model number doesn't come up but you can go here,put in your model number and see parts,sears.com http://www.searspartsdirect.com/partsdirect/part-model/110.629442100
Hi. Open up the back of the dryer after unplugging it. Take a deep
breath. This is not that hard. A dryer is a very simple thing but you
need to relax and figure out what the parts are. A dryer has a very
basic parts list. The obvious I will not go into with but here goes with
the electrical in the guts of the machine. A motor to turn the drum. A
heating element. A sensor to sense high temps for safety shutoff of the
element. A blower for air. Keep in mind as you look at this that usually
power wires are black or red. You will see some wires that are attached
to a sensor and then on to the heating elements. Take a test light or
volt ohm meter and see if the high temp limit sensor is bad. This can be
a simple ten dollar one from Radio Shack. That is, it will it get
continuity through it. You may have to detach the wires on this sensor
to do this test. The sensor is usually a flattened round disc with two
leads coming out of it. Test the element same as the sensor. Take the
part where there is no continuity through them to the appliance parts
store with the model and serial number of the dryer for appropriate
parts. Maybe ten bucks. I know it sounds scary but you may learn
something and if all else fails just pickup the phone and call the
repairman. Hope this helps. good luck please rate thes
If the venting is clogged this will happen. And that is a good thing because it is a safety measure built in to prevent fires. There is a thermostat that can tell when your dryer is over-heating,(usually caused by clogged venting by lint) and this devise tells the heating element to turn off so as not to create a fire. Clean out venting, inspect thermostats and element, replace if neccesary. You may only have to clean out the venting.
cutiepie, I've seen this many times on these dryers. You need to replace the door hinge. Not really a hard job to do. Post a model number (inside door) and we'll get you a part number...Catriver..post back.
