Question about Danby DPAC8020 Air Conditioner
I need a manual for an Everstar MPK CR10 portable AC. It is a used model and we need to know the specifics on how to set it up.
SpotBert
  • 231 Answers
SOURCE: need owners manual for Everstar Portable AC MPM1-10CR-BB6
Here's the 34 page manual from Danby Canadian website. =>
http://www.danby.ca/cms/uploads/products/en_manual/DPAC8020.pdf
Please leave feedback. Thanks.
Posted on Jan 03, 2009
Ed Phillips
  • 11 Answers
SOURCE: I have an everstar mpk-10cr and it leaks water out
This cap must be in place in all coolers I have seen. Frequently there is a gasket that is identical to the type used on a common garden hose. It needs to be clean and free of cracks. They only cost pennies. I don't understand what you mean by "I plugged it up but water did not go into the normal receptacle."
I will assume you mean that this is a manually filled unit and not attached to a water source. If that is the case give me more details on what you mean.
Posted on Jun 20, 2009
  • 6 Answers
SOURCE: water going into carpet instead of ac water bucket
I have this air conditioner. What I did was get a long plastic tube from home depot and connect it to the middle back drain. I then put the plastic tube outside my window, or if u have a drain somewhere put it in there or put the end into a big bucket. Let gravity do its job. I did not connect the tube to the internal bucket b/c I would have to empty it too often. The air conditioner is on top of a table so that water will flow down the tube and out the window.
Posted on Aug 19, 2009
  • 744 Answers
SOURCE: Everstar MPK CR10, blows cold, but won't cycle.
Make sure the exhaust hose isn't longer than the maximum allowed and is not kinked, turned too many times (bends) and is the right diameter as specified in the manual. It sounds like the unit is going off on high head pressure.
If at all possible, change the exhaust hose to a smooth type rather than the corrogated hose that probably came with the unit. The less air restriction in the exhaust the better.
Seal any air leaks at the exhaust or discharge point.
Posted on Aug 23, 2009
  • 39 Answers
SOURCE: I am looking for an air vent hose for an Everstar
http://www.supportuscenter.com/product.asp?specific=90
Posted on Aug 21, 2010
Everstar MPK-10CR compressor keeps running after power off, on remote. Display blanks. Only shuts off when O/L @ wall plug tripped.
call in an electrician as there is a problem in the circuit allowing power from a neutral line and bypassing the switch
Jun 30, 2016 | Everstar Portable Air Conditioner MPK-10CR
Need Instruction manual for MPK-10CR
You can find the Use & Care Manual for your Everstar MPK-10CR here:http://www.supportuscenter.com/documents/MPK_Manual.pdf
The warranty & repair services for this unit are handled by Midea. I would suggest contacting their staff for the part.
Contact for Technical Service USA:
Contact Person: Winston Sankey
Tel: +1-305-591-8460
Fax: +1-305-591-8451
E-mail:winston@mideaamerica.com
I also did a search for you on AppliaceFactoryParts.com. This may be the part you are looking for:http://www.appliancefactoryparts.com/search/part/1371698/146072
Best of Luck!
Jul 16, 2012 | Heating & Cooling
Everstar mpk 10 cr 1 manual, have an error code of P-1
It means that the little drawer for the water on the side is full of water or that it is not closed completly. In the water drawer there is a switch that makes it turn off the AC if it is running ,then it will give you a P1 code.
Make sure the water drawer is empty of water then. put the drawer back in carefully and gently, the switch that is built into the drawer will make contacts and your problem should go away. you might have to unplug the unit from the wall for it to clear the problem after doing the above steps.
Also here is a link to their site, Midea the company that makes these MPK-10CR units. For the owners manuel http://www.supportuscenter.com/documents/MPK_Manual.pdf
http://www.supportuscenter.com/pilot.asp
Sep 11, 2009 | Everstar Portable Heater/Fan
Aug 23, 2009 | Heating & Cooling
Everstar portable air conditioner
IF ANYONE NEED TO SEE THE OWNERS MANUAL FOR THE
EVERSTAR PORTABLE AIR CONDITIONER
MODELS # MPM2 - 10CE - BB6
MODELS # MPM2 - 10EE - BB6
MODELS # MPM2 - 10CR - BB6
MODELS # MPM2 - 12CE - BB4
MODELS # MPM2 - 12EE - BB4
MODELS # MPM2 - 12CR - BB4
YOU CAN E-MAIL ME AT - RICHCPZ@YAHOO.COM
I'LL SEND IT TO YOU IN A PDF FILE
(AS LONG AS I DON'T LOOSE IT IN MY COMPUTER )
Sep 08, 2007 | Danby DPAC8020 Air Conditioner
Danby DPAC8020 Air Conditioner Logo
297 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
Dan Webster
Dan Webster
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
