Question about Nokia 6600
Rec tuning error in nokia 6600
Some times i have received one error in my mobile screen.
App. closed.
Rec Tuning
and only OK option is there.
  • 45 Answers
Re: Rec tuning error in nokia 6600
Please do the hand format by pressing *3 callbutton,ON button at the same time.the display will show FORMATTING .After completion use it.(note: you will lose all datas so save the datas and do it)
Posted on Nov 07, 2007
0 characters
3 Points
Mp3 tune player Free MP3 Player Nokia 6600 Slide Java Apps to your mobile phone via WAP or PC. Send MP3 Player Free Nokia 6600 Slide Java Apps to your cell ...
Jun 01, 2012 | Nokia 6600
How to bar a particular contact in nokia 6600.tell me any software which can block a particular caller.
Go to following website.
you can download the application by pressing Download App button on right side.
This software can help you filter your calls.
May 03, 2011 | Nokia 6600
Nokia 6600 white screen problem
hello,the screen is faulty from the problem you posted above,this can equally be fixed.all you need to do is to get another screen to replace the faulty one.
I will suggest you take it to a mobile phone engineer to help you fix it,and this will make your screen come back to normal as it was.
Take care.
Apr 10, 2010 | Nokia 6600
Nokia 6600 problem
deactivate msg alert tone off. urs suresh9848417656
Jan 01, 2009 | Nokia 6600
I am using the handset of Nokia 6600 and facing a problem. my handset infected by the virus named by (Commwarrior).By this virus bluetooth is working as all time hidden ON and handset is working very slow. Please tell me how can i solve this problem?
Aug 10, 2008 | Nokia 6600
Display problem
i also have the same problem...white screen display
May 26, 2008 | Nokia N70 Cellular Phone
There might be a problem either with the program you are using or with nokia 6600 .if you are using facing problem with program try to reinstall that file,but if you think that your mobile is having problem than you can format your mobile or flash your mobile .When you flash your mobile ,it will become new as you you purchased means factory settings....
A. Blank screen phone unable to boot-up. B. Phone is only able to boot-up to “Nokia” screen (may flash “Nokia” 4 times also).
C. Install a program but unable to uninstall it.
D. Unable to delete certain files on C drive. WARNING: This will ERASE EVERYTHING on your phone
If you have any files that are important to you, make backups.
1. Make sure you phone is fully charged.
2. Backup your contacts list and personal files to MMC memory card (if possible).
3. Switch-off your 6600 phone.
4. Press and hold these three keys together
-Green dial key,
-Star key (*)
-Three key (3)
then press the power on/off to swtich on the 6600 phone.
DO NOT let go the three keys until you see the “formatting” screen displayed
5. After a few minutes, the format will be complete. Your 6600 will now be at its original factory settings.Disclaimer: I will not be held responsible for anything that happens to your phone as a result of following my guide. Use this guide at your own discretion and risk.
If this answers your question please rate this as fixed.
If you need more help just add a comment and I'll be glad to help you further... Thanks
dilipbagdi -
May 11, 2008 | Nokia 6600
Memory Card problem
try to format your memory card by your mobile. when it is formated in pc the mobile says the card is been corrupted. so format your mmc in your mobile itself
Dec 11, 2007 | Nokia 6600
Temporary overload
    Ok u do one thing just remove the memory card from ur mobile & give a code * will do hard reset on ur before doing that just save ur cntcts & all as they all will be delted if they r in sim memory.
Oct 20, 2007 | Nokia 6600
Program error in nokia 6600
Dear. just make if simple flash.
Feb 03, 2007 | Nokia 6600
Nokia 6600 Logo
29 people viewed this question
Top Nokia Cell Phones Experts
IT Solution
IT Solution
