Question about Craftsman 26 Hp 54" Deck Yard Tractor
Hi, I have a Noma Lawn tractor and the hydrostatic transmission seems to be slipping, can you tell me how to troubleshoot the problem. Thanks Larry
This isn't a solution but a question...not sure what i should put in there...trany fluid or oil....i was cutting the grass and it stopped going forward or backwards
Posted on May 31, 2010
Transmission repair or replace
Jim, The links below are what I found on the Net., You could also do a search with your year, make and model# for possible better results. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Rebuilding lawn tractor transaxle Part 1 of 2
1 Hydrostatic Garden Tractor transmission rebuild 1 of 4 Hydro Gear
Tractor hydro transmission rebuild part 1
Part 1 K46 hydrostatic drive Removal
MTD Transaxle Basic Rebuild Replacing all Bearings Part 1 of 2
Aug 20, 2016 | Huskee Tractor Replacement Riding Lawn...
Hydrostatic transmission in YTH2348 is very weak, pulls intermittently then stops. I changed the oil put 50wt in it, still doesn't work.
hydrostatics will not work with gear oil they take transmission fluid . or hydraulic fluid check with a dealer or read you manual
Sep 15, 2015 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Model 917.203900 22 HP lawn tractor. Shifts consistently into forward but frequently won't shift into reverse. What's wrong?
  1. Craftsman Hydrostatic Transmission Fluid Change - YouTube
    ? 40:15
    www.youtube.com/watch?v=vd1EqFtTYgk
    May 10, 2012 - Uploaded by Smokeasammie
    I change the gear oil and hydrostatic transmission fluid on my Craftsman Lawn Tractor. Fluid per Peerless ...
Jul 20, 2015 | Craftsman Garden
How to change dive pulley for 944602660?
This is likely due to a worn and slipping belt. Replacing the belt should solve the problem
Aug 03, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
My riding lawn mower slips in and out of gear while going forward
Sounds like your transmission is shot if its a geared mower. If its a belt driven hydrostatic mower the belt is slipping and needs to be replaced.
Jul 18, 2013 | Garden
Husqvarna Riding Lawn Mower Yth24v48ls 48 Inch Cut hydrostatic transmission slipping
first i would check the belt tension also check the belt for oil is so look for the cause of the leak the repair the leak and replace the belt
Jul 30, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
How to fill hydrostatic transmission fluid on Poulan Pro
How do I check the transmission
How to Fill Hydrostatic Transmission in Lawn Tractor
http://husqvarna.custhelp.com/app/answers/detail/a_id/387/~/maintenance---what-type-of-oil-is-used-in-the-hydrostatic-transmissions%3F
Jul 28, 2012 | Poulan Garden
While using my Craftmas 17,5 hp lawn tractor with a snowblower attachment, the hydrostatic drive seems to loose power, especially when it working hard and after its been in use for a while. I don't think...
My name is Dane and I'm going to help you with your problem. First, I believe those craftsman units are sealed and there's no way to actually check the hydrostatic oil level. So the first thing to do is make sure that you don'thave any leaks around the transmission assembly. If it looks clean and oil free, I would venture to say that it is more of a 90% chance that your drive belt is the problem, however it isn't from icing up, but rather from the heat of the extra work from the weight of the snowblower, causing it to slip. The belt isn't all that expensive and before I would get excited and start worrying about transmission failure, I would just replace the belt first, and rule it out. Make sure all your pulleys and tensioners don't have any loose hardware, and look alligned.
I think you'll fix the problem though just by the belt replacement. I hope I've helped. Thank you! Dane
Dec 22, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 26 Hp 54" Deck Yard Tractor Logo
875 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
