Question about Teledyne Laars Laars Lite 2 Pool Heater 125,000 Btu / Propane Gas
Teledyne Laars Model#LLG175N. Pilot lites but heater wont come on. Help
    Top Expert:
  • Teledyne Laars Master
  • 8,673 Answers
Check safety circuit
Posted on Mar 19, 2016
5 Suggested Answers
  • 139 Answers
SOURCE: starting a teledyne laars heater
check for proper millivolt reading( 400-600).it could be 20 different problems and/or components
Posted on Jun 21, 2009
  • 139 Answers
SOURCE: My teledyne laars pool heater will not cycle on. The pilot is lit and the valave is in the on position
check millivolt output should be 400-600.if less than that you dont have enough voltage to power valve
  • 3 Answers
SOURCE: Teledyne Laars LD250 Propane Pool heater cycles on and back off
Do you replace the thermopile or check the milivolts?
Check the Pressure gas
You need replace all of them terminals and check again the milivolts at the gas valve
Posted on May 29, 2010
  • 3 Answers
SOURCE: Pilot light on but heater will not start
check the high-limit switches. Under the inlet/outlet header. if either is open it will not allow you to fire up. my 150 degree switch was corroded and after jump9ng out, bam it worked.
Posted on Aug 07, 2010
My laar hot shot natural gas pool heater pilot says lit but wont fire any more replaced pilot generator pilot that whole unit nice pilot but wont fire
problem isnt with the pilot generator. you have either an open safety withing circuit, lose wiring connection, or tstat issue
Aug 17, 2013 | Teledyne Laars Laars Lite 2 Pool Heater...
Teledyne laars xe pool and spa heater
look inside on panel directions if not turn to pilot setting hold down button light under where small silver line goes under while holding down button when lit keep holding for about a minute then turn to on should stay lit if wont stay lit need new pilot generator
Jun 09, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
Hi! I moved into a bank owned home with a hot tub that has a gas LAARS LITE 2 Teledyne heater. It is not working, so I had someone come out and check it. He said I need to purchase a pilot assembly before...
Go to www.laars.com and download a manual for your model. Get the model number from the heater, and look up a manual. If yours is a milivolt model, the pilot must be working to troubleshoot further. The manuals will be full of information.
Oct 01, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot will light but heater will not ignight
You may need to replace the Ignition Module. Have someone check to see if it is sending power. I have the same problem and need to replace the Fenwal automatic ignition system. The part cost $390 - check inside the heater for the model #
Jul 16, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
LARS LITE #LLG175N BURNER WON'T STAY LIT.
Make sure your pool filter is clean. Low water flow through the heater will be detected by water pressure switch
Jun 19, 2009 | Teledyne Laars Teledyne_ Laars Lite2...
Our pilot light on our Teledyne Laars ESG250N will light but our heater wont come on. Can anyone help me find any info on our old heater?
check pressure switch should be 24 volts on both terminals if not bad switch or plugged copper tube you can jump just to check
Jun 13, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Teledyne Laars Laars Lite 2 Pool Heater 125,000 Btu / Propane Gas  Logo
301 people viewed this question
Top Teledyne Laars Pool & Spa Experts
Paul Carew
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
