Question about Infinity SW-12 Subwoofer
I have an infinity sw12 that is for some reason making a high pitched noise and some cracking noises as well. It does seem to work otherwise. I get the same noise when the cable to the stereo is unplugged. Tried plugging it into another outlet. What could be causing that?
    President:
  • 1,114 Answers
It could be an internal "cold solder joint" however, if your lucky, it may just be dust buildup on the control pods and switches. Radio Shack sells "Tuner Wash" which will clean potentiometers (volume controls) and other electrical contact points. It's an inexpensive "try". Pull the volume and crossover knobs and lightly spray down with the wash. Let it set 10-15 seconds then move the control pod back and forth. Turn it back on and see if it's better. Hope this helps
Posted on Jun 26, 2009
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ...
www.highdefforum.com > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from www.highdefforum.com
High pitched sound coming from my Samsung DLP TV - Open Forum ...
www.dslreports.com > Forums > Social > Open Forum
DSLReports
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Jan 08, 2016 | Televison & Video
Engine makes high pitch sound
sounds like a vacuum leak check for cracked vacuum lines
Sep 03, 2013 | 2003 BMW 325
Sub woofer, duck call noise at start up!
Contact the seller and the shipper and have it replaced. You wont be happy unless you do. You will always wonder about sound quality.
Apr 29, 2013 | Audio Players & Recorders
2002 yukon makes a high pitch noise when driving
possible front wheel hub bearing going out..
Dec 23, 2012 | 2002 GMC Yukon XL
High pitch noise when on or off
Some ferrite cores of power supply regulator might poise this problem. Check for it.
Jul 07, 2012 | Samsung P2370HD 23 in. TV
Weird noises in drive and reverse
The high pitched whine in reverse sounds normal for a honda. Ever honda I have had makes a similar noise while in reverse. The spinning, scraping noise in drive is not normal. You might want to see a mechanic about that.
Apr 30, 2009 | 2002 Honda Civic
2005 honda accord hybrid - high pitch noise
I have the same problem and called Honda. One of their technicians said its related to transmission fluid and is considered normal, and there's nothing to fix. :(
Jun 29, 2008 | 2005 Honda Accord
High pitched whine
Ok maybe this may help .... there is a coil LL08 I believe... somtimes it creates a high pitch whine like you describe.. its stands up on the deflection board..it basicaly a large coil of copper wire....you can take silcon and put on the coil...in effect damping the ocillations...hope that might help
Mar 27, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Infinity SW-12 Subwoofer Logo
344 people viewed this question
Top Infinity Audio Players & Recorders Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you an Infinity Audio Player and Recorder Expert? Answer questions, earn points and help others
