Question about Dometic Rooftop RV Air Conditioner
REPPLACING FAN AND COMPRESSOR CAPACITORS WITH A SINGLE UNIT
I am replacing wo capacitors with a common unit. The, oblong, fan capacitor had two brown wires connected, one with a white line. The "run" capacitor has a fat black wire and a thn black wire. The thin black wire has a yellow wired connected to it. The fat black wire appears to be going to the compressor. My question is how do I connect the wires to the three-pronged capacitor?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 127 Answers
Well, it sounds as if you have a Coleman rooftop unit. If you have a start capacitor with a PTCR (Postive Temperature Coefficient Resistor) then it is different than if you have a Potential Motor Starting Relay. Why are you replacing the run and the fan capacitor?
Here is a link to the documentation that you need. If you do not have a Coleman and it is in fact a Duo-Therm, let me know the model number and I will be able to pull up the wiring schematic.
Thanks,
Jeff
Rate this please!!
Posted on Jul 04, 2009
Replace compacitor on Carrier 5 ton 3 phase AC
Your 3 phase unit should not have a capacitor. I'm guessing it's single phase. If it's a single capacitor than the compressor should not be going to it also. To test the motor, common to start plus common to run should equal the ohms you get between start and run. For instance, 1.2 ohms+ 2.2 ohms= 3.4 ohms. Follow the wiring diagram on the inside of the door, send model number!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Aug 29, 2017 | Carrier Heating & Cooling
Wiring- Connecting wiring on replaced fan motor
Your new fan motor should have a diagram with it or at least printed on the side of the motor, that will help a lot from your end. As for me, I don't know what unit you have, so I will try to help you with just the basics.
Your old motor probably had 3 wires. One went to the contactor, that is the "Line Voltage", one went to the Common terminal on the old capacitor (COM), that's the other "Line Voltage" wire, and the last one went to the "FAN" terminal on the old capacitor. The reason the old capacitor looks different is because it works for both the compressor and the fan motor (split capacitor). You still need this hooked up for the compressor to work.
The new fan motor.
These vary in brands and wiring so I can not tell you the colors without knowing exactly which motor you have. On the new motor wiring diagram, you should see the "Line Voltage" as described above that 2 of the wires are ran to each other (just on the diagram, not wired together on the unit). This is your power wire that goes to the contactor on the unit, usually black, and your Common wire that runs to the capacitor. You can still run this wire (COM) to the common terminal on the old capacitor since you still have to use the old capacitor for the compressor and the common terminal should still be jumper-ed from the contactor to the (COM) terminal. Then you will probably have 2 wires for the new capacitor, usually Brown and Brown/White. These wires run to each side of the new capacitor and doesn't matter which terminal. Then you will take a new jumper wire from the (COM) terminal on the old capacitor to the terminal on the new capacitor that has your Brown/White lead. Make sure you secure the capacitors inside the unit so not to touch anything surrounding them. Your new motor might also be a "Reversible" motor that has reversing wires also. Again, your new motor diagram can tell you how to hook these up. You have to have it spinning the right way, most of the time it is CCW (counter-clockwise).
I'm sorry I can't be any clearer on this, but without knowing the brands, models, etc, I'm in the dark. If you need any additional help, I would be glad to help! Good luck and hope you get to cooler days!
Jun 28, 2012 | Heating & Cooling
Can I replace 2 single capacitors on a A/C unit with 1 dual capacitor?
Yes. You will have the terminals HERM, FAN, and COM on the dual capacitor. You will take the wire that comes from the compressor to the Herm terminal, then there is a wire that comes off the contactor to the capacitor(s), that is the Com, you will run it straight from the contactor to the Com terminal. The fan motor will usually have two wires going to the capacitors, finding out which one is which can be difficult sometimes, but there are a few ways to tell. First, it usually has the fan motor wiring diagram on the side of the motor that tells you the colors and what they are. If that is not visible or accessible, then you can see if there are any brown wires. Those are usually the capacitor wires. Since I'm not sure of the model or brand of equipment you are working on, I cant say 100%. You will have up to 4 wires that come into the electrical panel. 3 wire motors are 1 Com, 1 Power. and 1 Cap. 4 wire motors add an extra Capacitor wire which can be eliminated when using a dual capacitor, but you have to know which wire it is. Commonly, there is a Brown wire and a Brown/White wire which you wire nut and insulate the Brown/White and just use the solid Brown. Process of elimination is used to find the Com on the fan. If you have found the capacitor wire, and found the Power wire, obviously the last wire is Com. When it's all over, you should have compressor on Herm, Common from the contactor on Com, Com from Fan on Com, and remaining wire on Fan.
Sorry it's jumbled a little, but without knowing what your working on, I can just give you the general basics. Hope this helps, if you have any questions, feel free to ask.
