Question about Thermador MBBS Microwave Oven
F7 alarm on a Thermador Convection double oven - how do I stop it
How do you shut down the F7 alarm?
I have a Thermador Convection Microwave model MCES. The Microwave stopped working. I replaced the magnetron, and after a few days the same thing happened.
Perhaps the high voltage diode is the culprit.
Test info here: How to Test The High Voltage Diode Rectifier Used In Microwave Ovens
An important additinal test not mentined there is shown in the attached picture.
For more free help, feel free to contact me via my site with your detailed symptoms and full model number and FCC ID number as shown on the tag in or on the oven.
Nov 17, 2016 | Thermador Microwave Ovens
Thermoststat defective need new one
they only make 2 types...normally open or closed 155 degrees + or -
use a VOM reed the old one if it shows open you need a normally closed thermostat..$5 or less
Apr 11, 2014 | Thermador 30 inch Masterpiece Series...
Convection oven shuts off after a minute when trying to bake. Does this during Compubake also.. Does not preheat
Possibly a bad oven temp sensor. If the uinit doesnt read a temperature it will shut down to prevent a fire or over heating. The temp sensor is a thermister A temperature variable resistor that changes value as the temp changes. so If the main board doesnt get a response within a vertain resistance range it shuts things down. Sometimes since those parts are in the actual cooking area and subject to the heat and steam from cooking they can rust and break, or just get old and break. Or slam the door and break, you get the idea!!
Oct 19, 2017 | Sharp R-1874 Convection/Microwave Oven
Microwave sparks
If it sparks inside the oven then look inside for any powder paint missing... if so discard. If you has metal shelves or tin foil then don't put metal in when on microwave setting. Some of these metal shelves are for a microwave that is also a convection oven but only in the convection oven setting.
Nov 26, 2013 | Thermador Microwave Ovens
Microwave shuts down after 2 seconds
unplug the appliance from the main socket and plug it after sometime
Jun 07, 2013 | Thermador MCES MCEB Convection Microwave...
The oven (10+ years old GE True Temp double wall oven) beeps and displays an F7 error message. We can temporarily stop it by pushing the Clear button, but it starts again in a few seconds. We don't know...
I'm a GE tech, the F7 means there is either a stuck button on the keypad or relay on the board behind the keypad. Shut off the breaker. Remove the 3 screws under the keypad and lift the panel a bit to remove it. Lay it face down on the top rack and disconnect the ribbon cable. Turn power back on and if f7 goes away the problem is in the keypad. If f76 returns it's in the control. We typically replace both together because usually if you replace 1 it will come back later then be the other part.
Mar 26, 2011 | Microwave Ovens
Its got a code coming up saying f7
Most F7 codes are saying the keypad is sticking. Try running your fingers flat up and down across the keypad then horizontally multiple times and see if the F7 code clears. You cna verify this if you unplug the unit and then plug it back in. There should be a pause of about 16 seconds then the F7 code will appear if it is in fact a keypad problem.
Jan 22, 2010 | Whirlpool GH7208XR Convection / Microwave...
Microwave shuts down after 22 seconds
Assuming it's a Panasonic type with an inverter, If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter, controller, magnetron, or a bad connection from one or the other.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Jan 15, 2010 | Thermador MCES MCEB Convection Microwave...
Set covection baking temp / Thermador MCES
We have the owner's manual and have uploaded it to our site for you here.
Dec 24, 2009 | Thermador MCES MCEB Convection Microwave...
Thermador MBBS Microwave Oven Logo
245 people viewed this question
Top Thermador Microwave Ovens Experts
William Miller
William Miller
Chuck
Jerry Greenberg
Jerry Greenberg
Are you a Thermador Microwave Oven Expert? Answer questions, earn points and help others
