Question about Canon MP610 Photo All-In-One Printer
Black text Printing using Photo Black
When printing black text-only documents on my Canon MP610, it is using the Photo Black, rather than the larger standard Black ink.
Is there a setting I need to change?
Go to your printer and faxes, which should show from the start menu. Double click on the Canon icon. Click on the word "printer" and select "properties." Under the "general" tab, select printing preferences. There you can choose gray scale printing which will use the black cartridge that is independent of the color. If you print mostly documents, etc., this is a good choice. You can always change back to color with the printing dialogue box that opens when you print from any program. Or to make a permanent change, go through the same steps you did to change to gray scale.
Posted on Jul 06, 2009
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 127 Answers
You should be able to set the cartridge it uses when you print, as something like 'Print only black'. Fish around in the printer window when it comes up when it comes up. You may also be able to set this as a default in 'Properties' from the 'Printers' option in Windows, but then it will always try to do this, of course, which you may not want.
Posted on Jun 27, 2009
Canon MP610 Printer
You cannot switch to the larger black cartridge. You are using a CMYK (Cyan, Yellow, Magenta, Black) format for printing color images.
The larger cartridge is used for text only. The smaller black cartridge is used for color or graphic images.
If the black cartridge was not present, every time you needed black in an image, it would have to come from the composition of Cyan, Magenta and Yellow. This would greatly reduce the life of the color cartridges.
Don
Dec 12, 2009 | Canon PIXMA MP610 InkJet Printer
I have run out of black ink in the large cartridge. Can I make the rpinter use the smaller cartridge to print black and white?
No, the larger cartridge is used for text printing only.
The smaller cartridge is used to add black to images instead of using the color ink to make a composite black.
Don
Oct 23, 2009 | Canon MP610 Photo All-In-One Printer
Printer always uses large black & runs out, cant isolate other
The BK5 is for black text only. The other black ink is used for shades of black/gray together with the three basic colors in printing color photos. You cannot use it to print black text.
Jul 29, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Black text printing not using large cartridge
Change your setting to plain paper and normal quality.
This printer uses the small black for photos and high qau;ity papers.
Do this and you should be good to go.
Jun 28, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
I have a Canon MP610 printer.The Test page prints ok.The copy fuction is perfect co;our and black and white.When printing from a file saved on computer the text has a sepia tone not black and white....
just chk the properties or the colour cobinations if you choose text for printing out than it will only print text and if it is too dark red that means it is connected with some wrong colour wire
Jun 11, 2009 | Canon MP610 Photo All-In-One Printer
Why two black ink cartridges?
The larger of the two cartridges is used for text only. The smaller is used for color printing. Its purpose is to eliminate the need for a "Processed" black (black being mader by the color inks).\
Don
May 30, 2009 | Canon MP610 Photo All-In-One Printer
Ink cartridge running low will it default small cartridge
It won't default to the small one...I emailed Canon support; this is the response I got.
The reason for the two different black ink tanks is for the different types of printing your unit is capable of. They are not intended as backups to each other. The larger black tank is pigment based, and is primarily used for standard black text printing or output. The smaller black ink tank is dye based like the color inks, and is used for photo and graphics output. They are designed to complement each other, allowing the printer to produce the best possible black text output or photo quality as appropriate.
Feb 25, 2009 | Canon PIXMA MP610 InkJet Printer
Canon pixma ip4600 black ink problem
The PGI-220 is the larger ink tank and is filled with standard black ink. The PGI-221 black cartridge is the photo black. There is no way to force the printer to use the photo black cartridge (skinny one) to print documents. The photo black cartridge is only used if you print a photo. I own a Cartridge World ink refilling shop and I can't refill these cartridges yet. There is no way to reset the ink level chip without a resetter and any replacement chips you find on the internet are technically violating patent law.
Jan 28, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
Black ink
The PGBK cartridge is a pigment black ink, while the others use a dye for coloration. The pigment black is used when printing text and other documents. The dye ink is used when printing photos and other colored documents. The dye black is used in conjunction with the color (dye) inks to provide tinting and color gradation, and therefore is not used nearly as much as the pigment black unless you use your printer only for printing photos.
If you're printing text and documents, you will need to buy another pigment black (PGBK) cartridge.
Oct 13, 2008 | Canon MP610 Photo All-In-One Printer
The black, print quality when printing a document on white paper, is not 100%
Few questions, are you running true Canon Inks and refills are always a off black not a true canon black!
Have you tried doing nozzel check, does the top black squares all come out ok? if so it could be down to the paper and the inks!
if you use 80gsm paper does it print ok?
Hope this helps
Sep 30, 2008 | Canon MP610 Photo All-In-One Printer
Canon MP610 Photo All-In-One Printer Logo
228 people viewed this question
old marine
old marine
