Question about HP 22" Widescreen Flat Panel TFT LCD HD Monitor
No sound from built in speakers - HP 22" Widescreen Flat Panel TFT LCD HD Monitor
    Problem Solver:
  • 14 Answers
Is it a monitor or TV??? If its an LCD computer monitor check your cabeling, the sound coard should be plugged into the "green" jack in the back of your computer. Check the "sound and audio devices" in the control panel if it is on MUTE or turned down very low.
If its an LCD TV check your audio inputs with another device to see if they work. Check to see if it has been muted on the TV. Otherwise its probally your main board in your tv buring out.
Posted on Jun 26, 2009
Does it have a built in mic
If it doesn't have a web cam then it wont have a built in mic. However you can buy cheap plug-in ones.
May 24, 2014 | Samsung r540-ja04 15.6" notebook intel...
No sound coming from built in speaker
Is your computer custom built? Or a factory built one? If it's factory built I'm going to need the model name.. For an example I have a Dell A950. It's name can normally be found on the front or back.
I need this because I can't help you solve your problem if I have no idea what hardware you have. Therefore I can't know where to get the driver to fix your speaker. The built in speaker probably needs a specific driver to be used.
Apr 09, 2013 | Computers & Internet
Pavilion 22bw does it have built in speakers?
Troubleshooting Sound Problems with Monitor Speakers
Not all monitors come with built-in speakers. If your monitor does not have built-in speakers, then you will need to connect an audio cable to an external speaker system to hear sound.
Mar 19, 2013 | Acer V193w LCD Monitor
I have a subwoofer and speakers from a surround sound system but the dvd part has blown up can i use the subwoofer and speakers with another unit
sure u can. but depends either your system is active or passive. active means the speakers (or sub) driven by built-in amplifier, so the dvd delivers a low signal to the speakers amp and they amplify the sound for the speakers. passive means the amplifier is built into the dvd and delivers the amplified sound signal to the speakers thru speaker cable. if you tell me model number and brand i can find out what type they are.
Feb 08, 2011 | Philips Audio Players & Recorders
I can not tell in my monitor has speakers
Most monitors do not have built in speakers and the ones that do have them are usually of fair quality. Look for speaker grills under your monitor's screen. Didn't find speaker grills? You can buy computer speakers at a computer store or at Walmart. Your computer, desktop or laptop, has a green jack that you plug a set of speakers into. The volume control may be on the speakers or on your keyboard.
May 01, 2009 | HP P1130 21" CRT Monitor
No sound at laptop speaker but audio output is ok
I have lenovo notepad 3000n100 with winXP sp2.
I downloaded realtek audio from ibm site and installed.
Now sound is coming at my output port but the in-built laptop speaker is not giving any sound output.
The hardware is ok as the sound was coming at in-built speaker before formatting. The previous audio driver set up file i have lost.
Plz help.
Apr 16, 2009 | Lenovo 3000 N100 CoreDT2080 VB PC Notebook
No sound through external speakers
Although some monitors have built in speakers, most people have stand alone speakers. If the old monitor had built in speakers and now it is unplugged you won't hear sound. Even if the speaker cable is still plugged into the sound output on the back of your computer, the monitor must be plugged into an electrical outlet to have power.
I'd recommend buying a new set of external speakers if this is the situation.
If you never had speakers built into the monitor then normally changing monitors would make no difference whatever. The only explanation that makes sense under those conditions is that in the process of replacing the monitor, you dislodged the speaker jack from the sound output on the back of the computer.
Make sure your external speakers have electrical power plugged in, the power is on (green light on at least one speaker lights up) and the volume on the speakers is at least half way up.
Unplug the speaker from whatever hole it is plugged into and plug it firmly back in and test sound.
If still no sound other than some static on the speakers, try every single hole on the back of the computer that the jack will fit properly and test for sound.
Let me know if you have further questions.
Honest1abe
Jan 10, 2009 | Acer Computers & Internet
Emachine computer no sound at all
Built in pc speakers are just for error beeps etc. You most likely have on-board sound. I would try getting a sound card (with drivers) Put it in a free pci slot & connect your speakers to it. :)
Dec 01, 2008 | E-Machines T1742 PC Desktop
No sound on new LG Flatiron Monitor
You need to get a set of powered computer speakers!
I always found that stand alone speakers are much better than the ones in the monitor.
Jerry G.
Apr 30, 2008 | LG Flatron L1919S LCD Monitor
Built in speakers don't work.i have sound only when i plugg the headphones
Looks like there is some problem with the stereo headphone connector. As its a hardware issue, I would recommend sending it to the service center.
You may also use external speakers temporarily.
Apr 15, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Open Questions:
Toshiba Laptop doesn't start up. Black screen [Solved] -Dataalign If you are facing any kind of issues in Toshiba laptops or other products related to Toshiba brand, then you have come to the right place, as this article is an overview of where you can find the right kind of services, required for proper working of the gadgets by any tech savvy person, in particular the ones using Toshiba products. Another beneficial thing about using Toshiba products is its reliable Toshiba Customer Service , which can be reached any time for assistance with guaranteed satisfactory results. Toshiba customer care services are provided by highly efficient and knowledgeable tech support technicians having years of working experience in the field of providing dependable services to the customers of Toshiba. Toshiba support services provided by Dataalign are the best in class for their consistent services and highly advanced way of resolving tech issues faced by the customers. Dataalign tech support team comprises of expert technicians and they make use of high class technology for fixing the issues in Toshiba laptops and other devices as they have proper knowledge of all kind of issues with their perfect resolution. Dataalign technicians can be reached easily anytime from anywhere through the toll free helpline number +1888784-9316. Dataalign assistance providing Toshiba Tech support engineers are selected through a rigorous process of selection which makes them efficient for providing right support in minimum time with high accuracy. Technicians of Dataalign assist the customers in the most polite way with the assurance of providing highly accurate solution for every issue. For the answer of any kind of query related to Dataalign or for help regarding tech issues contact Toshiba support on their toll free helpline number.
Jun 21, 2018 | Toshiba Computers & Internet
See all HP 22" Widescreen Flat Panel TFT LCD HD Monitor Questions
HP 22" Widescreen Flat Panel TFT LCD HD Monitor Logo
129 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
