Question about Toro Co M/R Blwr/Trmmr Rear Bag Kit
The front wheel drive will not engage properly
    Champion:
  • 205 Answers
Check the front wheel drive pinion. and the gears in the wheel. you may want to check the belt from your trany to the engine. some times thy Ride up the pulley
Posted on Oct 13, 2009
Is there an electric or vacuum switch on a 2001 chevy blazer
There are 2 models here the push button will flash if the system is not engaging or disengaging properly . If front drive shaft is turning. That is with car raised and supported . if front drive axles do not turn then the axle actuator is not engaging axle shaft passenger side. Remove actuator and manually engage shifting collar with a screwdriver still does not turn then inner axle is twisted.
Mar 21, 2014 | 2001 Jeep Grand Cherokee
I have 2003 RA Holden Rodeo 3.0 ltr T/Diesel. The 2 front wheels don't seem to be engaging when i put it into 4wd (high or low range). I can hear the high and low range click in when i press the buttons...
Does yours have AUTO hubs, there are some luxory models have auto hubs, these rely on difference in drive on the axles,(wheel spin) others have manual locking hubs, these actually need to be engaged manually, these require you to twist the centre of the hub to engage and disengage the front hubs, these sometimes require you to reverse to disengage properly, Rodeo had both depending on model. Happy New Year
Dec 30, 2013 | Isuzu Rodeo Cars & Trucks
Lawnmower wheels jamming/sticking rear wheel drive
Unless you want to replace these gears You can make this mower into a push mower by taking the wheels off and disconnecting the gear drives. One time I took wheels off the front and put on the rear and rear off the back and put on front. In order for this to work all four wheels have to be the same size.
Dec 23, 2017 | Garden
4 wheel drive not working won't engage front
have you checked the front hubs are engaged or engaging
Jan 20, 2012 | 2000 Isuzu Rodeo
08 f150 4x4 on front end only one side is disengaging when in 2 wheel drive. The problem is when engaged into 4x4 wheel drive the front drive line spins and both sides engage but only the back wheels spin...
If I read this correctly ( which I might not have, bit early for me ), the front drive shaft will engage ( from the transfer case ) but the front wheels are not engaged ?
If so, sounds like either the vacuum from the IWE ( Integrated Wheel End ) is not being released, or the IWEs have had an issue with part vacuum ( damage vacuum lines ) and the IWE gear is rounded off.
If you pull the vacuum lines at the IWEs ( there are 2 lines, 1 is the vacuum line, the other is the vent tube that routes up into the engine compartment and is not attached to anything ), the front wheel should engage ( might need a 5 * turn to mesh the gears ). With the vacuum lines off, jack up the front axle ( take precautions, chock the rear wheels, parking brake, jack stands, etc ) see if the front wheels are engaged ( turning one wheel should turn the other ). The option is to do this after the truck has sat over night, and the vacuum has been released out of the vacuum reservoir.
If the wheels turn correctly ( engaged ) I would think the contact plates in the transfer case are not making contact. Good starting point for this is the connector on the side of the transfer case, some times this gets gummed up, and the pins do not make good contact. The contact plates in the transfer case are used for a few things, one of them is to signal the IWE solenoids to release vacuum to the IWEs.
Operationally vacuum holds the IWE ( Integrated Wheel Ends ) out, and once vacuum is removed the spring engages the IWE.
Here is a black diagram of the IWE vacuum system
Feb 05, 2011 | 2004 Ford F150
Every time i push the button for the four wheel hi it makes the click noise in the front but DOES NOT ENGAGE. only the back tire spins
Depending on the year, it is not posted, it may be a bad transfer case motor. The clicking you are hearing is the motor trying to engage transfer case & front axle. It looks like a windshield wiper motor & when it gets power & works properly it engages front wheels. Again, depending on the year, may be 4 wheel drive actuator or switches bad on front axle or transfer case.
Jan 17, 2011 | GMC Jimmy Cars & Trucks
1999 gmc seirra , the four wheel drive is not working properly , the transfer case seems to be engaging but the front wheels are not spinning
There is a gas canister on the front differential that engages the hubs for 4wheel drive. make sure it is functioning properly. It works by way of heating the gas in the canister which forcess a rod to slide and engages the front diferential. During the cold months it takes longer to heat the gas in the cylinder and sometimes won't allow the diff to engage. Check to make sure it is functioning it is located on the inside right hand side of the front differential.
Jan 07, 2011 | 1999 GMC Sierra
4wheel drive wont engage
First, start checking the fuses an there is also an electrial activaced switch at the transmission or transfer case that may be bad.
95-96
Your control knob should say 2wd, 4auto, 4low.
First, we need to narrow it down to a transfer case issue, or a front axle issue.
Step 1) Jack up the front end and place it securely on jack stands.
