Question about HP PSC 750 All-In-One InkJet Printer
Changing cartridges I recently replaced the empty color cartridge in my HP PSC 750 printer with a proper cartridge replacement however an error message pops up on the printer screen either telling me to check the cartridge or that there is a scanner failure. It prints fine in black and white and color the message is annoying.
  • 7 more comments
  • Anonymous Nov 18, 2007
    Error message: "Incorret black cartridge installed"
  • Anonymous Dec 17, 2007
    I have a HP PSC 750 Printer. I am unable to scan. I get the message Scanner Failure please turn off power and turn on again. This did not fix the problem.
  • jimchap Jan 03, 2008
    black cartage
  • Anonymous Feb 10, 2008
    I change the color cartridge now I get the check color cartridge error message.
  • wantfixit Feb 15, 2008
    I had same problem. check color cartridges.
  • unal May 22, 2008
    i cant chenge cartridger..please help
  • Anonymous Jul 01, 2008
    My printer only printed in black and white until I replaced the color printer. Now it prints in charcoal grey + white and fuschia(hot pink). I tried to realign the cartridges to no avail because the printer is not able to detect the alignment page.
  • sandysea50 Jul 01, 2008
    my printer only printed in black and white until I changed the color cartridge. Now it only prints in charcoal/white and hot pink.
  • kusidaniel Aug 09, 2008
    how to change cartridge on a hp psc 750 printer
I just turned on my hp psc 750 and an error message appeared. Incorrect black cartridge installed
I just used it yesterday, what is wrong???
Posted on Aug 24, 2008
Every time I try to print in says remove and check color cartridges. I recently bought a new cartridge. Can I fix this myself or do I need to buy a nw cartridge again.
Try reseting the cartridge. If it doesn't work, call the customer service where you bought the cartridge for some options for that. You deserve a free replacement.
May 17, 2010 | HP PSC 750 All-In-One InkJet Printer
Printer always says "Remove and check color cartridge"
It must be your ruined catridge. Some times the wire connections are burned at the side of the catridge and you must thaw away it and buy a new color catridge.
Oct 28, 2009 | HP PSC 750 All-In-One InkJet Printer
Won't print gives error message above power and function push button incorrect color cartridge installed---was working fine yesterday no cartridge was done...
uninstall and reinstall printer and make sure u follow the promp and put the right cartridge in the right and color....2 different chambers
Apr 19, 2009 | HP PSC 750 All-In-One InkJet Printer
How can i print in just black with no color cartrage
in your printer you can use single cartridge but there should be both cartridge inserted in the will not print if only one cartridge let the colour cartridge empty but it should be there in the printer.other wise it will not present the problem in your printer is colour cartridge circuit is got faulty so the printer is not detecting the co,lour cartridge in it ask for this case you will have to compulsary get the replacement can buy new cartridge or recycles cartridge that will be quite cheaper then new cartridge.
Apr 03, 2009 | HP PSC 750 All-In-One InkJet Printer
HP PSC 1500 xi Cartridge Error Problem
You do need both cartridges installed in order to use the printer. Even if one is near empty it will print (although your quality may suffer).
Jan 16, 2009 | HP PSC 1510 All-In-One InkJet Printer
HP PSC 750 - Gives message - check cartridge or wrong cartridge..
You could try to clean with alcohol the metalic looking part of the cartridge. If this doen't work, you should replace it and try a new one. I would suspect the the ink has dried on the cartridge and is clogging the jets. .
Nov 27, 2008 | HP PSC 750 All-In-One InkJet Printer
How to use only black when the color is finished
you cannot use the printer by just keeping only 1 cartridge in the both the cartridges should be present in the printer then let the colour cartridge is empty what the problem can print the black printouts with empty colour cartridge in the printer, but both the cartridges should be in the printer.and if still you get the message as colour cartridge is empty please replace the colour cartridge.the simple option is yopu can get the same cartridge the cost of refilling is 10 times less then the new cartridge.
Oct 03, 2008 | HP PSC 750 All-In-One InkJet Printer
Color cartridge wont print
The color cartridge is defective. Sometimes, when the printer detects a refilled cartridge, it "marks" the cartridge as defective hence the refilled cartridge will not work on any printer.
Jul 21, 2008 | HP PSC 750 All-In-One InkJet Printer
Carriage Jam Error from replacing refilled cartridge
Cleaned the roller & carriage assembly, If possible service the printer your printer will work fine.
Mar 10, 2008 | HP PSC 750 All-In-One InkJet Printer
Had the same problem. Cleaned the copper-colored "contacts" on the actual printer. Where the printer and the cartridge touch ... you will see them when you take the cartridge out. Hope that helps.
Feb 17, 2008 | HP PSC 750 All-In-One InkJet Printer
HP PSC 750 All-In-One InkJet Printer Logo
1,108 people viewed this question
Ben Johnson