Jun 19, 2012 | Heating & Cooling
Unsure of capacitor terminations for ao smith condensing fan moto
Does the motor data plate say anything about the motor. You can hook up a motor like yours with 3 wires. First use an ohmmeter and check the resistance between the brown/white wire to the black then the yellow wire. The resistance between brown/white and one of the others should be pretty much 0 ohms. If not check between the brown wire and the black and the yellow. Which ever wire has 0 ohms with the brown/white wire is the common leg. You can put a wire nut on the brown/white, it will not be used. Next the brown should be for the start winding and the other wire left over will be the run winding. Then connect the common to L2. L1 will go to the run winding and one side of the capacitor and brown will go to the other side of the capacitor. I hope this isn't too confusing. Let me know if I need to explain it better.
Jun 09, 2010 | Heating & Cooling
Electrolux split AC 1.5 ton inside fan working.But out side compressor fan stops after two or three rotations.
The 2 most common issues are a freon leak or the outside unit fan start capacitor goes out. It's more likely a capacitor issue. They fail regularly, especially when it's hot out. I had a fan capacitor go out on one of my 3 units last year and it cost close to $300 for an AC company to come out and fix it. I watched them fix it and it's something that you can do yourself if you know what you're doing and are careful to hook it up right. I have three AC units and another capacitor went out this year and I found a kit with detailed instructions with pictures and phone support at hvacrepairkits.com. It saved me over $200 on the capacitor replacement.
Mar 21, 2010 | Heating & Cooling
EMERSON FAN MOTOR WHICH HAS A BLK WIRE PURPLE WIRE AND A BROWN WIRE WENT DEAD. SO I BOUGHT A NEW FAN EMERSON CAME WITH 4 WIRES BLK ,WHITH, BR AND BRW AND BRW WITH WHITE STRIPE. I WIRED IT BLK TO THE...
The two brown wires go to the fans capacitor. The capacitor should always be changed with the fan motor.
It sounds like your unit has a dual capacitor. One side for the fan and the other for the compressor. All you will be doing (After rewiring the compressor wires as they were originally.) is abandoning the fan side of the capacitor, and wiring your new capacitor to the brown and brown with stripe wires. It does not matter which terminals the brown wires go on.
Oct 11, 2009 | Dometic Rooftop RV Air Conditioner
The AC unit outside is running but the fan is not moving at all....The air coming into the house is not cold at all. Is the problem a bad capacitor? If so can I fix this myself? To be safe, will turning...
Could be a bad capacitor however, it could be a bad motor. (make sure you have disconnected the power from the unit ) The cheapest and quickest way to see is to get a capacitor and install Once the new capacitor has been installed if the fan doesn't activate then fan motor is also bad. The capacitor is a round or oblong and it is either silver or gray If it is a dual capacitor it will also connect to your compressor. There will be several wires coming out of it follow the brown or yellow wire from fan itself to the capacitor If it is a dual capacitor it will also have wires coming from the compressor to the capacitor. Make a diagram of the wire placement on the capacitor before removing to insure you place the correct wires back to the correct location. VERY IMPORTANT. Thiis capacitor will have voltage stored in it even though you have disconnected the power so make sure that nothing comes in contact with both prongs i.e. touching the prongs to metal together on th a/c unit while removing It will give you quite a jolt. Take the capacitor to an appliance warehouse for replacement to insure the proper capacitor is given to you. Hope this helps good luck on your repairs If I have helped you let me know
Dave
Sep 16, 2009 | Heating & Cooling
Rewire air conditioner controls
Assuming "Window Unit" with rotary switch.
L1 (smooth part of line cord) to thermostat 1, thermostat 2 to overload (black disk) from overload to Common( C) terminal on compressor.
From Run (R) terminal on Compressor to Common (C) terminal on dual capacitor. From Start (S) terminal on Compressor to "Herm" terminal on capacitor. From fan motor to # 4 on switch = Medium Speed, to # 6 on switch = High Speed, from fan motor to # 7 on switch - Low Speed. Brown wire from fan motor to (F) on dual capacitor, white wire from fan to (C) on capacitor and L2 (ribbedwire) (N) to (C) on capacitor
May 10, 2009 | Heating & Cooling
Compressor fan motor runs backwards
Most likely a bad motor or bad capacitor. I would check the capacitor first as this is probably a $20 fix. The fact that it runs in the correct direction but at a reduced speed really leans hard to the capacitor.
Good Luck and hope this resolves things for you. Let me know.
May 09, 2009 | Goodman CKL24AR24 Air Conditioner
Wiring compressor
The two terminal cap is only for the new fan motor. Connect the compressor wire back where you found it, on the 3 terminal cap. It's the terminal marked, "herm". The "common" terminal on the 3 terminal cap must still be connected to one side of the 220 power at the contactor. One side of the 220 goes to the common on the compressor. The other side of the 220 goes to the run winding on the compressor AND the common terminal on the 3 terminal capacitor.
Jul 18, 2008 | Carrier 38CKC036 Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
460 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
