Question about Smith Corona Office Equipment & Supplies
I have a really old SD 660 and I no longer have manual. It is printing great but it is not typing correct letter for example when you type a it prints the letter p and so on?
Hi, either the bottom of the card guide is interfering with the daisy wheel or the daisy wheel is not seated properly or the solenoid is out of time.
Posted on Sep 15, 2009
  • Smith Corona Master
  • 3,594 Answers
Remove the printwheel check for bent spokes, look for debris in that area, try it without the correction tape, check that the correction tape is dry not tacky, also check to see if the pitch selection isn't in PS proportional space. If allis good the homing pawl spring is probably broken, you need a tech.
DickyO
Posted on Jun 29, 2009
I am setting up a Vision 1 action camera DragonTouch 1 for my grandson. How do I format the SD card that I purchased for tllhis?
Most SD card will fit in your laptop or tablet with an adaptor sleeve. Most laptops today automatically format new memory cards or prompt you to do so. Look on the side of your laptop or tablet for a hole about an inch by 1/8 of an inch slot. Insert the sleeve and follow the instructions. You can go old school and use the command prompt window and drive letter using the command help from the C:>
type help from the C prompt to see the proper commands
example
C:>format D:
or
C:>format E:
etc..
***make sure you have the correct letter or you will clear all the data from whatever letter you use.
Jan 10, 2018 | Action Cameras
Changing correction ribbon
First this is old school after hitting the correction you must press the letter you are trying to correct. if you knew this and the correction tape is properly installed and lifts up you may have old supplies, If you want to talk yuo can call me.
DickyO
216-269-3918
Dec 05, 2014 | IBM Correcting Selectric Iii Typewriter...
Letters are not printing correctly
try resetting the language with the lang key
Jan 29, 2014 | Nakajima AE-710 Typewriter
Typewriter won't type
check to see that when yu replace the ribbon it has not slipped in front of the print ribbon and that you have not got the button for corection pressed by mistake it is using this to print you letters not the ink ribbon
Jun 11, 2009 | Brother ML-300 Typewriter
Hi, my dane-elec showing write protected. How can I solve it? I tried http://www.fixya.com/support/t345484-format_write_protect_usb_drive file but did not work. Need help. Thanks, Zia
Click > Start > Run > type "CMD" Then
Type "CHKDSK" and type the letter of your SD drive and "/F".
chkdsk Q: /F > press Enter
another example:
chkdsk D: /f
chkdsk E: /f
D or E is the letter or your SD drive.
May 04, 2009 | Dane-Elec DaneElec 4GB USB Drive Copper...
PRINTER NOT PRINTING IN TRAY
Make sure the green part in the back of the tray is set exactly to the type of paper you are using. For example, make sure that if you are using letter paper, the paper size selector is set exactly on letter. if it already is try to move it off letter, and then line it up correctly again with letter.
Apr 03, 2009 | IBM Infoprint 1332 Laser Printer
MICRO SD
another example:
chkdsk D: /f
chkdsk E: /f
Aug 22, 2008 | iLO (2 GB) MP3 Player
Wrong keys printing
I have sent you the manual
Please could you rate my response
Many Thanks - Regards
TC
Aug 19, 2008 | Brother GX-6750 Typewriter
Wong letters & numbers
I downloaded the manual from http://www.devicemanuals.com/downloadguide.php and then, following the instructions there, I removed then re-inserted the daisy wheel. This solved my problem. Perhaps it had somehow gotten out of adjustment. At least, it is something to try if you haven't tried it already.
Jul 15, 2008 | Brother GX-6750 Typewriter
90 people viewed this question
Top Smith Corona Office Equipment & Supplies Experts
James Cagle
James Cagle
Hjalmer Lamminen
Hjalmer Lamminen
Jim Goldsmith
Jim Goldsmith
Are you a Smith Corona Office Equipment and Supply Expert? Answer questions, earn points and help others
