Question about Epson Stylus Photo 950 InkJet Printer
"Ink cartridges cannot be recognized" when using genuine Epson
I've got a problem with my Epson Stylus Photo 950 printer, and hope someone here would be able to help me.
The Status Monitor says that the 2 black ink cartridges are empty and shall be replaced. So I replace them by 2 genuine Epson cartridges, according to standard procedure. I obtain an error message saying "Ink cartridges cannot be recognized".
Several times I try to pull out and set back the cartridges. No change, still the same error.
Next, I put back the two old (empty) cartridges. But now, Status Monitor, in stead of saying the cartridges are empty, tells me that "Ink cartridges cannot be recognized" (of course, the old cartridges were also genuine Epson).
There is a real problem here, and I don't know what to do. After all those manipulations the system now pretend that six out of the seven cartriges cannot be recognized.
Any idea ?
Best regards, and thanks a lot.
Steen Pedersen
  • 526 Answers
I had this happen to me twice with two different people, it is highly possible that your black inks are defective, its also highly possible that one of the other inks are causing this error. take them all out, and put one and see what happens, do this one at a time until you see something screwey.
also possible, the contacts on the printhead are dirty or are pushed in.
also possible, bad printhead.
Posted on Jun 27, 2009
Will my epson stylus nx415 printer print if there is only one out of 4 ink cartridges installed?
That seems to be what it means. I am unable to even use the scan function on my epson 500 without all of the inks installed and with ink.
Nov 30, 2012 | Epson Stylus Nx415 Color Inkjet Printer...
Does not accept new ink cartridges, indicates they are empty
This might ba an issue with the cartridge holder in which its not recognizing inks or inks are defective. Call Epson for cartridge replacement is reinstalling of inks doesn't work.
Sep 21, 2012 | Epson Stylus Photo 950 InkJet Printer
Epson s20 cannot recognize ink cartridges
have you bought genuine ink cartridge?? if it isnt genuine or original the printer wont recognize it at all..
Jun 02, 2010 | Epson Stylus S20 InkJet Photo Printer...
I have been using non Epson cartridges for years on my RX620 but today when I changed the black cartridge, I got a message that none of my cartridges were recognized as Epson and the printer is now locked...
Newer Epson ink cartridges and other manufacturers place a chip in the cartridge that interacts with the printer, telling it is a genuine cartridge.
If an aftermarket cartridge is used, it may not have the chip and subsequently will not work with the printer.
The best work around is to use genuine Epson cartridges, but when they are empty, take them to a store that can re-fill them or exchange them for a previously refilled genuine cartridge.
Mar 13, 2010 | Epson Stylus Photo RX620 All-In-One InkJet...
Won't recognize ink cartridge
Try this. Insert only 5 only ink tank, without LM. See status monitor. All 5 ink status look gray? and LM look cross. Try to another ink tank left. Last, insert all ink tank. All ink tank not recognized (cross sign)? If yes, the problem probably is epprom.
Jun 09, 2009 | Epson Stylus Photo R390 InkJet Printer
Ink not compatiable
Hi. When I fitted the second set of cartridges to my Epson Stylus Photo 1400, the printer failed to recognize any of them, even though they were genuine Epson! I repeatedly installed and un-installed them without success. After giving it a bit of thought, I had a hunch that the contacts on the cartridges might not be making good contact with the contacts on the printer as the cartridges seemed a little loose. I removed each cartridge in turn and after putting some adhesive tape on the opposite end to the contacts, (there are grooves cut into this end, but the tape drops nicely into them when you install the cart) replaced them all. (This had the effect of pushing the cartridges harder against the contacts). Switched on again and all carts worked fine. So it seems that even Epson can't make the cartridges to fit their own printer properly! Having said that it's a great printer otherwise. I hope this is helpful to you.
Dec 05, 2008 | Epson Stylus 1400 InkJet Photo Printer
Non recognition of genuine Epson cartridge which was already used
try this hold down all 3 bottons for 20 sec this will reset your printer
DONT FORGET TO RATE
Nov 24, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson stylus photo rx580
Hi-
You are having a hardware problem with the printer, the sensor is damaged. call epson @ 5622761300 for replacement ink and printer.
Hope this helps
Nov 08, 2008 | Epson Stylus RX580 InkJet Photo Printer
Ink not empty
You have confused the software in either changing a cartridge when not required or having a chip failure whilst changing multiple cartridges.
Full info on how to get out of this is on my site.
Please go to my website http://www.the-inkstore.co.uk . I have the latest version of SSC Service Utility to download directly onto your computer and instructions on how to use it, what to click on etc etc. Click any of the Epson links if you can't find it, everything you need to know will be there, including printer Firmware resetting which sorts out a multitude of problems.
The 'maintenance required' problem with Epson printers has absolutely nothing to do with which cartridges you are using, it is a built in page counter in your printer firmware, which has a different maximum amount for each Epson model. Don't listen to old wives tales and heresay, we are the experts and it's an Epson scam to cause a lot of people to pay for maintenance or throw their printers away.
I haven't found a model that can't be reset with the latest version of SSC Serve or the manual reset on my site.
For Epson RX500 users there is also a manual reset on my site, as the SSC Serve software won't do it for you.
When using the program & choosing your printer from the list, it may have a weird name with 'x' in the model number, this is because some configurations are for many models in a series. For example, the C46 will be listed as C4x as it is for the C42, C44 & C46 models.
I hope this helps all Epson users to overcome the Epson scam of page counting and locking out until you pay their dealers money for maintenance.
If you like what I've done for Epson users, please show your appreciation by spreading the word and perhaps buying your ink from my site.
Happy trouble free printing
The INK Store (UK & Europe)
Apr 13, 2008 | Epson RX620 All-In-One InkJet Photo...
Open Questions:
See all Epson Stylus Photo 950 InkJet Printer Questions
Epson Stylus Photo 950 InkJet Printer Logo
3,278 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
