Question about Kenmore Refrigerators
The freezer works fine, but the refregirator is
The freezer works fine, but the refrigerator is near room temperature.
  • 1 more comment
  • sellyeyw Jun 27, 2009
    Your solution seems to be right on. The fan works but it will take some time to remove all the ice. I may have questions later. Bill
    Hello mgprice
    The fan runs and the heater measures 35 ohms, so I think it is OK. The thermostat has no connectors and I would not know how to test it anyway. So I'm going to try to get a replacement. Do you know where I could order one over the internet?
    Somewhere in the refrigerator there must be a circuit or circuit board that controls it. It seems possible that there is something wrong with this board and thus I will also need to replace this. Where would this board be located in the frig? Do you know where I could get this board or whatever is used to control the refrigerators functions? Is there a wiring diagram or schematic available from somwhere?
    Bill
  • sellyeyw Jun 29, 2009
    Excellent help. Thank You Mike.
    I have been running the frig all weekend and just puled the cover off the cooling tube. There is no frost or ice build up.However I will buy a replacement thermostat to have it on hand when it stops working again. Bill
    President:
  • 744 Answers
Hi, With the information you supplied i'm going to assume there is an ice build up at the rear of the freezer. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself. This is going to be one of three problems with your refridgerator, 1st thing to do is remove shelfs and panel in the back of the freezer...you should see ice build up on the evaporator...don't worry get a hair dryer and melt the ice. Next locate the wires for the heater...using a multi meter test the heater for condinuity...if the heater is bad replace it, If the heater is good replace the defrost thermostat..the stat normally is a barrel looking part clipped onto the evaporator pipe. The last possible problem could be the evaporator fan, have you heard the fan running in the past few hours..if you are not sure pull the panel out to where you can see fan and watch it over an hour to see if it turns. I have included links with pictures of what the parts you need to check are: http://romulusappliance.com/manufacturers/maytag/refrigerators/575432.JPG defrost stat http://www.hotekalliance.com/UploadFiles/2008627111553382.jpg heaters http://www.applianceblog.com/archives/EvapMotor1018185.jpg evap fan. Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck!
Posted on Jun 26, 2009
  • 1 more comment
  • Mike Price
    Mike Price Jun 27, 2009
    ok bill, I will be here
  • Mike Price
    Hi bill, there is no need to change your main board if your Refridge even has one, You are going to need to change the defrost thermostat..you can get it at the following site...just enter the model number.
    http://www.repairclinic.com/appliance-pa...
    Your defrost stat should be wired in series with the heater...
    If you have any other questions feel free to comment again.
  • Mike Price
    Just wanted to mention the main boards normally retail around $200 which is why we dont want to jump in changing that...Trust me bill i have been doing this for years...change the defrost stat and you will be good to go. if you are unsure how to change it i will give you step by step.
    Mike
How can I get the refrigerator to cool (the freezer is working fine)?
Double check your refrigerator setting, it should be separate from the freezer. Check the vent is clean. If it is still not cooling, set freezer to warmer, turn off the unit, unplug, wait 3 minutes. Restart and see if the condenser starts
Jul 13, 2014 | Sub-Zero 650 / O Bottom Freezer...
The freezer is working fine but the refrigerator is at room temperature.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 16, 2011 | Maytag 19.8 Cu. Ft. Side-by-Side...
The fridge is not working (room temperature only) though the light is still on etc. The freezer is working fine, if a little too icy!
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 17, 2010 | Zanussi ZI918 / 12K Bottom Freezer...
Model# 596-63822200 Bottom Freezer Refrigerator. Makes loud noise around 15 seconds every 5 to 10 minutes. Temperature is warm in refregirator and freezer. Naomi
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 06, 2010 | Kenmore 62232 / 62234 / 62239 Bottom...
Fridge wook fine. Freezer is room temperature. Freezer dial at top temperature
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 05, 2010 | Maytag MTB1891AR Top Freezer Refrigerator
The refrigerator isn't getting cold
the refrigerator part isn't getting cold. it was working but now its just room temperature inside. the freezer part works fine.
Jul 03, 2009 | Whirlpool Refrigerators
Refrigerators Logo
282 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
