Question about Whirlpool ED2FHEXN Side by Side Refrigerator
How do you remove the water filter supply howlines for a sears side by side refrigerrator model number 10657202602
2 Suggested Answers
SOURCE:
Controlfrk
  • 304 Answers
SOURCE: Refrigerator gushing water through ice maker filter
Filters themselves don't usually leak. Check full insertion of filter, cracked filter housing or cracked supply line.
Posted on Aug 22, 2009
Where can I get instructions for replacing the ice water dispenser panel?
disassembly and reassembly shouldn't be hard if you will take your time my first removing the module cover around dispenser it's the square plastic metalic looking window frame around the ice and water dispenser it should have two clips on the very bottom use a butter knife to push him in. once you get that off just make sure the power supply is off before hand you can go to Sears Parts Direct.com and enter your model number as model number not part Water Filters Lawn Garden Appliance Parts
you will see where to enter your model number and then look up the ice dispenser assembly so that you can see how it's put together this would be a good one for you too but they don't have this model you can get an idea of how it works but everyone's a little different
Appliance 911 Sea Breeze
Jul 29, 2015 | Electrolux EW23SS65HS (225 cu ft) Side by...
I have an Amana side by side, model number SRD20S4E. I can not locate my water filter to change it. Any ideas where it is? The water and ice tastes off and really need to find the filter.
In searching a parts listing for your model i do not see a listing for the filter and believe your model doesnt have one.
If it did it would be in the fresh food compartment in the ceiling in the upper right corner above the upper most shelf.
A external filter could be added to the water supply line where it could be easily accessed and replaced. Filter kits are sold at Sears Lowe's HomeDepot or your local appliance parts store
Aug 13, 2011 | Refrigerators
Where is the water filter on the amana #scd25tw
The Amana with model number SCD25TW does not have a water filter. You would have to install an in-line filter on the water supply line if you want to filter the water. If your talking about the model number ARS266ZBS, then open the refrigerator door and look at the top right hand side. You should see a filter housing with a tab to release. Once released you have to remove the filter from the housing to replace it. When finished be sure to run about a gallon through the dispenser, to flush any air out of the system.
Mar 23, 2011 | Amana ARS266ZBS Side by Side Refrigerator
Water overflows from icemaker & freezes in the freezer. Makes three ice cubes in a day & the water is extremely slow to fill glass from freezer door!
If both the water in door and ice maker are experienceing slow water problems the common point is the water supply itself.
This can be caused by:
1. Water supply shut off valve is partially closed or blocked with debris.
a. TURN water supply OFF
b. Remove the water line from the rear of the refrigerator ABOVE the in line filter (if one is installed)
c. Place the removed line into a bucket.
d. Turn on water supply and check flow. It should fill an 8 Oz glass in about 8 seconds.
If it passes this test then the water supply is fine. If it FAILS this test either cflear the obstruction in the line or replace the water supply valve from the house connection.
Test 2 (Water supply is OK
Reconnect water supply to external in-line filter (If installed) or water valve assy connection.
Your unit has a Verticle filter that if it is clogged will cause slow water flow.
Test water thru the door for the same amount of water flow. It should fill an 8 Oz glass in 10 seconds or less.
If it does ot do this then the VERTICAL internal water filter is clogged. (5 months or 500 Gallon change interval)
REPLACEMENT filter is PN LT500P but there are several like / suitable aftermarket replacements for the LT500P number.
As for the ice maker freezing up. There is only one cause for this and that is the water valve assy itself is bypassing water when it is supposed to be closed. The only remedy for this is to replace the water valve. They are not repairable.
The valve is available through sears parts direct:
http://www.searspartsdirect.com/partsdirect/part-number/LG-Parts/Refrigerator-Parts/5221JA2006D/0046/795/Model-LSC26905TT/3204/0165000?keySuffixId=NA&productTypeId=x&searchModelNumber=LSC26905TT&subCompDesc=Ice/water%20parts&brandDesc=LG&modelDesc=REFRIGERATOR&blt=11
Thanks for choosing FixYa.
Kelly
Sep 19, 2010 | LG LSC26905TT Side by Side Refrigerator
Kenmore side-by-side not dispensing ice or water, the ice maker has been replaced, no water going into the tray. I cannot locate the water filter, does this model have one?
Don't know what is the model number of your fridge. 1.Need check electric water valve under the fridge. If that fridge made by GE (Kenmore just a Sears brand name and they use several others manufacturers for refrigeration), usually it's a frozen plastic water supply line inside freezer door. You could unplug fridge for 24 hours (you have to put food from freezer to other freezer).
Jun 29, 2010 | Kenmore 24.5 cu. ft. Side-by-Side...
I have a kenmore modle 52559100
I am working through Sears Commercial Parts Direct and I cannot find that correct model number. Double check. Filters do not suddenly stop flow. Water control valves yes and when you have an ice maker the water valve has two sides. Water control valves are located most times on rear of refrigerator and near floor where the house hold water enters the refrigerator. Sometimes hiding behind a paper cover. Your number really looks good to me and I was surprised that it will not work. Double check and correct that number and I will be able to assist you better. In a way I wish Sears would not change the numbers. The 525 in the number is who made your model and 525 does not come up. Sea Breeze
Mar 13, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Have always had problems with bad tastes in the water supply. Service man replaced the tank with a coil, but the problem comes back in a couple of weeks. Now the ice is having the same problem. The cubes...
Put a box of baking soda just next to the ice maker to soak up smells. Even if water is filtered, it can get the smells present in the freezer. You can also put a large water filter inline from the supply under the sink that goes to the Frig. The small water filters in the frig are limited and some only filter particulates.
Oct 14, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Water coming from under the refrigerator.. it is getting heavier
see if defrost drain tube is in the pan under the fridge and check it is not plugged
Aug 10, 2009 | Kenmore 53642 / 53644 Side by Side...
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
Top Whirlpool Refrigerators Experts
Bruce Denton
Steve Allison
Steve Allison
Norman Worley
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
