Question about Acer (ACERMOTHERBOARD)
Acer travelmate 230 won't boot
When I power on all I get is the drive light stays on, no fans power up no power light on laptop, no post nothing
  • simshazz Nov 23, 2007
    The battery still charges. When I try and power on the battery light flickers but very dull? If I pull the cpu and power up the cpu fan comes on. Any ideas?
  • 661 Answers
This sounds like it may be a Power controller problem, (circuit that controls battery charging etc...) To fix this the mainboard usually needs to be replaced, which will mean that you will have to send it to Acer to be "serviced".
Posted on Nov 18, 2007
My acer Travelmate 242lc will not power on
First think , has it been dropped, jarred, banged, get the idea? Does it continue to blink, the HDD? Do you see a "ghost image" in the monitor in a bright light? Do you here sounds? You say "nothing else happens", meaning the light stops blinking? Shut down, unplug, remove battery, plug in, try to boot noemally.
Nov 16, 2012 | Acer TravelMate 242LC Notebook
My acer laptop 5530 won't boot anymore. The fan starts up fo appr 4 seconds, the screen stays blank and nothing happens? I removed tre battery, unplugged the power, hold down the power button for 60...
I have the same problem. I connect the laptop to an external monitor and still have the same error.
I tried to change the hard disk, memory, processor, video card, but has the same problem.
Seeking a solution still and know that the problem is somewhere on the motherboard.
Apr 26, 2011 | Acer TravelMate 5530-5207 Notebook
I have an Acer 5670 Laptop, I replaced the HDD with a new SATA drive and when I powered up the laptop, the Video card fan starts, the CD drive cycles once, the drive light flashes 3 times, then it stops....
Sounds like it. Try taking out the hard drive, disconnect all usb devices and anything attached, and try to run POST again...Being a laptop, there is not a whole lot else you can do if it won't POST. YOu can try swapping in some different RAM that is known to be good also.
Jan 13, 2010 | Acer Aspire 5670 Notebook
Acer travelmate 8006lmi when turned on only the power light and dvd drive work nothing on the display and nothing if you connect an external monitor either
The graphic chip is dead. replace the motherboard or reflow the graphic chip. I am not fan of BGA reflow. The seldom last beyond 90days.
Good Luck
Nov 24, 2009 | Acer TravelMate 8006LMi Notebook
Blank Screen
HI there.
Try booting into safe mode by pressing F8 while the computer starts up.
If you can get it into safe mode perform a system restore.
If it won't boot into safe mode please post back.
Good luck and thanks for choosing FixYa!!
Jun 02, 2009 | Acer TravelMate 4230 Notebook
Acer travelmate 2350 wont boot or display
I have seen this on several ACER Laptops. It is always the Motherboard. Contact Acer repairs and order a new motherboard. IT will likely be about $200ish dollars. Then follow one of the guides on the web for taking your laptop apart and replace the board.
Feb 15, 2009 | Acer Computers & Internet
Acer will not start travelmate 4000 series
does it pass the BIOS tests ?! if so, than u have to boot with a bootable cd to install the OS (new hard drive)
if it does not pass the BIOS tests, or gives errors, try reseting the BIOS, set it to the default settings ...
u can also recheck all connections (cdrom, mems, hard ....) and if the batteries pins have a good connection when pluged in the laptop...
give more details of what is wrong with it ... does the screen even get a image on it ... !?
Jan 23, 2008 | Acer TravelMate 2300 Notebook
Help to repair ACER Travelmate 290LCi
this is normally motherboard or powe side problem check your motherboard
Oct 19, 2007 | Acer TravelMate 290LCi Notebook
Acer travelmate 4000 laptop Big problem
I guess I can assume that you have it plugged into the ac power, so you know its not a power problem. We also know its not a problem with the power switch since the light turns on. So that leaves, motherboard, cpu, and ram possible problems. Ram would unlikely cause such a hault. Even with no ram, I believe the computer would make horrible beeping noises. So if its a problem with the motherboard or cpu, its pretty much trash, unless you want to waste the money on ebay or some place for another cpu to try to swap.
Aug 23, 2007 | Acer TravelMate 2300 Notebook
Screen does not display(black) and machine won't boot
You can't do anything without memory, it will stop cos it can't find any.
Jan 25, 2007 | Acer TravelMate 517TE Notebook
Computers & Internet Logo
202 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
