Question about Electrolux 18 in. ESL4114 Slim-Line Built-in Dishwasher
Dishlex 302 water not heating
I have a dishlex302 and the water is not heating in any cyle, i can not find the heating element or how to replace it could you tell me how to or email the service book.
thx
thorny6542@optusnet .com.au
My son fixed this problem with our DX302 dishwasher only this morning. Now works fine and hot. Found the solution on this site posted 11 august 2008 from dishwasher dishlex dx302wb no hot water. There are photos to help you. Take out the circuit board in the top of door and resolder the points on left hand side of green board there are 2 long solders and a half moon. The problem is at the top of the 2 long solder lines. Do not replace your element. There is a fault with the circuit boards on this model 302. I want to thank all the posters for helping me fix my no hot water problem.
Posted on Jun 27, 2009
  • Bridget Dec 13, 2010
    Just fixed our problem with DX403 and its working HOT, thanks for the great solution. My husband had to resolder it twice before it worked, and so far so good.
  • petersmyth79
    petersmyth79 May 07, 2012
    the problem is not enough solder on the joints for the relay, if there is future problems i will add a solid state relay somewhere inside the control panel away from the pcb and wire it to the trigger connections on the board, i also located other "dry joints" on the pcb, i think the soldered joints for the relay will go again because of the relay's mass not being supported on the pcb other than the soldered joints, a remote ssrelay would cure it permanently
I found a break on a solder line on the back of the control panel circuit board. It is easy to see as there is a burnt spot where the solder is meant to be. I simply resoldered the line, washer now heats and washes as before!
Posted on Dec 13, 2009
  • schtormcloud Dec 27, 2010
    We had soldered that joint but still no hot water.
    Any ideas.The element reads 27 ohms so i assume that it is fine.
DISHLEX DX302 REPLACE HEATING ELEMENT
Remove the device and then restart again
Jan 25, 2014 | Dishwashers
I have a dx302. its not heating the water or drying.
download this manual...
http://epubl.luth.se/1402-1617/2006/118/LTU-EX-06118-SE.pdf
Aug 22, 2008 | Electrolux 24 in. EDW5505EPS Stainless...
Hello - I have an Electrolux Dishlex DX302 dishwasher. The washer works okay - but it doesn't always empty the contents of the dishwashing powder in to the dishwasher. It is often wet and stuck in the
If you have hard water, you should reduce the amount of detergent you use. Here's a map showing water hardness in the USA. http://www.citriclean.net/why-citriclean/
Nov 23, 2013 | Dishwashers
No drying cycle on the electrolux dishlex 302 any idea's
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Nov 10, 2010 | Electrolux 18 in. ESL4114 Slim-Line...
Elextrolux dishlex DX 302 - not cleaning dishes properly and dishes still wet after drying
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Sep 12, 2010 | Electrolux 24 in. EDW5500DSS Stainless...
Dishlex Global Unable to remove heater element retaining screw
I have a simialar problem with the Dishlex 450 Global model, after searching for the heating element on line, I found a picture of the element (450 model), showing that the Stainless Steel screw is actually spot welded to the element bracket, hence you should be able to remove it by accessing a retaining nut from underneath the dishwasher....(turn power off first!)..
May 24, 2009 | Electrolux 18 in. ESL4114 Slim-Line...
The dishlex 302SB is not producing hot water for the washing
I have a Dishlex 302 which had this fault. Initially I thought it was the inline heater element and replaced it. It seemed to work but later no hot water again. Someone here put me on to the problem. There is a dry joint in the control board in the top of the door. This controls the relay which powers up the heater. Unplug it from the mains (very important) and undo the screws around the top of the door (don't take the door right off!) you will be able to wiggle off the front panel containing the electronics. The control board is ealiy disconnected an removed from the machine in its protective plastic cover. Have a look around the PCB and you will see the dry joint. Resolder with rosin core (electronic) solder, reassemble and you should have hot water.
May 23, 2009 | Electrolux 504199 Dishwasher
Vulcan dishlex 750 eco taking alot longer to complete wash cycle.
How is the water flow into the machine. Are all your inline filters clean?
Apr 05, 2017 | Dishwashers
Dishwasher
If your water level is below the heating element that is normal after a wash. Some unit the water will not always drain (relates normally to low water pressure or hose length or height)
If your water level is below the heating element and your dishes ALWAYS clean then its fine, the water drains out before a new wash so you are not using the same water
if water is above heating element, run garbage disposal to clear lines if one is installed, if not you could have a clogged line/hose/sump/filter
May 02, 2008 | Dishwashers
Dishlex dx 302 heat drying
Found I had no hot water in my Dishlex DX302 and did a google search and found this page.
My problem was found to be the same as the others; one of the solder joints on the relay on the control board had arced off.
You could see the burn mark on the board and cover where it had been arcing.
Soldered it back together, and now it seems to be going good again.
Now my only problem is a damaged door seal, which means a small water leak; I have used part of a rubber glove to bridge the gap, and it reduces the water leak.
Sep 22, 2007 | Dishwashers
Electrolux 18 in. ESL4114 Slim-Line Built-in Dishwasher Logo
4,143 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Gerard Curran
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
