Question about Grohe Grohtherm Thermostatic Rough-In Valve 3/4'' Valve - 34125000
I have a grohe 34122 1/2" valve and two different shower heads. Do I need a diverter or two volume controls? Anything else?? Thanks. I want to be able to run one or both heads.
  • 332 Answers
Install a shower head diverter, it is a push pull valve that goes on the shower arm before the shower head
Posted on Jun 27, 2009
Why is there no hot water, only cold water coming out the mixer valve?
Sounds like the screen is plugged or the check stop is not working correctly
May 28, 2014 | Grohe Grohtherm Thermostatic Rough-In...
After turning water on to 10 year old grohe shower faucet pressure rapidly drops to nearly nothing
If you spin the shower head off there should be a metal screen inside. If it is clear, Soak the shower head in CLR for about 4 hours. After 10 years even the best water supply will leave behind a build up that can plug the tiny holes.
Feb 24, 2011 | Grohe Grohmix Thermostat Valve & Trim -...
My contractor installed a 4 port diverter. The hot and cold are ok, but when I turn the shower on, the flow starts in the hand held shower head and not the main shower head. According to Grohe, whichever...
I haven't had a lot of experience with Grohe brand but have had twenty eight years as plumber, 22 years as master plumber and the bottom port of every tub or tub/shower valve that I installed used the bottom as main supply port. As far as the instructions from manufacture like I said I have not used that particular brand much,so I really couldn't say. Hope this helps some. Thanks
Nov 10, 2010 | Grohe Grohmix Thermostat Valve & Trim -...
I cannot get any hot water to come out. ihave done everything except take out the cartridge.
that valve has a shut off built in...
flat head screwdriver, turn it so it is horizontal.
if that is already on, you might have a blockage inside the valve
Aug 15, 2010 | Grohe Grohtherm Thermostatic Rough-In...
I'd like to install 1 shower had and one hand held shower. What do I need to have ?
well you can do a 3 way shower valve , or a mixing valve with 2 control valves. or you can do just to regular shower valves one for each of the heads you want one for the rain and one for the shower head. this way is cheeper and you can have one on hot water and the other cold water or the other way around or both the same temp.
Apr 26, 2010 | Grohe Integrated 1/2'' Shower Thermostatic...
I need to clean the filter on my grohe shower how do I do this
Use a flat head screw driver and unsrew the brass fitting remove the temperature spindel and wash out. Re install the same way and test.
Feb 19, 2010 | Grohe Grohtherm Thermostatic Rough-In...
Flow of water thru shower head is barely a trickle
There is a chance there is mineral deposits in the showerhead openings. You can try products sucha as limeaway by unscrewing the showerhead , soaking in the limeaway for a few minutes and rinsing with water. You may have to repeat this a few times to get it clean.
Jan 20, 2010 | Grohe Integrated 1/2'' Shower Thermostatic...
HOW TO ADJUST A MODEL 34122 gROHE VALVE
there should be a flat head screw on the mixing valve turn the water on and turn it to the desired temp,, it is letting to much cold water in , if this does not work replace the mising valve
Apr 11, 2009 | Grohe Grohtherm Thermostatic Rough-In...
Installation problem: Grohmix shower valve 1 1/2'' extension
This is what you should have... Grohe Grohmix Thermostat Valve & Trim - 34436
  • Paraffin cartridge
  • Lever volume control
  • Grip ring temperature control
  • 1/2" NPT female connections
  • Service stops
  • Includes rough-in valve and trim
  • Integrated temperature and volume control
  • Requires Twin Ell (03 671) for shower/tub combinations with diverter spout Note:
  • Grohe Grohmix Thermostat Valve & Trim - 34436
    Mar 26, 2009 | Grohe Grohmix Thermostat Valve & Trim -...
    Grohe Thermostatic Valve
    the temp, control valve is getting to hot!!! there for only let so much hot water go thru, did you take the inner parts out when soldering this in, if not you might have damaged it, and if so need to replace the cartdrige
    Feb 10, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
    Grohe Grohtherm Thermostatic Rough-In Valve 3/4'' Valve - 34125000 Logo
    543 people viewed this question
    Top Grohe Water Heaters Experts
    Paul Carew
    Craig Butler
    Craig Butler
    ray gallant
    Are you a Grohe Water Heater Expert? Answer questions, earn points and help others
