Question about Xante 4G Printer
Printer keeps jamming with paper - Xante 4G Printer
    Scholar:
  • 84 Answers
Check your rollers inside and where the paper feeds.
They may need to be repalced. Cheap to reaplce.
Here is a guide that can help
Posted on Aug 18, 2009
SOURCE: printer keeps saying paper jam
we had the same problem at the college where i work. the print queue had somehow clogged up to such a point where the printer was doing this. the constant paper jam light & the printer taking paper when printing test sheets etc. we solved it by deleting the printer & then re-installing the drivers. may not work for everyone, but it certainly worked for us.
Posted on Mar 11, 2009
  • 34 Answers
SOURCE: HP 4200 printer paper jam. No paper is jammed
check this out....when the printer reports the jam, open the paper tray very carefully and slowly.
Has the paper moved at all forward? Has it moved like 1/4 inch to 1/2 inch out of the tray?
If so, you probabaly need a torque limiter, no tools, $10 or so and a very very easy fix.
POBCM is very correct when he points out that the block/stop in the back of the tray moves when the tray is closed with too much force and this is the #1 cause most of the time.
You may see a "41.3" code displayed if the block is not up to the back of the paper and the paper is not all the way forward in the trays, and under the two metal clips at the front of the tray.
Posted on Mar 14, 2009
  • 7 Answers
SOURCE: wont print on card stock, legal paper- keeps jamming
Menu> scroll to Paperhandling> MP Tray type>>(plain) try changing this to cardstock  <enter>
instead of MP Tray type do the same for Cassette if you desire....
Best, danakadan
Posted on May 30, 2009
  • 13433 Answers
SOURCE: my canon mx310 keeps showing a paper jam alarm and there is no paper jam. how do I fix it?
give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Posted on Jun 12, 2009
SOURCE: Canon MP470 keeps saying "paper jammed"
I had the same problem for DAYS and there was no paper jammed at all. I went to the cannon site as a last ditch effort & the solution below fixed it. Just clean the rollers and the link tells you how. Good luck!
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15403
Posted on Feb 01, 2010
What would cause paper jams in a hp 4100 printer
Where is it jamming. Printer this age could have fuser issues, worn rollers that are not picking up properly. Is the jammed paper crinkled up or does the printer stop before damaging the paper? If paper is not damaged, the cause is usually in the paper pickup slipping and causing the printer to think that the paper is either too long or too short. Clean all the rollers in the paper tray cavity with a damp cloth.
Sep 05, 2014 | HP LaserJet 4100 Printer
Keep getting an error that says paper jam. can
Dell P703w Printer
May 02, 2010 | Dell P703w Printer
Jan 04, 2010 | Canon PIXMA MP470 All-in-One Printer
My printer keeps saying there is a paper jam. But
If the printer is sensing a paper jam, then there is either a small piece of paper jammed under a sensor, or the sensor is falsely reporting a jam.
If you cannot find the sliver of paper, I suggest that you contact Canon Technical Support or take the printer to an authorized repair shop.
Don
Oct 17, 2009 | Canon Office Equipment & Supplies
My canon mx310 keeps showing a paper jam alarm and there is no paper jam. how do I fix it?
give this a try
alternative :
Jun 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon MX300 Paper Jam
I have the same problem - every time I turn on my printer now, the alarm signal shows up with "Paper jam" but when I check for jammed paper, there is none. So I think there's something faulty with the printer. Is there any way to reset it? I've looked everywhere but can't find it.
Jan 16, 2009 | Canon MX300 Office All-In-One Printer
Paper jam in HP 4255 office jet all in one printer
the paper path may have some jam. It may have some solid particle or paper that's causing disturbance.
If not the paper moving mechanism is having problem.
Better get your printer serviced.....
Jul 17, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Xante 4G Printer Logo
233 people viewed this question
Top Xante Office Equipment & Supplies Experts
edy copier
edy copier
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
