Question about Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
Deck belt need to no how to put the belt on - Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
How to install a belt for a poulan riding lawn mower deck S#120403A001222 15.5Hp 38" 5sp
Posted on Aug 26, 2009
    Problem Solver:
  • 12 Answers
Put the deck on the lowest setting not all tractors are the same but it should have a picture of the belt routing. just make sure that you put the belt in all the guides around the pullys. then move the deck up so the belt is level with he pullys and put the belt around the motor pully.
Posted on Aug 09, 2009
  • 1 more comment
  • davidmcdaniel Aug 02, 2012
    i need a diagram of the belt around the pullys
  • Richard Ordal Oct 22, 2012
    I need a diagran of the belt around the pullys
  • don c Oct 22, 2012
    Look at the underside of the feet rest , ive seen the diagram sticker there
2 Suggested Answers
  • 138 Answers
SOURCE: husqvarna cz 4815 diagram to put deck belt back
there should be a routing diagram sticker somewhere on the deck. look at the back side of the deck in the middle
Posted on Aug 25, 2009
I HAVE A CRAFTSMAN 1000. I AM TRYING TO PUT NEW DRIVE BELT ON AND CANT.DO I NEED TO TAKE DECK BELT OFF TO DO IT?
most probably as most drive belts are above the deck belt owing to the fact that the deck height can be shifted
Jun 21, 2016 | Craftsman Garden
How does belt go back on for mower deck
Gary, Belt diagrams can usually be found on the Deck it self or in your manual. If you do not have either check the links below or Google search your make and model# manual.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Service Mower
Murray Belt Graphics
Craftsman Riding Mower Deck Belt Diagram
lawn tractor deck Belt diagrams Google Search
May 29, 2016 | Garden
Need diagramof ground drive belt asembly
I just put a new one on mine. Your owner's manual has a diagram. Should be a diagram on the deck close to right rear wheel.
Aug 06, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My Motion Drive Belt slipped of it's pulley on a Husqvarna Riding Mower Model 917-289570. Do I have to remove the rear tire to put the belt back on?
i had a 2148. you remove the mower deck as the first step. feed the belt over the pulley on top the transmission, then put it over the engine pulley. then have someone push the clutch pedal in so the tensioner pulley moves, put the belt in the guide pulley and on the tensioner. release the clutch put the deck back on and you are good to go. notice there are little keepers welded to the frame for the front, engine, pulley and it is easy to mistakenly put the belt over them instead of under them.
a general rule is that a pulley shaped like a Vee takes the V of the belt whilst a pulley which is flat takes the flat back of the belt. if you bear that in mind you will not have a problem putting belts back on. also there is a little decal on top the deck showing how the deck belt and deck drive belt go.
Sep 09, 2011 | Husqvarna Riding Lawn Mower 42 Inch Cut...
I am looking for drive belts for Sony Model TC-WR801ES stereo casette deck
All you need to do is measure the diameter of each belt in MM. Then put "Cassette drive belt ??mm" into Google and you should find a supplier. Belts are not generally specific to any maker. Also you don't need to be precise on the MM. If you are removing them to measure, make a note of how they fit first.
Oct 05, 2010 | Sony CASSETTE DECK Single Dual Cassette...
Trying to put a new drive train belt on my sit on murray lawn mower
Drive belts can be a pain. You are going to have to drop the deck belt out of the way and sometimes drop the front of the deck to be able to get the belt up around the front pulley. Feed it through the belt guards if possible...if not, you are going to have to loosen or remove the guards to get the belt where it is needed. Then loop around rear pulley, tighten guards, hook up deck and replace deck belt.
www.nnyparts.com
May 29, 2010 | Garden
Husqvarna cz 4815 diagram to put deck belt back
Aug 24, 2009 | Husqvarna Garden
Deck belt
go to partstree.com click mtd,then put in your model#;then click deck assembly. it will show you your belt routing;then scroll or click the item #.it should tell you the lenth of your belt.hope this helps.please rate this;thank;s
Jul 02, 2009 | Mtd Garden
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed Logo
900 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
