Question about Dryers
Clothes dryer drum stops turning during drying cycle
My clothes dryer quits turning while drying the clothes , but if you spin the drum it works for a little while , then stops again.
    Problem Solver:
  • 16 Answers
Your motor is going out , it doesn't have wenough to keep going.
Posted on Jun 27, 2009
How do you dry clothes in this machine please
A fairly common problem! The official instructions are
Before using your dryer, wipe the dryer drum with a damp cloth to
remove dust from storing and shipping.
1. Load clothes loosely into the dryer and close the door. Do not
pack the dryer. Allow space for clothes to tumble freely.
2. Turn the Cycle Control knob to the recommended cycle for the type of load being dried. Use the Energy Preferred Automatic Setting (,) to dry most heavyweight and medium weight loads. See "Drying, Cycle, and Temperature Tips."
3. Select a temperature setting on models with a Temp/Fabric selector. The cycle descriptions include temperature setting suggestions.
4. Push the START button.
Stopping and Restarting
You can stop your dryer any time during a cycle.
To stop your dryer
Open the dryer door or turn the Cycle Control knob to OFE
NOTE: The Cycle Control knob should point to an Off area when
the dryer is not in use.
To restart your dryer
1. Close the door.
2. Select a new cycle and temperature (if desired).
3. Press START
Extracted from
http://www.manualslib.com/manual/511763/Whirlpool-Lte5243dq.html?page=10#manual
Nov 14, 2015 | Whirlpool AWZ410 Front Load Washer/Dryer
My kenmore 417 wahser making too much noise, it looks like the inner tub hitting the outer plastic housing. How can I fix it?
Have you tried moving the clothes around in the drum to balance the drum BEFORE you was them? If that works, you have solved the problem! Most people forget that when cloth gets wet it gets heavy so leaving the clothes unevenly placed in the drum dry will make a real problem when they get wet!
Dec 26, 2012 | Kenmore Washing Machines
Dryer wont turn on
try to spin the inner drum. You could have a broken belt. if it spins really easy, that's probably what it is. There should be some resistance when you turn it.
Sep 08, 2012 | Whirlpool Dryers
Drum knock when spin cycle
Hello.
Noises are common when using a two-in-one washer and dryer, as clicking or whirring is part of the cleaning process during the transition to the next cleaning process. The GE Spacesaver washer and dryer combo uses a top-loading washer stacked beneath the front-loading dryer, and uses an agitator that makes noises throughout the spin cycle. Although whirring or clicking is normal, other noises or malfunction indicates a problem with the washer that requires minor troubleshooting. Professional repair is necessary if the washer continues to experience problems during the spin cycle, as there may be a problem with the washer's agitator.
1 Open the washer's door and check the balance of the load's clothes. Clothes that are unevenly distributed around the agitator cause excessive shaking and result in an imbalance during the spin cycle. Reduce the load's size by removing clothing if the washer's drum is overloaded.
2 Push "Start/Pause" to pause the spin cycle and turn the washer's cycle knob to the "Off" position. Turn the knob to "Spin Only" and press "Start/Pause" to reset the cycle.
3 Turn the wrench counterclockwise or clockwise around the unit's legs to adjust the appliance's balance. The legs are adjustable with the help of a wrench to ensure the unit does not shake while in use. An unleveled unit shakes as it spins, and causes excessive squealing or rattling as it attempts to dry the clothes.
4 Touch "Start/Pause" on the front of the washer's control panel and unplug the washer/dryer unit's power cord from the electric oultlet. Wait two minutes and plug the power cord back into the electric outlet. Push "Start/Pause" to resume the spin cycle.
Thanks.
Nov 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The heating compenent works, but drum won't spin
Have you checked the belt? That's generally the problem when a dryer stops spinning.
May 19, 2009 | Whirlpool LEQ9858L Electric Dryer
Problems Drying Clothes
That's the way it works, kinda stupid, it would be good if it did that at first to loosen up clothes in case they're stuck to the drum but then move like a traditional dryer but that's just the way it is. BTW, here's a website with parts for it in case you need them. I never used them but just found them, I was lucky I never had any problems with my equator until now but I kinda can live with it (during rinse cycles it pumps water out but then when it does the short spins it does not, so rinsing is not as effective sinse it leaves a lot of dirty water in and then puts fresh water in and does it again, it does pump the water out during the final spin cycle though). Anyways, good luck. I bought mine in 2001 or 2002 and never had any problems except for the one I mentioned.
Apr 25, 2009 | Equator EZ 3600 CEE Front Load Washer /...
Dryer stopped working during cycle
is dryer drum turning u might be amotor are some other problem you may want to call a service tech to fix your dryer ok
Oct 21, 2017 | Maytag Performa PAV2200
Drying cycle runs but does not dry clothes
more than likely that your thermostats have blown if you could smell the heater element getting hot then this will be the case m8
Nov 23, 2006 | Hotpoint Aquarius WD640 Front Load...
Dryers Logo
329 people viewed this question
Top Dryers Experts
