Question about Kenneth Cole KC3289 Wrist Watch
Shortening the Length of a Metal Wrist Band
I have just recently bought a watch which has metal wrist band made up of links.
How do i go about shortening the metal wrist band to the desired length?
  • 10 more comments
  • Anonymous Nov 11, 2007
    I purchased a St. Moritz Aquamatic and need to shorten the band. How do I do it?
  • Anonymous Nov 13, 2007
    need to shorten band
  • Anonymous Nov 15, 2007
    Don't know how to remove links from the metal band. Need help.
  • Anonymous Dec 19, 2007
    Have not taken steps to shorten
  • Anonymous Dec 25, 2007
    I dont know how
  • Anonymous Jan 31, 2008
    help no instructions in box
  • Anonymous Mar 01, 2008
    I have a Festiva watch with a metal writ band. It's just a little too long. So I've purchased (online) a little device that will clamp onto the wrist band and "push" the link pin out. I've been able to do this. However, now that I've removed the link needed, I'm not sure how to insert a "new" link pin. The device has a couple of extra pins, but when I load the new pin and it's "outer" cover, I cannot use the "push" device to place the new pin.....how do I do this??
    rswoboda@comcast.net
  • RJSwoboda Mar 01, 2008
    I've bought a little plastic device that I can place the wrist band to that I can use the tiny driver to "push" the link pin out fo the wrist band and remove a link. I've been able to figure that out. Now I'm trying to put the new link pin back into the band. I can set thie up, but cannot fit the band with the "start" of the new pin in the device to "push" the new one into the band.....suggestions on how to do this??
  • Towo Apr 04, 2008
    Where can I buy a suited screwdriver if necessary to reduce the length of the wrist band?
    May be it should be enclosed with a new watch?
    Krgds
    Tom Wollan
  • Anonymous Dec 30, 2008
    same problem
  • tony54964 Jan 04, 2009
    i have a new swiss legend watch with metal band, how do i shorten it?
  • hoangkhoi Mar 06, 2009
    shoterning the length of a wrist band
I just did this for my wife's new Kenneth Cole wrist watch rather easily. You don't need a screwdriver, but a short section of a paper clip will do. I just set the band on a raise surface to allow room for the pin to be pushed out using the paper clip. For this watch, one side of the pin resembles the slotted side of a small screw - but it is not a screw. This is the side that bulges up a bit to help the pin stay in place. I believe if you punch it out from the opposite side it will fall off quickly, but if you do from the bulged side it, too, will come out but with some resistance. To reattach the band you need to punch the pin into the slot in such a way that its bulged side is on top otherwise you may end up with a bent pin. You must also first line up the hole with the paper clip before reinserting the pin. Good luck.
Posted on Mar 11, 2009
Take your watch to a jeweler and they should do it for you free of charge.
Posted on Aug 03, 2008
Changing the wristband on Charge 2
What sort of wrist band do you have? Metal or leather/plastic? Make sure the spring pin is properly inserted into the holes on the watch. Sometimes if there is tension in the wrist band the spring pin will not expand all the way into the hole and thus will come out when putting the watch on the wrist.
Jan 10, 2018 | The Watches
I am trying to figure out how to shorten the wrist band on my Casio Edifice EFA-119.
mcdevito75 here, If your Casio has a metal band, you can remove 1--2 links, this takes a special tool called a link remover, best bet is to look for a small watch repair shop in your area. If your Casio has a strap, the buckle may be able to move up the strap to fit your wrist, if so, move the buckle up the strap to fit your wrist and cut offf the exccess strap. If not, you"ll have to replace the entire strap. Hope this helps.
Aug 03, 2010 | Casio Edifice EFA109-7AV Wrist Watch
Watch strap a little big
mcdevito75 here, Maybe a link or 2 can be reoved from the metal band, or an adjustment at the clasp can be done. Look for a small watch repair shop in your area, they can help.
Jul 08, 2010 | Casio A168W Wrist Watch
Remove links on this watch
Most bands have removable links on the end of the band. You can tell because they have small holes on the side to remove the pins that hold them together. The links that don't have holes are not removable. This is standard on most metal bands.
May 09, 2009 | Timex Atlantis 100 77517 Wrist Watch
My grandson has had two Ironman watches with a
good day,
hope this link below will solve your problem.
watches
Feb 19, 2009 | Timex Ironman 30 Lap 53952 Wrist Watch
Broken wrist band
The easiest is to bring it to Wal-Mart, or another store with a watch section in their store, if you buy a new wrist band, they;ll put it on for free. If you're feeling DIY, pull the watch band to the side, untill the metal bar inside is ejected form the slot in the watch, from there, insert the new band's bar into the slot, and voila!
Nov 15, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
Skagen 596XLTXM Titanium Mens Watch
good morning ! you need a puncher pin and anvil to remove the pin on your watch band punch or push the pin use the puncher pin according to the arrow sign,full the pin to remove,and fush to fix again,do it carefully,thank you ! god bless .
Aug 27, 2008 | Skagen 355LGSC Wrist Watch
Kenneth Cole KC3289 Wrist Watch Logo
2,309 people viewed this question
Top Kenneth Cole Watches Experts
Jimmy Accardi
Ansel Alberto
Ansel Alberto
Are you a Kenneth Cole Watch Expert? Answer questions, earn points and help others
