Kenmore 82822 Electric Dryer Logo
A
Anonymous Posted on Jun 19, 2014
Ke more dryer works but makes whistling noise. What could the problem be?
Jorgie the appliance guy
Level 3:
Top Expert:
  • Kenmore Master 5,639 Answers
  • Posted on Mar 31, 2015
Kenmore Master
Level 3:
Top Expert:
Answers
5639
Questions
Helped
1522535
Points
32630
Maybe a worn belt, bad felt, glides etc
1 Related Answer
hunter19_46m
Curtis Sewell
  • 7482 Answers
  • Posted on Jun 16, 2011
SOURCE: my dryer is making a whistling noise
Hi markbid...
I have never heard a dryer whistle, but there is always something to learn, follow the directions below and you can solve your noise problem.
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
Note: This method works with most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer if you have to.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical console with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer by removing two screws located on either side of the top of the dryer housing and unplug the door switch.
This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.Now is a good time to replace the front felt seal on the drum if it needs to be replaced. Be sure to use a good grade of weatherproof cement on the seal to glue it to the drum, sometimes the glue is furnished with the seal.
Now is also a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots they will make a thumping type of noise or if there is too much wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil, or a light lubricant like Vasoline.
Reassemble the dryer.
Plug back into your electrical receptical.
This should solve your noise problem.
This is a FREE answer, Please take time to rate me
1helpful
Whistling noise
Could be a worn belt, or a motor part needs oil, or friction with armature (sp).
Whistling noise
There are many possibilities that can make vehicle whistling noise.
Click the link below and follow the details:
http://www.gresk.com/2013/09/car-make-whistling-noise.html
This will help.
Thanks.
2helpful
There is a squealing noise when the dryer runs. The belt seems to work fine, but there is a whistling/squealing noise when the dryer is on
The drum rides on a pair of plastic glides in the front. They get thin and their bracket begins to rub the drum.
The rollers tend to get a little noisy in time. I use HVAC oil (zoom-oil from ace hardware) to lube them because it is temp resistant, won't disapate, and is non flammable.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
2helpful
2answers
Dryer does not start, makes a high pitched whistle noise.
Can your drum be stalled and the whistling is created by the belt slipping on the pulley on the motor?
Remove the top and front to look more closely at your situation.
Let me know what you find.
a
2answers
Whistling noise when accelerating
you most likely have an aftermarket radio installed
the noise you hear is engine noise, if yo turn your radio off it will go away
this can be fixed by either getting better wiring for your aftermarket radio or by installing a noise filter, you can purchase that at most big electronic stores
1helpful
Drum makes noise after I unscrewed the screws inside the machine.
You will have to remove the drum from the front and replace the drum support cup kit.
WHISTLING NOISE-DAY AND NIGHT REFRIGERATOR MODEL # GSS201BPDWW
Pull the cover off to the fan and compressor housing and clean it. Clean coiling as well. Most coils are located under the unit. They make an appliance brush to reach between the coils that can be purchased at an appliance store.
Kenmore elite HE3
You need to check if the Spray Arms are knocking against an item in a basket. If the source of noise cannot be determined, run a program without plates or glassware. If the noises continue, let me know for further investigation.
LG Electric Front Load Dryer door whistles!
under warrenty call serv tech they ussally know whats wrong from svc bullitans
Top Kenmore Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
