Question about Gateway LCD26TV 26 in. Television
26" TV is inop
I have a 26" TV that was in my motor home, it quit working. Unable to turn on or off with remote or power switch in front of TV. Turn off main switch in back or unplug. Once on the screen goes form red to blue, to green and that is all it does. Unable to change channels or turn off. It will take a video input from the DVD player but the TV itself does not work.
  • 3 Answers
Re: 26" TV is inop
Gateway was sued Class action over LCD's and Plasmas they sold over a 2 year period. They resell 3rd party TV's that were very faulty, an immature design.
Here's what I learned about mine, which makes it limp through as a Computer monitor (both DVI and VCA) and halfway functional TV.
You have to connect a DVI source, on the Main Menu for the DVI input there is an option called "Factory Mode". scroll down to it with the CH buttons and select it with the vol button. The scroll to "initialize eprom", select and confirm it. After the "Waitting" words disappear, make sure you have a TV source connected, Then turn the TV off and on, using the hard switch in the back. The TV input should be defaulted to channel 10 or 11 now But you select a TV channel that has no TV signal on it (like channel 1 for example) , the whole TV input side will refuse to let you select it again, and you'll have a blank screen and have to start over.
That takes care of the blank screen thing Now the other problem is parental control is defaulting to "ON" or something, and you can't program channels. With the TV input Main Menu engaged, select "Setup Menu." If you have this problem, then you'll only see 2 options, all the TV input and channel programming options will be missing. You have to select Parental Control, and when it prompts you for a password hit the volume > button 4 times (or just wait for a minute.) This should bring back your TV System and auto prgram/manual search options.
Unfortunately, my TV doesn;t remember these setting very well if I select cable, it does better if I select "AIr". But at least it funtions - kind of. If you switch to your computer input, you probably will have to switch the monitor off and on from the back panel again. Mine always starts up with the menu onscreen. All this might bve less trouble if you have a the remote, I don;t know where mine went after the last move.
Good luck, and hope this helps.
Billy K.
Posted on Feb 12, 2009
0 characters
3 Points
When turning on the tv by either remote or switch on side screen will flash blue then turn off. Have unplugged tv still won't turn on.
Search Results
    Samsung TV Keeps Shutting Down - Forums - CNET > Forums > Samsung
    CNETWhen I turn the TV on for the first time each day it shuts itself off within 30 ... There is ablue kill switch there, but you don't want to fool with that. .... The tv will not turn offwith the remote or the side buttons on the tv. .... I replaced the lamp but the tv screen will have a momentary flash of light on the screen then it will turn on and ...
    Philips/Magnavox Tv Problems ? - Home Forums > Home Forums > Electronics
    Mar 26, 2005 - I turned the tv on then off a few tims then eventually the piture would come on. .... time, the LED will flash continuously along with the volume going up to max. ...... You can use the remote to turn the tv off and on but nothing else. ... If you press the power button over and over it stays on a blue screen but as ...
    Top 208 Complaints and Reviews about Akai ' Page 3 > Electronics > Televisions
    Rating: 1.9 - ‎37 votes
    The screen will not turn on with the remote, side switch or rocker arm. .... It will flash for a second and the blue Akai screen will display very briefly, but then .... Akai LCT3201AD TV does not turn on using either remote or power button. ... I turned itoff one night and the next time I turned it on, the green light came on, but it did ...
    Get help with audio, video, or power on Apple TV - Apple ...
Jan 28, 2016 | Flat Panel Televisions
I have a insignia ns-pdp50hd-09 plasma tv that has sound but no picture
You may try using the power switch on the TV itself instead of the remote. I have had trouble where the remote turn on doesn't work for the video, holding down on remote button longer seem to help.
Also you may want to try another input to the TV -so connect up input wires from your cable/sat to another one.
Jul 01, 2014 | Panasonic TC-26LX20 26 in. HD-Ready LCD...
Geedmorning, please help me to unlook FROM HOTEL MODE of old tv color 14" THOMSON 418x ITC008 EU. Many thanks best regards
To exit the hotel mode you have to put your tv on stand by using your remote. Then you have to switch the tv off using the power button on the tv. After that, while pressing the teletext key on the remote (magenta one), switch the tv on using the power button on the tv. Select "LOCK" and turn it off.
Hope this helps!
Apr 28, 2011 | Initial 26 in. LCD TV
The buttons on the top of our television has quit working and the remote has too. We cannot turn it off or on or the volume up or down and cannot go to the DVD player. We have no code to use to put it in...
There may be an issue with the tuner itself because the remote and the buttons no longer work. You can try a method of programming called a powerscan the steps are below:
Power Scan
1.) Hold down the clear "TV" button on the remote for four seconds, then press 500 pound ( #)
2.) Hold down the clear "TV" button on the remote for four seconds, press the big power button once.
3.) Press the channel up button once per second until the TV turns off then press pound (#).
Daniel Busa
DISH Network
Customer Service
Apr 12, 2011 | Protron PLTV-26 26 in. HD-Ready LCD...
LG 26lx1d tv will not turn on. Power supply is fine. Remote control is working. Also tried on/off button on tv and tv does not turn on. Red light blinking on front bottom of tv near remote receiver.
Have an LG26Lx1D for about 3 years, dropped off by my son.(Figures).Power light just blinking, but went back to red.Removed back panel, and metal cover. Just above antenna/cable input, its a small fan,mine was full of dirt. Blow off dirt, and make sure its turning freely.
Install back the covers, an voila....its a miracle...its working again.
Good luck
Jan 24, 2010 | LG 26LX1D 26 in. LCD HDTV
We lost power and the tv was on at the time the power went off when power returned the tv said no signal all other tvs in house work
if there is a stanby switch for the remote, turn it off. wait for a few minutes then turn it on. operate the remote.
Jul 17, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Cannot change channels in digital mode
Solution that worked for me:
Beware: Although the process should be safe, it technically voids your warranty.
Enter the service menu:
1 - turn of tv with remote
2 - press and release in the following order on the remote: Info, Menu, Mute. Make sure remote is pointing at the tv
3 - turn on the tv from the remote
4 - you will see the service menu. using the down arrow on the remote select the Reset option. Using the right arrow button at this point will do a hard reset.
5 - Wait a few seconds, turn TV on
6 - you will have to rescan analogue and digital channel but it should be working now.
Jan 29, 2008 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
Gateway LCD26TV 26 in. Television Logo
310 people viewed this question
Top Gateway Flat Panel Televisions Experts
olayoju victor
Are you a Gateway Flat Panel Television Expert? Answer questions, earn points and help others
