Question about Philips 42PF9431D/37 TV
Blinking red light
My t.v. does the same it turns on then a few moments later a blinking red light comes on. I dont see any raised capacitors...the ones with crosses on them, is there any other way to see if they are infact burned out....? They all look the same to me.
  • 508 Answers
Honestly unless your very knowledgable in electronics i would take to someone reputable or if under warranty call manufacturer!
Posted on Jun 27, 2009
Sony Bravia 52EX701 picture went out. Now bottom
Most likely it's a capacitor fault.
Google "Capacitor bulge" and then search Youtube for your make and model to see if anyone has done an instructional video. You'll need to be comfortable dismantling the unit and be able to use a soldering iron. If this isn't you then take it to a repair shop.
Sony is, by and large, a reliable brand. The problem is that Sony like most other manufacturers has to buy capacitors from 3rd party suppliers who bid on price. Unfortunately the cost cutting has affected parts quality.
Sep 16, 2014 | Televison & Video
My tv intermittantly turns off, the LED red light continues to blink. Turning off and then turning the TV back on after a few moments rectifies the problem - but it will recurr after a while.
Ur power board is dying,must check replaced parts like capacitors puff up or burst open.Know how solders?Buy a refurbish power board Shopjimmy.com,Ebay.com to buy.
Jan 13, 2010 | Panasonic VIERA TX-26LXD80 26 in. HD-Ready...
What does the blinking red light mean? The
it means that you have probably blown a capacitor or 2 in the back of the set. Take the back panel off and look for the round capacitors that have a cross. If any of them are bulging, they are blown. You can order new ones at most electronic parts stores, just get all the readings off it, temp. range and farad readings. They cost less than a buck each. They need to be soldered onto the board.
Nov 19, 2009 | Philips Televison & Video
Television turns on and immediately turns off
it costs $2.50 to fix its 2 capacitors in the motherboard need to change them very easy i just fixed mine took me an hour all together and less then 3 bucks .if you open the tv look in the middle motherboard and you will see witch capacitors are blown because the top of them is raised up change them and ure done,all the capacitors have a cross scored in the top ,so they dont blowup ,so if you see 1 raised just a little bit its fried change it while ure in there , they wanted $400 to $500 to fix lmao now .
Jan 18, 2009 | Philips 42PF9431D/37 TV
50" Magnavox Plasma TV will not turn on - Red LED blinking 4x
When you have the red light that blinks four times on the 50" Magnavox Plasma Model 50MF231D/37, you should look for the capacitors on the power board in the center of the of the TV. Look for two 3300uf, 10V, 105c capacitors that have a build up of pressure that has caused the top of the capacitor to look rounded instead of the flat top that will be on all of the other capacitors. Changing these two capacitors fixed the problem of the TV not coming on.
I had more trouble finding the capacitors than changing them. I could not find them locally so I went to an on-line electronics supply store where they were $1.65 each and $8.99 to ship.
Jan 03, 2009 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Picture & sound shuts off
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Oct 06, 2008 | RCA L32WD14 32 in. LCD Television
Mitsubishi big screen vs45605
I believe I have a convergence problem with my VS-45605, i cannot get the front panel controls to move the blue and red crosses. I dont have original remote and a universal remote doesnt work either, any suggestions.
Jul 24, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Sony LCD television will not power on.
I get 5 blinking red lights for about a minute or so before it powers back down. The Sony TV has a specific light that i presume is supposed to light up when the bulb is out. I'm unsure if this is what it is.
no picture, no sound. tries to boot with green light blinking a few times. then goes to red blinking light, six in all, then waits a few moments, then another 6 blinking red light.
Bulb was already replaced several months ago but we do have the TV on for long periods of time.
Jan 15, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Philips 42PF9431D/37 TV Logo
492 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
