Question about Plumbing
I drained the hot tub put water back in the jets are not working
    Sergeant:
  • 399 Answers
U need to prime the pump to get the air out
Posted on Nov 14, 2009
Do Mirolin water jet tub jets come out for cleaning ?
No they do not here is a simple way to clean the jets and the piping.
Regular Jet Cleaning
To clean the entire whirlpool system and tub exterior, follow this process every month or more frequently if needed. Don't let dirt and grime build up or you'll have more scrubbing to do to get the tub clean.
  1. Fill the tub with hot water, approximately an inch above the highest jet.
  2. Make sure the water temperature reaches at least 140? F (60? C).
  3. Add 1/2 cup of laundry detergent or the amount used to clean 1 load of laundry as recommended by the detergent manufacturer.
  4. Run the jets for 15 minutes.
  5. Drain the tub and refill with clean lukewarm water.
  6. Run the jets for another 15 minutes.
  7. Drain the bathtub.
  8. Dry the tub completely by wiping it down with a clean towel.
Jan 13, 2017 | Jet Home
Hot tub comes on jets want start
most hot tubs have two motors. one is a circulation pump to move water when the heater starts and the other comes on when the jets are being used. from the sounds of it, the one pump isnt running properly
Oct 20, 2015 | Pool & Spa
How can i clean/disinfect my tub/jets really really well? Im not sure what is safe to use in my tub.
Log in to this link.www.wikihow.com. It will give details . you can use dishwasher detergent works well for me. fill the tub with hot water ,several inches above the jets, run for ten minutes or so , drain refill with fresh water run for ten minutes to flush system . drain again finished.
Nov 12, 2014 | Home
Morgan hot tub
I found the drain snakes very helpful to unclog a drain even it is a bathtub. Dran snake found both hand cranked and power cranked. for home use, the hand crank is enough but for professional plumbing power cranked drank snake is best.
Learn more from here -
https://www.toolsfreak.com/best-drain-snake/
Jun 30, 2014 | Pool & Spa
How do you clean the jets in a whirlpool tub? Is there any product to put in water and run jets to clean them?
Put white vinegar in the water and run it through your tub. Fill the tub to it's maximum running capacity, which is normally just above the jets, and pour a gallon of vinegar in the water with it. Let it run with the vinegar for about 20 minutes, then turn it off and let the vinegar sit in the jets for about 30 minutes. Then start up the jets again for about another 10 minutes and drain. Then run plan water through the jets for about 15 minutes, drain and that should do it. I would recommend doing this at least once every 2 months depending on your water type and how often you use the tub.
Feb 13, 2013 | Home
I have a walk-in jacuzzi-type bathroom tub. When the automatic blower comes on it sends out a mildew smell. How can I get rid of it?
First of all, after each use, refill the tub with warm water and run the jets for about 10 minutes to clear out any excess debris etc.
To eliminate the smell/mildew/mold. :
-Fill the tub to above the jet level with HOT (over 140deg.) water
-Add two tablespoons of low sudsing dishwasher detergent and five cups of distilled white vinegar
-Run the jets for 20 minutes
-Drain the tub and use a tooth brush or any small brush to gently clean inside and around all of the jets and nozzles, remove all foreign material you can from the areas inside (disassemble the outter rings to do so) and around the outlets. Be as thorough as possible.
-Rinse and refill the tub with CLEAN COLD water and run the jets for another 20 minutes.
-Drain the water and the smell and mildew should be eliminated.
To prevent future mildew build up/odors once a month fill the tub with HOT water (again) and four to five cups of vinegar (no detergent) and run the jets for 20 minutes. Drain and fill with clean cold water running jets another 20 minutes. If the tub is used very often you can increase the scheduled flushing of the system to every two to three weeks. The mildew/mold flourishes in the warm wet areas inside the jet tubing and nozzles. Diligent maitenance is the best way to make sure you're not bathing with any unwanted guests in your bathwater!
-Take care
Mar 01, 2012 | Washing Machines
We have a dreammaker spa, how do we drain it? the model is Fantasy
The Fantasy has a drain located in the toekick of the spa. You have to first remove the drain cap, attach a hose if you wish, spin the outer black ring counter clockwise to start the water flow, then pull the outer ring out away from the tub to increase the drain to full flow.
I understand that a screw driver is often needed to pull the outer ring out to achieve full flow. Therefore, I suggest another method. Take a garden hose and place it in front of the jet while the spa jets are on. This will force water flow thru the hose and prime the hose. Once you see water running from the other end of the hose, drop the hose in front of the spa jet into the footwell and as long as the loose end is lower than the end in the footwell, a siphon will drain the spa as fast as the spa drain will. Remember to turn off electric to the spa once you have established a siphon. You may have to bucket the last bit of water in the footwell. Goodluck.
Oct 31, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
I have an Eljer jet bathtub with a smell to the water when we bat
What you smell is algae forming in the pipes. If you have small black particles in the tub when running the jets, it is algae. Fill the tub with hot water, add 2 teaspoons of cascade dish soap and 1/2 cup bleach. run the tub for 15 minutes and drain. fill tub with cold water, run for 15 minutes and drain, tub is now ready to use. repeat as necessary.
Aug 02, 2009 | Home
Hot tub mtor is on.....no jets....
you may have burnt the pumps up,pumps like that are water cooled they may have over heated ,you may need to replace the pump.
Jun 29, 2009 | Maax Calla 6042 Bathtub - 101058-000
Plumbing Logo
116 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