Step 2) Verify that the front driveshaft turns by hand. When turning the front driveshaft by hand, the front wheels may or may not turn. Do not be alarmed if they don't turn. This is normal for your vehicle.
Step 3) Start the vehicle and let it idle. Place your foot firmly on the brakes, place the transmission in NEUTRAL, engage 4low, then place the vehicle back in park. DO NOT ENGAGE ANY GEAR!! The lurch as the transmission engages could cause the vehicle to lurch and potentially fall off the jack stands.**If you can turn the front driveshaft, the transfer case is not locking. This could be due to a mechanical issue with the transfer case itself, or an electrical gremlin with the control system. Start a new thread with the results of your checks, and we'll go from there.
**If the front driveshaft does not turn, the transfer case is locking properly and we need to continue searching.
Step 4) With the front wheels in the air, engine idling in PARK, spin one front wheel. The other wheel should spin the opposite direction. If both wheels spin in opposite directions, then the front axle *should* be properly engaged. Take it for a test drive (after safely lowering it to the ground, of course). If the front wheels do not spin in opposite directions, there is a problem with the front axle. This could be due to a mechanical problem with the diff, or a failure of the center axle disconnect to engage the passenger side axle shaft. Start a new thread with the results of your checks, and we'll go from there.
Troubleshooting the CAD on a 95-96 is a bit more involved than I want to get into here, and the problems can vary widely. This'll get you started.
97-01 4-door and 96-00 Sports
Your control knob should say 4auto, 4high, 4low.
Step 2) Verify that the front driveshaft turns by hand. When turning the front driveshaft by hand, the front wheels should turn. (If only one turns, don't be alarmed. One wheel sometimes has more resistance in the brakes, bearings, or CV joints. This is normal)
Step 3) Start the vehicle and let it idle in PARK. Engage 4high. DO NOT PUT THE VEHICLE IN GEAR!!! Crawl underneath and see if you can turn the front driveshaft.
Step 4) With the front wheels in the air, engine idling in PARK, spin one front wheel. The other wheel should spin the opposite direction. If both wheels spin in opposite directions, then the front axle *should* be properly engaged. Take it for a test drive (after safely lowering it to the ground, of course). If the front wheels do not spin in opposite directions, there is a problem with the front axle. Start a new thread with the results of your checks, and we'll go from there.
'01-'03 Sport and '01-'05 Sport Trac
Your control knob should say 2wd, 4high, 4low
The transfer case in these trucks functions essentially like the 1st-gens' 13-54 t-case. (i.e. it uses a lockup collar engaged by the transfer case shift motor) The troubleshooting procedure is very similar, but you don't need to worry about hubs or center-axle disconnects engaging.
**If you can turn the front driveshaft, the transfer case is not locking. The shift motor could be falsely reading an incorrect t-case position, or it could be a mechanical issue with the case itself. Start a new thread with the results of your checks, and we'll go from there.
Step 4) With the front wheels in the air, engine idling in PARK, spin one front wheel. The other wheel should spin the opposite direction. If it does, the system should be properly engaged. Safely lower the vehicle to the ground and take it for a test drive. If the wheels do NOT spin in opposite directions, there is a problem with the front differential or axle. Start a new thread with the results of your checks, and we'll go from there.
Keep us updated.
Dec 16, 2010 | 1996 Ford Explorer
Front drive shaft not fully engaged in 4WD, with truck on stands all 4 wheels do rotate but if i stop front wheels the front drive shaft is not engaged
Do you have auto locking hubs on the front wheels, or manual locking hubs?
If you have auto locking hubs chances are they are not engaging properly and will need to be removed and spline sets checked for broken teeth on locking hub and locking shaft.
If you have manual locking hubs then check that they are firm when turning to engage them in the lock position.If they are light when engaging them to the lock position then they my have broken/worn out the locking hub and spline. Also check that the engaging spring inside the hub has enough tension to engage the hubs they may be broken. If the hub are all ok then you have a problem in the transfer box, where the 4WD lever is not meshing the transfer box properly. Hope this helps, let me know how you get on.
Jason
Apr 04, 2010 | 2002 GMC Sierra C/K1500
Digital speedo jumping randomly up to299kmh not reading correct
The speedo drive sender is very common failure on these bikes following any maintenance involving the front wheel removal (like tire replacement)
The speed sensor is located on front axle on the right side of the wheel
The magnetic rotor gets broken because the drive detent is not properly engaged duing re-assembly.
Fortunately the replacement is relatively inexpensive and reasonably easy to replace if you are careful to engage the drive properly when re-installing wheel. Insert the drive into the wheel before bringing wheel up to forks and inserting axle.
Mar 20, 2009 | 2006 Suzuki SV 650
Toro Co M/R Blwr/Trmmr Rear Bag Kit Logo
188 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
