Question about Maytag Neptune MLE19PN Front Load Stacked Washer / Dryer
I have a Maytag front load dryer. When you push start everything runs good except the gas won't kick on. I have vacuumed out inside between the walls and drum, removed the lint filter and shoved a plastic tube down it and vacuumed it out, removed the exhaust hose off the back and vacuumed into the dryer and cleaned the whole length of hose and went outside and checked the exhaust hole. All is clean. What is my next step
  • 46 Answers
First make sure gas is on then turn it on and look at the ignighter should be as brite as the sun if so you will here a click when tha gas is to come on and you get nothing then the coils are bad easy fix make sure you unplug it then unplug coils 2 screws that hold it down you can not put them in wrong
Posted on Jun 26, 2009
Dryer won't start and has a burning smell.
there should be a fan in the unit that blows air over the element and through the clothes
there should also be a thermostat that sets the element temp to low mild or hot according to the switch on the front
Jan 20, 2016 | Maytag Centennial Series MEDC300XW
Maytag Neptune Dryer MDE3000AYW. Replaced pulley and arm (pulley was seized to it), rear drum wheels, front drum glides, belt. Cleaned throughly inside. Worked like a charm for about 6 loads. Went to hit...
I'm guessing that your belt my have been misaligned, which means, no problem!
But, I recently had a machine that had a motor that would not turn, only hummed. I vacuumed the lint, then blew the lint out of the motor with a compressor, and vacuumed again. It still needed a push start to get the motor turning, but it starts on its own, now. So, if you have a lot of lint buildup, it can eventually stop the motor
Mar 06, 2017 | Maytag Dryers
My maytag dryer got to hot heating a blanket and now it won't work at all. When u push the power button I feel it wanting to kick in but it won't do anything!! I know nothing about dryers Help...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 04, 2011 | Maytag Dryers
When we push the button to start dryer it buzzes, it won't go and won't dry clothes. maytag admiral dryer ADG7005AWW
heatman101
May 19, 2011 | Maytag ADG7005AWW Gas Dryer
My dryer running but not heating. What's wrong
take a putty knife just inside the front corners push in the top will lift up then on the inside there are two screws that take the front off
Jun 08, 2010 | Maytag MDG5806A Gas Dryer
Maytag gas dryer, model #MDG7600AWW does not turn on
a thermal fuse should read shorted until it gets hot .. the buzzing you hear might be the motor running but not turning the drum .. that would be a broken belt .. the motor is spring loaded to keep the belt tight ..the belt is long .. it goes around the drum and down to the motor ... belts are available at many appliance parts shops .. changing it is not hard for someone handy .. a bit more than you would want to handle if you are not mechanically inclined ... on some maytags the whole front of the dryer comes off with just two screws near the bottom .. that makes servicing much easier ..
Sep 12, 2009 | Maytag Dryers
When I push the start button on my maytag neptune dryer it sounds
MORE TIMES THAN NOT, WHEN I HAVE SEEN THIS PROBLEM, IT TAKES A NEW MOTOR TO CORRECT THIS SITUATION. MAKE SURE EVERYTHING MOVES FREELY BEFORE CONDEMNING THE MOTOR THOUGH.
Jan 29, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag 5806 Gas Dryer starts and suddenly stops.
You may have a problem with a thermal overload sensor. Since it runs and then shuts off, this sounds like the problem.
Dec 29, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Maytag dryer will not start completely.
replace motor it would hold a load and is kicking out on over load switch
Dec 08, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MLE19PN Front Load Stacked Washer / Dryer Logo
75 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
