is called a color killer and needs to be adjusted.
it is for a technician to do.
it operates off the 3.58mhz color subcarrier.
Aug 18, 2009 | Jwin Electronics JD-VD138 DVD Player
Plays vhs tape in only black and white (no color).
my old series of ROOTS is playing in black and white and says on cover that they are in color
Jul 03, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
Dvd plays in black and White
There are a couple of things you could try with this. One, is to make sure that the video input is connected properly. The second would be to make sure that the DVD that played in black and white automatically changed your settings to PAL rather than NTSC.
Jul 06, 2008 | Apex Digital AD-1110W DVD Player
DVD'S Play only in black and white
In UK this occures when an NTSC picture is played from a DVD player to a TV which cannot enitrely hand NTSC format. Possible this will happen in the reverse for USA.
Also my TV cannot handle SVHS signals and also displays them in black and white.
Try changing settings on the DVD Player to Composite or RGB.
Regards
Mar 10, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
191 people viewed this question
 Grubhead
Grubhead
