Question about Refrigerators
The compressor buzzes but will not start. it tries to start for about 20 seconds and then stops for a few minutes before it tries again.
  • 82 Answers
The problem most likely is a failed start relay located on the compressor itself. Other possibilities are a burnt and broken wire on the compressor from running hot or The compressor itself may have failed and is "tripping" on it's thermal or current overload.
Posted on Jun 26, 2009
  • 46 Answers
Bad over load or comp if there is a condencer fan on it make sure its working
  • appliancerp Jun 26, 2009
    bad over load or comp if there is a condencer fan on it make sure its working
Whirlpool ed25dq Not Cooling
Unplug unit from the wall, remover the start relay from the compressor and shake it. If its solid possible bad compressor, if it sounds loose (broken part) then most likely bad relay. Verify your model number as you are missing some letters.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Dec 13, 2013 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore 7.5 freezer stopped working.
Thanks for all the suggestions. I just replaced the overload relay and it does the same thing. Runs for a few seconds and the loud click from overload relay. I did notice the relay is really hot to the touch, if that matters.Coils on back are clean. I had noticed the last few months that the inside coils were frosting up quite a bit.Really had hoped it was the relay.
Dec 04, 2012 | Kenmore 7.5 cu. ft. / 212 liter Upright...
Switch on fridge and compressor runs for a few seconds and then stops, switch off for a few minutes and then switch on again and it runs for a few seconds. Checked thermostat and seems to be OK
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 17, 2011 | AEG Refrigerators
Amana refrigerator/freezer started making a buzzing noise and stopped working. Inside lights do work, but nothing cools.
based on your description i would guess that the start relay on the compressor has failed or the compressor it self is the buzz you are hearing... if the noise would come and last for 5-20 seconds and then stop or click sound made then that is the compressor trying to start but kicking out on overload. it usually after sometimes a few minutes or sometimes in thirty minutes will try again once the compressor gets hot enought it may take longer.. you will have to gain access to rear of unit and on compressor is a relay that may have failed. make a drawing of the wires and remove sometimes (2) seperate pieces see if it rattles or smells burnt. if so get you a new relay and may have caught it early enough to not have done any other damage... repost with anymore questions good luck to you...
ps there are several web sites to order the parts online or go to a local appliance store...
www.sears.com hit the parts direct link up top of page then enter model number
www.repairclinic.com
www.apdepot.com reputable companies...
Feb 11, 2011 | Refrigerators
Every 3-4 minutes the a very loud buzzing sound occurs for ~20 seconds. It sounds like it is coming from the compressor area. The fridge and freezer are both working well.
It sounds like the starting components on your compressor are bad. the buzzing is your compressor trying to start and then shutting down on its overload. You will need to replace your starting components on the side of the compressor (start relay and overload) which will usually come in a kit together. Good luck _MJ_
Apr 23, 2010 | Maytag MZD2766GES Side by Side...
Compressor stops running and keeps cycling every few minutes. It buzzes as if the compressor is gone. the compressor is hot. If the thermostat is turned to off for 6 to 8 hours and then turned back on the...
you can replace the relay with a 3 in 1 made by supco. i generally just use a supco 0410.
www.supco.com
it is a start relay, overload, and start capacitor all in one. works great for residential systems.
Nov 06, 2009 | Frigidaire FRS3R5EMB Side by Side...
My air conditioner is on but not blowing cold air and buzzes
The compressor is not starting. The buzzing noise you hear is the compressor trying to start and then the thermal overload trips. When it cools it will try to start again. Could be a bad capacitor or the compressor is bad. These two units need to be tested to see which one is bad. A capacitor is inexpensive. If it's the compressor it will be cheaper to buy a new AC.
Aug 21, 2009 | Heating & Cooling
My refrigerator buzzes for 5 or so seconds then
the buzzing noise your hearing is possibly your compressor trying to start up. this is generally a buzzing for 5-7 seconds followed usually by a click noise if it goes on for several hours you will notice the temps in the unit starting to rise. for alot of may tags with the tecumseh compressor the compressor had to be replaced. if it has an embraco compressor you can just replace the start relay on the compressor. let me know what you find thanks Peyton
Mar 06, 2009 | Maytag MSD2756G Side by Side Refrigerator
Refrigerator buzzing for 10 seconds every 4 or 5 minutes
Buzzing is usually a fan, like one in the freezer, or back bottom - for cooling the freon. The compressor over-heat usually will make a single click (off) and a few minutes later a click (on). If the fan in the freezer stops working well, the freezer will frost up and the fridge section will not be cold enough.
Apr 20, 2008 | Refrigerators
Refrigerators Logo
146 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
