Good Morning Gary,
I understand you are receiving an E68 code on your Frigidaire Affinity washer, model# ATF7000E. The E68 code states that there is a current leak to the ground on the heater or there is a fuse open. This could also be a false error code. I suggest resetting your appliance, by either unplugging it or shutting the power off at the circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Testimonial: "Seems to have done the trick. Thanks so much"
SOURCE: Code E36 and Code E68
hello e36 means control board problem E68 means current leakage to ground on heater or fuse opened
shaun
SOURCE: Frigidaire Affinity dryer error code?
HELLO,
I HAVE A FRIGIDAIRE AFFINITY DRYER (AEQ6000CE32). WHENEVER I PUT THE CLOTHES IN IT JUST SPINS FOR 10 TO 15 MINUTES AND SHUTS OFF BEFORE THE ALLOTTED TIME. THERE IS NO HEAT IN THE DRYER. ANY SLOUTIONS?
SOURCE: MI SECADORA ES FRIGIDAIRE AFFINITY MODELO AEQ6000ES2 Y ME DA ERROR E68
confirma que sea realmente el error del boton atorado y si todo esta bien agrega un resistor de pull down al micro eso me funciono en una secadora que arregle
SOURCE: error code DR comes up on my Frigidaire Affinity and won't keep running
It is telling you there is something wrong with the door lock assembly. You will probably have to replace it, but check it first for a broken wire or some other problem that you can fix.
Here is a link to the part if you need it.
Here is a link to a service manual for your machine that will take you through the testing and repair process.
http://www.emaservicetips.com/pdfs/778_5995456851_Affinity_washer.pdf
