Question about Linksys Wireless-G Broadband Router
Will not detect a connection to internet
When i set up my wireless g broadband router it will not detect an internet connection. When i dont have it connected i have a connection.
Whats the deal with that?
  • 390 Answers
Hi
instead of connecting the cable from the modem to the Internet port on the router connect it to one of the ports numbered 1,2,3,4 and hopefully it should connect
also check the channel at which the laptop and the router are communicating
also check the ip range that the router is adjusting itself to
hope this helped
cheers
PS: if this was anybit useful pls rate the solution, thanks
Posted on Jun 27, 2009
My laptop can detect the wi-fi but I cannot connect to the internet. What is wrong with my router? Please help me out. This is a new router by the way.
routers have a limited bandwidth.. but some routers need to register your laptop serial to be able to connect to the internet.. there is a permission to allow your laptop to use the wireless connection.. check your wireless connection setting, then choose your router name, then try to connect..
May 21, 2011 | Edimax BR-6226n nLite Wireless Broadband...
I dont have the drivers for NETGEAR 54 Mbps wireless Router WGR614 v7. I want to connet my BroadBand connection to my Router I want to use my LAPTOP without wireless. kindly assist me about the...
Hello, I dont think you need the drivers for Router. And first of all you need to connect your modem to your router through ethernet cable. And after connecting your modem, configure your wireless router by typing this IP address in internet explorer: 192.168.1.1 The user id is admin and the password is password. Then detect your broadband connection by using the option in the router. Try connecting your Laptop to wifi after setting the connection.
Nov 02, 2010 | NetGear WGR614 54Mbps Wireless Router...
My lynksis router can detect the signal of the broadband connection but it cannot access the internet. when u try to browse any website it always says 'Error 105 (net::ERR_NAME_NOT_RESOLVED): The server...
This sounds like the router does not have DNS settings.
Check the web configuration to make sure that the DNS settings are valid. If there are DNS servers in there, try changing them to 8.8.8.8 and 8.8.4.4 and see if you still get the same problem.
Hope this helps!
Oct 18, 2010 | Linksys Wireless-G WRT54G Router
I bought WRT54G2 router , but could not detect the broadband connection ,,,
do you have the broadband modem plugged into the wan on the router and is the cable you are using good. and also check to see if your internet is working. you should be able to connect your computer to the modem and get internet. if your broad band requires you to log on the modem before you get out you will need to connect directly to your router and set it up per the instructions.
Dec 24, 2009 | Linksys Wireless-G WRT54G Router
Just set up my g broadband router. Unable to connect to internet
Your laptop may not support g wireless. Change the wireless to broadcast B and G
Nov 15, 2009 | Linksys Wireless-G WRT54G Router
Computer repair tech said Linskey wireless caused internet prob
If you are using DSL as your internet connection there is a timeout period that could be setup in the linksys.
In order to change this you need to log into your router and on check on the setup page. You see the timeout option.
Check with your linksys manual for detailed instructions for logging into the unit. If you dont have it, you can always get it from their website.
Jul 31, 2009 | Linksys Wireless-G Broadband Router
Linksys wireless-G router configuration on PPPoE internet connection
Connect modem to the internet port of the wrt54g
Connect pc to port 2 of the wrt54g
Reset the wrt54g, push reset button for 30seconds with the power on, uplug the power for 10 seconds
Open internet explorer, type 192.168.1.1, you will be asked to login, no username, password is admin. This will take you to the router page. On the page you will se AUTOMATIC CONFIGURATION DHCP, change that to PPPOe, enter your broadband username and password. Click save settings at the buttom of the page. YOU WILL ONLY GET CONNECTION IF YOUR USERNAME AND PASSWORD IS CORRECT.
GOOD LUCK
Mar 14, 2008 | Linksys Wireless-G Broadband Router
Iam not able to connect to internet via wireless router
Need more information to help you.
1. If not using the router at all is there connection to the internet??
2. When working woth a utp cable between computer an router is there internet connection??
Don't forgett getting connection with your wireless network is not the same as gettin connected with the internet.
Suggestion: Clone your computer MAC address in the router.
Jan 23, 2008 | Linksys Wireless-G Broadband Router
Broadband Connect Manager
problem on connecting to internet by t-mobile broadband usb stick 110
Dec 19, 2007 | Sprint PCS Merlin S720 Mobile Broadband...
Router
click start, control panel, internet options, connections tab, remove anything you see in the "dial up and vertual private network, click on LAN Settings, the only one that should be checked is "Automaticly detect settings, click ok and close all. open internet explorer if problem still there disable firewalls.
contact me if you still have issues.
Nov 04, 2007 | SMC Barricade g SMC2804WBRP-G Wireless...
Linksys Wireless-G Broadband Router Logo
164 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
