Question about Poulan Pro 22" Self Propelled High Wheel Mower
Continuously stalling and extreme difficulty restarting.
The lawn mower is very difficult to start; it takes several pulls to start. If the mower is level when mowing it will stall out and it can take several minutes of pulling the starter cord before it will restart. When I turn the mower off to empty the rear bagger I have an extremely difficult time getting the mower restarted. Some times it would take about 5-10 minutes to get the mower going again. The spark plug and filter have been replaced. The carburetor has been cleaned and the float seems to be working. The bottom cup under the carburetor has been cleaned. Any suggestions other than dynamite
  • jimmym47 Jun 27, 2009
    Thanks for all the help and explaining in detail what needs to be done.
    Problem Solver:
  • 5 Answers
The brass "Bolt" that holds the "cup" on the bottom of your carburetor is also the main fuel metering jet for the engine. Get yourself a can of automotive carb cleaner, the aerosol type that comes with the small red plastic tube on the side of the can. Remove the "Bolt" and "cup". (Tip: tilt the carb side of the mower UP about 45 degrees and support it with whatever you have, wood, bricks etc. This will help stem the flow of gas from the tank while you have the "cup" removed.) Examine the "Bolt" and you will see one or two small holes in the side of the "Bolt" between the hex head and the threads. These are the metering orifices. Use the carb cleaner to throughly clean the "Bolt" orifices. (Tip: DO NOT attempt to 'drill' the orifices clean) Next, use the red plastic tube to spray carb cleaner up through the hole on the carburetor that the "Bolt" screws into. Be liberal with the cleaner. Finally, clean the "cup" with the spray one more time for good measure. Put everything back together. (Tip: easy does it on tightining the "Bolt") Level the mower, check for leaks and verify the oil level is OK. If the plug and air filter are up to snuff you should be good to go. (Tip: how old is your fuel? You should keep it around for only about 30 days unless you use fuel stabilizer. These little engines LOVE fresh fuel) Good Luck.
Posted on Jun 27, 2009
Lawn Boy. why does it stall every min or 2 then restart easily?
sounds like it might be starving for fuel check carb to see if it has clogg
Jun 11, 2015 | Garden
Changed blade belt on husqvarna cth194 had difficulty restarting engine but got it going. When blades engaged going uphill lawnmower starts to struggle and threatens to cut out. this is a two month old...
I do not think this is a belt issue, i had some problems like this, it turned out to be a fuel issue, with the fuel tank completley full it was ok, as the fuel level became lower the mower stalled, the problem was the fuel tank did not have enough fall for gravity to allow the fuel into the carb, we ended up fitting an electric fuel pump.
Aug 10, 2013 | Husqvarna Garden
Lawn-Boy 20" mower stalls when hot and blade clutch engaged
probably the valves have unseated the hotter it run the worser it get warranty defect take to dealer tell what it doing tell him you think its un seated valves and cover under warranty
May 20, 2012 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Lawn mower won't start with out being jump started . Changed battery. After jump starting mower and while mowing engine stalls while mower deck engaged . If mower deck is shut off before it looses...
HI jLAFORCE 1.
Other possible causes include: Loose, Dirty or Disconnected Spark Plug in Your Lawn Mower: Check it out, clean off debris, re-connect and tighten. Fuel Not Reaching the Engine: Tap the side of the carburetor to help the flow of gas. If this doesn't work, you might need a new fuel filter.
Top 5 Mower Troubleshooting Tips ' Briggs & Stratton
https://www.briggsandstratton.com/eu/en.../top-5-mower-troubleshooting-tips.html
Lawn mower won start Google Search
Nov 30, 2017 | Simplicity Vacuums
Lawn mowewr wont restart
Check the gas cap. Loosen it a bit and try again. There is a vent built into it the hole on top plugs up ans stops the fuel flow.
Eric
Jun 24, 2009 | Toro Lawn Mower With Toro Power Tools
Loud screech noise from deck area
This can be due to a belt slipping or a bad spindle bearing.
And on the difficulty scale,10 being extremely difficult, The belt would be a 1 or 2 and the spindle about 6 or 7 (because the deck usually needs removed for this job)
Apr 04, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Poulan Pro 22" Self Propelled High Wheel Mower Logo
385 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
