Question about GE Freezers
Ice dispenser The flap on the ice and water dispenser on the outside of the door doesn't appear to be working correctly. It doesn't close tightly and there is frost buildup inside on the dispenser chute. I have opened the door and tried operating the ice dispenser, but nothing happens. I am not sure if the flap should actually move or not though. I never noticed when it was working. The water is dispensing normally.
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Aug 23, 2010
Ice dispenser
The solenoid that opens the flap is not working. You'll need a repairman to get to it .
Jul 21, 2014 | Frigidaire Freezers
Samsung model rf4287hars only dispenses water when ice lever depressed
3b662ccb-018c-4390-ab7a-74a2025960df.jpg 3d562c7f-18a6-4fa7-9993-373c8c5d3c7f.jpg 763378c4-5f13-435a-aac3-b67d9041b031.jpg
First photo shows paddle assembly that can be purchased you need to got to Sears web site to find part # other wise you will have to buy the whole circuit board assembly hundreds more than the paddle assembly. The circuit board and paddle assembly is removed buy removing screw on inside of door and pulling it out be careful it seems strange but it just pops out. The paddle assembly slides on to the circuit board assembly look close and take your time to slide it off I thought I was going to break mine but did not and save me big money.
Second photo shows tab for water dispensing still there.
Third photo show ice dispensing tab broken and missing.
If you leave the assembly plugged in press the micro switch for the ice dispenser and see if it works most likely the tab has broken and is what hits the switch telling the door to open and ice dispensing screw to push ice to the door. Hope this helps
Mar 04, 2014 | Samsung RF4287HARS - 28 cu. ft. French...
Walk in freezer solenoid not opening
Many Kenmore side-by-side refrigerators have an ice and water dispenser installed on the outside of the freezer door. The ice dispenser has a flap that opens to allow ice to be released, and closes after dispensing to keep the cold air inside of the freezer. The dispenser flap is opened and closed by a solenoid, that when energized pulls the plunger attached to the flap, opening the door. If the flap stops opening and closing, it is likely due to a faulty solenoid.
Jul 29, 2012 | Freezers
Our subzero freezer has a new problem. The cubes
Ice cubes WILL BE slightly moist when they land in the ice bucket. they've just been slightly melted in order to eject from the ice maker. Stop playing with the settings, for starters. put them back to normal, i.e., middle setting, place thermometer in center of freezer, and if you can, one in center of fresh food. monitor after 24 hours, and for the next three days thereafter. freezer temps should be in the -5 - +5°F, sometimes up to 10°, fresh food should be 35-40, sometimes up to 44°at the normal settings. If you are not having temperature issues, see if you notice any frozen drips of water on the underside of icemaker, indicating a possible crack in the ice maker mold, or a faulty water valve. You didnt include your model and serial number, so not knowing the path of the ice shoot, some go out the freezer door, some slide over and get dispensed from the fresh food side. Its possible you may have a problem instead with the flapping door that opens to allow ice cubes to be dispensed, or similar type mechanism. If this door does not seat completely when its closed, it will leak warm air directly into the ice bucket, which would make them slightly moist, also too, this warm air can cause frost and ice to buildup near the warm air source...look for any unusual forms of ice and or frost leading up from the flapping door to the ice bucket. Also look for any gaps in the door gasket when closed, this warm air leak can also cause similar problems, but its most likely with the ice door. could be the door, the spring, the solenoid, or something else i wouldn't know without personal refrigerator inspection.
Mar 27, 2010 | Freezers
Whirlpool GR2FHTXVQ00 fridge. Water dispenser
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
You can thaw out the fill tube and replace the inlet valves.
Oct 13, 2009 | Freezers
Whirlpool GS6NBE side by side ice maker works fine but the ice dispenser doesn't. I can hear a sound and a click when I push it and the dispenser flap works but no ice will come out. Water works fine.
The four prong (flat) plug to the ice maker (in the freezer compartment) in my Whirlpool Gold SbyS Refrigerator; should I be able to test for 120 Volts with a tester, should this plug be 'HOT"?
Sep 04, 2009 | Whirlpool Freezers
Ice maker flap don't shut all the time
The flap may be getting stuck on the ice guide which is mounted on the arm you push in th dispense the ice . ( pt # 2180224 ) . Try pushing the arm in and look to see if the flap is catching on the clear plastic piece .
Aug 24, 2009 | Whirlpool Freezers
Frost and ice on flap of ice maker
look down in the chute where the ice despences see if its closing all the way
Feb 15, 2008 | Freezers
Freezers Logo
79 people viewed this question
Top GE Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
John Tripp
John Tripp
Are you a GE Freezer Expert? Answer questions, earn points and help others
