Question about Microwave Ovens
Whirlpool MH2155XPS - numbers on the clock display
Whirlpool MH2155XPS micro wave- numbers on the clock display aren't working. how can i fix?
  • Microwave Ovens Master
  • 9,098 Answers
Normally it's bad connections or "ring cracks" on the connections on the circuit board.
This assumes the display glass is not broken, which would necessitate a new control board.
(Note that a dark spot on the display glass is normal)
And it assumes that the unit was not hit with a surge, or needs other repairs, which we do nationwide for $39.95 in most cases.
Feel free to contact me directly (and please remind me of your full model number with suffix 0, 1, 2, 3, or 4 from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jun 28, 2009
How to set the clock on ge space maker micro wave
http://products.geappliances.com/appliance/gea-support-search-content?contentId=17872
Quoted from link above:
To set the clock on most GE microwaves:
  1. With the microwave door closed, press CLOCK.
  2. Touch number pads that reflect the time of day (1:45 would be 1, 4, 5).
  3. On some newer models, indicate AM or PM for morning or evening.
  4. Press CLOCK or START to lock in the time.
If you prefer not to display the time:
Disconnect the power for 30 seconds. After restoring power, do not set the clock. If your model has an ON/OFF clock display, you can choose not to have the time displayed. To choose this option, press the 0 pad for about three seconds. To Turn the display back on, press the 0 again.
Mar 21, 2018 | GE Microwave Ovens
How do I set the clock on the kenmore brew wave
To set the clock:
Find the OPTION button, it is the second top button to the left of the green clock display
1 - Press OPTION
2- Press 1 (to set the time)
3- Press the numbers for the current time of day - then press START (ie: 130 for 1:30 )
4- Press 1 for AM / 2 for PM
5- Time is set !
Jul 10, 2014 | Kenmore Brew 'n Wave 63992/63999 Microwave...
Microwave sometimes heats up food and sometimes it does not.
usually when you kill the power and then when you put power back on the machine works it's the computer board that's bad.all you're doing is resetting the board just like your house computer,if something happens to it you shut it down and reboot it,that's what you're doing with the micro wave just rebooting the board.here's the funny thing about micro waves sometimes the part you're gonna change is almost the same price as a new micro wave so i would first check how much the board is,i went on sears and they have the board for 115.00 repair clinic for 235 part number WPW10216347 they don't make this model anymore but you can get a stainless micro for around 290 to 300 dollars and if you buy the same brand all you should have to do is remove the bolts up above that hold it in place and remove the micro wave and the same brand should mount the same way so you won't have to drill new holes or replace the back metal panel.if i were you i would replace the unit instead of the board repair clinic shows most of the parts for this model out of stock so it might be a while before you can get any parts for this model but this is up to you.good luck with your micro wave.one more thing when you were in there did you see alot of grease,this is usually the cause of no heat,the grease from cooking on the stove top gets into the micro wave and on the mag tube and damages it,if there was grease in there i would just replace the unit
Dec 15, 2017 | Whirlpool WMH2175XVS Stainless Steel 1000...
Dont know how to set clock
hello there:
to set the time on you're micro wave you will need to push the clock button and use you're number pad to enter the time and once you have got the time set properly you will need to press the clock button again.... hope this helps you out sincerely D.Jones
Jun 06, 2010 | Goldstar MV-1501 Microwave Oven
Whirlpool micro wave making loud humming noise fan and light works
Some micros when they get older make more noise. as long as it works I wouldnt worry about it
Jan 12, 2010 | Whirlpool MH7140XF Microwave Oven
The microwave stopped heating the food. Power
The light inside the micro wave needs to be replaced most have a door on the back side that yo can remove the screw and unscrew the bulb and take to a applince shop and purchance a new one to replace.
Jul 16, 2009 | Whirlpool GH4155XP Microwave Oven
I cannot set the clock on my LG MS1949G Micro wave
After spending 25 minutes on hold while LG try to find out how their own product sets the clock, I now know that the LG MS1949G Microwave open does NOT have the ability to set a clock that shows the time of day.
Jul 11, 2009 | LG LTM9000 Microwave Oven
Samsung MR6699GB
This model was one of many subject to a recall due to defective membrane keypads.
Details of the recall are here: http://www.allworldauto.com/recalls/NHTSA_03E044000__SAMSUNG_MICROWAVE_MR6699GB_recall_55168.html
Long story short, please unplug it and contact Samsung with you model and serial number at 800-932-3837.
If your serial number was not one subject to a recall, E2 usually means a temperature sensor problem but it may also mean you have a bad door switch.
If it's not in the recall, please post back and I can give you info on checking the other parts.
We're happy to help and we appreciate your thoughtful rating of our answer.
Feb 13, 2008 | Samsung SMH7174BC Microwave Oven
Micro not working
No most likely the little angel didn't ruin it. Remove the cabinet and you will find a 10 to 15 amp fuse connected in line with where the power cord comes into the back of the microwave. Be careful that you make sure power is off and be careful you don't touch the capacitor it could be charged. But the fuse just usually snaps in.
Dec 24, 2007 | Whirlpool MH2155XPS Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
