Question about Maytag MDG2706A Gas Dryer
My husband is right now hanging a belt in out
My husband is right now trying to put back a belt in our Maytga gas dryer but he couldn't do it. can i seea a picture of the right way? or we can follow steps if you have a guide for us.
I appreciate your help and time thanks.
Angie
  • 46 Answers
Angie tell him to stop relax it is a bit of a pain to do it must be done fron the front patince it will go
Posted on Jun 26, 2009
Need help putting new belt back on Admiral dryer model ADG 7005 AWW, possibly a diagram?
Hi bgpace02669..
To to this webpage to see a picture of how to route your belt.
Please take time to rate me
http://www.expertappliance.com/dryerbeltconfiguration.html
Jul 09, 2011 | Maytag ADG7005AWW Gas Dryer
The belt for the dryer is not in place and the dryer is not longer spinning. how would i fix that? There is also a piece with a wheel on it that i cannot figure out where it goes but looks as though it is...
Look up "Tension Pully & Belt Diagram" on internet for your dryer on google or Dogpile. You should be able to find how to
put the Tension Pully back where it belongs & how to thread the belt through it and back on to the motor drive shaft. Check different sites for the right picture for your dryer. Here's a picture to get you started. Good luck,
Sep 13, 2010 | Kenmore 500 6952 Dryer
The belt broke on my Whirlpool super capacity dryer (23 years old)model number LG7686XPO. we are able to get the belt could you plase send us a diagram of how the belt goes on? and some directions...my...
Your belt will use one of these configurations. Just right click on the picture, copy & paste it into a document or save as and them open it with a photo viewer.
Jun 30, 2009 | Dryers
I HAVE AN AMANA GAS DRYER THAT MAKES A VERY LOUD
Here is the link for the owner's manual, but it doesn't look like much help. Just cut and paste on the address bar of your browser. http://shop.amana.com/assets/pdfs/literature/40125301.PDF
Once you get through looking over the manual, here is how you fix your dryer:
  1. Unplug the power plug, disconnect the gas line, and vent hose, and pull out where you can access all sides.
  2. Take a putty knife and insert it between the top and the cabinet at the front corners to release the spring clips.
  3. Flip the top toward the back making sure the wiring harness to the timer and controls does not get pulled.
  4. Take off the access panel toward the bottom of the cabinet, push the belt tensioner away from the belt, and pull the belt off of the motor pulley.
  5. Lift the drum out of the cabinet, clean and re-grease the ball and socket at the back of the drum, clean off the surface where the belt rides with steel wool.
  6. If the idle rollers turn freely, clean the lint off of the surfaces, put the new belt on the drum and lower back into place.
  7. Put the belt back on the motor pulley, put the bottom cover back on, flip the lid closed, reconnect the gas, vent hose, and plug in.
If you found this solution helpful, please don't forget to rank it.
Mar 27, 2009 | Amana ALG331RAW Gas Dryer
My whirlpool estate dryer tub will not rotate
To replace the belt unplug the dryer, remove the lint filter, remove the 2 philip head screws,with a stiff putty knife pry up in the top of the cabnet on the right and left to litf the top, disconect the door swithch remove the screw from each side and lift the front off romove the old belt the reinstall put new belt around the drum groove side toward the drum. put the idler pully in the slot closest to the motor be sure the tab is under the base and the 2 catches stit in the slot. now pull the belt through the idler pully and around the motor shaft. the reinsatll the front secure with the screws reconect the door switch,close the top, put the 2 screws back in where the lint filter goes then put in lint filter, plug in dryer and test.
Jan 19, 2009 | Estate EED4300SQ Dryer
Dryer spins counter clockwise
When installing new belt the belt comes off the right side of the drum and through the idler and around the motor shaft, then up the left side
Jan 07, 2009 | Whirlpool LGV4634JQ Gas Dryer
Need to know the exact way to put belt on ge dryer model number DDE7200RALWH cant figure it out around the pulleys , ge assures its the right size belt for the dryer , but belt seems loose and drum wont...
with belt around drum, pull idler back with tension on it and put belt over pulley of motor and let idler up against belt and it should be right ,,,, larryyb
Dec 10, 2008 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
LER6636PW0 drum does not turn
hi fakestar,
here is an exploded view of the dyer, and you can see where the pulley came off.8dd05ba.gifpart number 24 are the pulleys.
another picture is for the belt and the tensioner
1e696ba.gifpart number 53 is the tensioner and part number 56 is the belt.
it just tricky on how to put the belt.
first put the pulley back to its location then slowly insert the drum to the dryer while putting the belt around the drum with the grouve of the belt facing the drum.
have a helper hold unto the drum , in place, then lean underneath towards the motor and put the tensioner to its slot at the flooring, just like in the drawing, then insert part of the belt under the pulley of the tensioner then with your left hand, hold the tensioner pulley and with your right hand, grab the belt which you inserted under the pulley, and bend the tensioner towards the right with your left hand while the right hand is pulling the belt towards the motor until the belt loops to the motor's pulley.
i hope i was able to explain that one.
that is really tricky to put on.
tnx 4 using fixya,
drcool
Oct 10, 2008 | Whirlpool LER5636P Electric Dryer
Trying to replace belt
Wherever you got the belt, did they need to know th Make? We do... lol
Geno
Mar 17, 2008 | Dryers
Intermitten heat
We have a Neptune Gas dryer,my husband changed the belt cause it was making noise,now the heat hardly works,i put the dryer on for 40 minutes and usually it is dry,now i did that twice and clothes is still damp,would you know what the problem is please help
Jan 12, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Maytag MDG2706A Gas Dryer Logo
266 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
