Question about Refrigerators
My GE side by side ice maker is dripping water and not making ice. Even in the stop (bar up) position water still flows into icemaker
  • 3 more comments
  • Lee Arslan Jun 26, 2009
    Water is just dripping from the bottom of the housing randomly
    Model # TPX21PR or TPX21BR
    It's dripping at a quick rate. Not just a drip every few seconds, but constant
    R u there? Don't quite know how to use this site...
    Looking for support on a GE Profile side by side fridge/freezer with a constant water drip from the lower housing on the ice maker unit. Even in the "stop" bar up position, water keeps flowing to ice maker. currently have big bowl in freezer to catch drips. Model #TPX21PR/BR
    Sergeant:
  • 160 Answers
At some point the faucet for lack of a better word gets old and leaks that's what happened with my old whirlpool side by side. The part was expensive so just replaced the fridge. You can also, and I suggest this adjust the amount of water going into the ice tray before you start trying to replace that faucet.
Posted on Jun 27, 2009
  • 15,935 Answers
Please click the "Continue with this Expert" option and reply with your exact model # so I can be of more assistance and help you troubleshoot.
Also - where is the water dripping? Is the icetray overflowing... or is it dripping from the tube?
Thanks :D.
Posted on Jun 26, 2009
  • blueextc3221
    blueextc3221 Jun 26, 2009
    Model # please?
  • blueextc3221
    blueextc3221 Jul 02, 2009
    The dripping water is from your double outlet water valve not closing all the way - either from a faulty solenoid or build-up in the valve that does not allow full closure when the icemaker is not calling for water.
    CLICK HERE to see the part you require.
    Thanks for using FixYa!!
    This is an attempt to follow up on a question you submitted that remains open on our open work queue.
    Experts on FixYa work hard in an attempt to troubleshoot problems remotely.
    Returning to your account and rating My (or the person's that helped the most) answer is appreciated...
    As after 7 days, the fee you paid is credited to the very first Expert
    to reply - even if it was not related to your problem or helpful to you.
    If you need additional help - please use the "Continue with this Expert" option so we are connected in the future.
    In any case - please rate as FixYa to remove your question from the Work Queue.
    Thanks for using FixYA!!
The drip pan is filling up with water and then over flowing. We have to empty it once a day. Then I noticed the ice maker has stopped making ice. Any ideas?
Turn icemaker off see if water problem stops ice tray water valve may be overflowing tray cycle timer may be faulty or faulty water control valve.
Jul 31, 2015 | Whirlpool Refrigerators
Frigidaire Superba Ice maker - no water flow
Testing the ice maker:
As far as the smaller line (1/4") you have to manually advance the ice maker and wait for it to call for water with the 1/4" line disconnected from the valve. For whirlpool and its subsidaries,you can do this by getting a jumper wire, removing the cover of icemaker, which you jsut grab and pull off, and using the jumper wire insert one end of the wire into the cirle marked m and the other in the cicle marked n. Leave there until you hear a click and sometimes see a little spark behind the modular head wheel. For GE, you turtn the ice maker off, wait about a minute then turn back on, water should automatically shoot water in the icemaker. That will tell you the water valve is good and icemaker is bad, or the ice maker is good and the valve is bad if no water. Also if you see ice in the maker that hasn't dumper and the teeth of the icemaker are facing any direction other than two o clock position, the icemaker is bad. Also check the fill tube to be sure the no ice is blocking water from coming in.
Jun 06, 2012 | KitchenAid Superba KSBS23IN Side by Side...
The water dispenser in my refrigerator ice maker is leaking
if you have recently changed your filter, had the water turned off, or disconnected from the ref this is a common problem. you have air in your water line. fill 5-6 large cups of water or until it stops spurting and your drip should go away
Apr 23, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Icemaker clogs with ice. Water flows with icemaker unplugged.
ur solenoid could be allowing water to flow freely its in the back its blue try replacing this solenoid and see if this fixes the problem they r cheap and easy to change
Feb 27, 2010 | Amana ARSE67RBB / ARSE67RBW / ARSE67RBC...
GE TFX22ZR side by side. ice maker not making ice
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
A strainer before the inlet valve can also get stopped up restricting flow.
Oct 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE adora side by side refrigerator DTL181C5RRBS
Sep 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker dripping water even in stop position (bar up) and keeps supplying water to device. water dripping from the bottom of the housing unit at a steady rate.
unplug ice maker if you still have water coming in fill valve is stuck on back on the bottom if not more than likly icemaker bad
Jun 26, 2009 | GE Profile 20.7 cu. ft. CustomStyle...
Bosch Side by Side, top shelves dont freeze food, bottom does
majority of refrigerators today are equipped with an automatic icemaker. The water valve supplying the icemaker is a key component of the icemaking system, and it should be the first thing you check if the icemaker's performance is erratic or if the icemaker stops working. When the icemaker calls for ice, its switch closes an electrical circuit and energizes the solenoid-operated water valve. This allows water to flow through the valve and into the ice cube tray. The water is frozen into cubes, and the cubes are dumped into the ice bin. As time passes, strange things may happen to the refrigerator's icemaking capability. The cubes may be small or there may be a solid chunk of ice instead of individual cubes. It's also possible that the icemaker will stop working. These are all signs of a malfunctioning water valve. The valve is equipped with a screen on its inlet to remove minerals and sediments in the water supply. Over time, minerals and sediment build up on the screen and restrict flow through the valve, or even block it completely. Minerals that make it through the screen can cause the valve to stick in the open position, overfilling the ice cube tray in the process. This is a common problem in areas with hard water, but it can happen just about anywhere. Another malfunction that will cause the icemaker to stop working is a break in the solenoid coil winding. This is known as an open coil. The coil winding generates a magnetic field as current passes through it, and this magnetic field opens the plunger valve that controls water flow. A break in the coil winding stops current flow and this prevents the valve from operating. Test And Inspect The icemaker's valve is easy to inspect and test. First, gently pull the refrigerator away from the wall, and unplug it. Turn off the water supply to the icemaker by closing the shut-off valve in the copper waterline leading to the valve (Fig. 1). Use a screwdriver or nutdriver to remove the rear lower access panel from the refrigerator's back. Next, remove the fill tubing from the water valve. Use a wrench to loosen the flare nut on the brass fitting on the inlet side of the valve (above). Place a container under the valve to catch the small amount of water that will spill from the valve and tubing. Now use a screwdriver or a nutdriver to remove the screw holding the valve's mounting bracket to the refrigerator cabinet (Fig. 2). Pull the valve out of the compartment and remove the tube on the valve's outlet. Then, remove the solenoid's electrical contacts (Fig. 3).
Mar 29, 2009 | Bosch KGU66920 Side by Side Refrigerator
Refrigerators Logo
65 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
