Question about Philips Televison & Video
Fail to initialize, fail to erase blank DVD+RW
I have a Philips DVDR 3480. Lately, whenever I insert a blank disc, it fails to initialize, prompting me to erase the disc, but fails to do that. It records already initialized discs well, and plays fine otherwise. What can I do to repair this?
5 Suggested Answers
SOURCE: dvdr 3480/05 user manual
Try the philips website for the user manual.
Posted on Jan 04, 2009
  • 46 Answers
SOURCE: LG DR275 Initialize problem
hello..Carol..please refer to your user manual and look in the chapter that includes "how to" maybe you don't have to manually initialize the disks..this will be done automatically...keep it easy...please tell me how it went !...good luck...Ron
Posted on Mar 07, 2008
sandie3796
  • 132 Answers
SOURCE: How can I reset a Philips dvdr 3505 to it's
Press setup on your remote. Use up or down button to select( general settings ) press ok. Use the up or down buttons to ( reset all ) then press ok. Use the up or down button to ( yes ) press ok Use the up or down buttons again to select (yes) press ok. That should do it. If this works give me a vote please.Good luck.
Posted on Mar 03, 2010
Testimonial: "Yep that did help/work :-) thank you for such a fast response to a very frustrating problem. :-)"
SOURCE: Philips dvdr 3480 disc draw refuses to open
Illustration:
This usually happens when you close the drawer with no disc in it. There is a strong magnet inside the DVD-drive that keeps the spinning disc in the correct position. But when the drive is empty, the magnet is connected to tough to its counterpart (no disc in between) and the worn out motor and/or transmission (belt) is not able to pull them apart in order to open the disc tray.
How to fix - "brute-force-attack":
Press OPEN and give the disc draw a couple of decent slaps (or snap at the tray cover with your forefinger) until it opens. Repeat procedure, if motor stops before drawer is open.
How to fix - "high-tech-approach":
Disconnect power chord. Locate the slot provided at the bottom of the device, near the smaller, left clip holding the front panel. Insert a screwdriver into it at the far right (when viewing from the front), so you can push a small white plastic-lever-thingy (can be seen thru the slot) to the far left. Now the tray is partly opened and can be pulled out completely.
Future outlook:
Don't you never ever close your old machine with no disc in the tray - or just start over again...
Posted on Mar 23, 2010
This pioneer DVD player is rejecting all disks. Kindly assist
Most dvd players (or anything with a laser) will fail eventually. If the laser failed, there isn't much point trying to get it repaired.
Oct 21, 2013 | Pioneer DV-420 Black 1080p HDMI...
I have a philips audio recorder cdr 760 When i try to record cd rw a blank audio tdk cd the machine said OPC FAIL What I have to do to record the cd rw on my Philips cdr 760 Thanks for your...
There are a lot of forums which discuss OPC failure and it strikes every hardware maker and brand of media.
The bottom line is that certain media and certain writers just don't get along.
The manual:
http://www.p4c.philips.com/files/c/cdr760_17/cdr760_17_dfu_aen.pdf
Discussion online:
http://homerecording.com/bbs/general-discussions/recording-techniques/phillips-cdr870-187247/
http://answers.google.com/answers/threadview/id/318687.html
"I don't buy expensive blanks. I buy modest quality blanks and watch
for sales so that I can them for about a dime a piece after the rebate
check comes in. If I have an OPC Fail message, I try another blank. If
I find that they consistently fail (about half a buck wasted) I move
the stack over to the computer (which seems to work fine with these)
and buy another stack of blanks of a different brand next time I see a
good price..."
an interesting workaround:
http://www.sweetwater.com/forums/showthread.php?10128-Tascam-CD-RW5000
"CDRW 5000 work around for OPC FAIL
Here's a work around for OPC FAIL on cdrw 5000 -
method 1: turn unit on at least 30 minutes or more before use (this seems to work best for me)
method 2: run OPC on an old cd that always works - after OPC passes, remove old cd and insert new CD (you only get 99 OPC runs per disc)
-or use a combination of the two methods
I've always used TDK and I recently bought a new batch and they stopped working. The old ones still work everytime. I don't know enough about the system to guess what the difference is.
side note: CDRW 2000 will finalise discs from the cdrw 5000 but not the other way around.
Hope that helps "
Jan 30, 2011 | Philips CDR760 CD Player
My recorder DVDR 3330H has the "finalize" in the menu disk but I cannot click on it .
Probably you don't have a DVD+/-R disc inserted but a DVD+/-RW. A rewritable disc can't be finalised and doesn't have to be.
May 28, 2010 | Philips DVDR3330H DVD Player/HDD Recorder
When it comes time for me to copy my dvd...it prompts me to insert a blank dvd-r...i insert a blank dvd-r and it kicks the disc back out telling me to insert a blank dvd-r. Do i have to do something...
This is a common problem. RW DVD are different types. You need to read what type of RW DVD you need there will be either a nimber, leter or symbol at the end of where it says RW DVD or DVD RW and you CANNOT use just any disc.
Mar 16, 2010 | Roxio Easy CD & DVD Burning
Cd/dvd burner will only recognise blank cd discs not blank dvd discs
Find some "older" blank DVD-R, or DVD+R, or DVD-RW disks, and insert them.
If they are recognized, then access LG's web-site,
and look for a downloadable "firmware update" for your model.
The newer firmware adds support for "newer" DVD media.
If all else fails, replace the CD/DVD device.
Nov 06, 2009 | LG GMA-4020B Super-Multi...
Illustration:
Future outlook:
Jul 26, 2009 | Philips Televison & Video
Can't read CD but can read DVD
This is not uncommon. I have seen it often. It is a sign that the unit is about to fail, and needs to be replaced.
I don't know where you are, but around where I live, these dual layer DVD RW drives retail for less than 30 dollars. They usually come with software and are not difficult to install.
Beware of ESD, however, whenever you are working on the inside of a pc. ESD (electo static discharge) can destroy the insides of your machine without you knowing it until it's too late.
good luck
tony
May 20, 2009 | Sony (DWQ30AB2) DVD RW Dual Layer Burner
I have a dvdr3380 lately when i put in disc it says disc unrecord
Test the created DVD with TMPGEnc v4.0 Xpress here is the free trial link It has a read source function that will fail if the DVDR has not been authored correctly.
If this works and scans in the full DVDR then I suggested that you buy a branded DVD+R like Philips who created the format, if this still fails I think you DVDR 3380 will need a service.
LOL
Mar 15, 2009 | Philips DVDR3380/05 DVD Recorder
Dvdr 3480/05 user manual
Oct 02, 2008 | Philips DVDR3455H/37B
Video8 to DVD
First erase the DVD and then try...
you can erase DVD by right clicking the drive in my computer and selecting "ERASE DVDRW"
then you try to write onto the DVD-RW
Apr 11, 2008 | Computers & Internet
Televison & Video Logo
190 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
